Yokomo MR4TC-BD
Old 08-19-2007, 04:41 AM
  #7561
Island Losi's Avatar
until i can get new nuts ill put a drop of 'blue' locktite in the nut and hopefully they wouldn't came off again
Island Losi is offline
Old 08-19-2007, 04:56 AM
  #7562
Post Setup needed
anyone got setups from........
Chris Grainger setup from the euros 07 that just concluded?
Billy Easton Roar Nats 06?
Masami Reedy race 05/05/07?
Old 08-19-2007, 12:04 PM
  #7563
JasonC's Avatar
Trader Rating: 120 (100%+)
here is what i use
http://www.fastener-express.com/inde...OD&ProdID=2244
JasonC is offline
Old 08-19-2007, 02:02 PM
  #7564
Chris Graingers setup from Euros.
Front
Drive train Yokomo alloy spool and fixed centre pulley
Roll-bar - none
Caster block 4 plastic
Camber - -2
Toe angle - 0
Susp spacer 1 mm under all 0.5 mount used
Steering arm - -0 inline graphite
Bladder Tamiya black, no O ring
Body - new version
Length - 1.5mm spacer inside, 11.6mm travel outside
Spring - Yokomo pro dot pink
Oil 450
Piston Tamiya #3
Droop - 5.5 to bottom of caster block
Top link inner 1mm under ball
Shock upper 3rd out lower tower
Shock lower middle
Ride height - 5mm
Ackermann 2nd from back
Rear
Roll-bar - none
Camber - -2
Toe angle 3
Susp spacer 0mm under all
Bladder Tamiya black no O ring
Body - new version
Spring yokomo pro dot blue
Oil - 400
Piston Tamiya #3
Droop 4.5 measured to hub, or wishbone
Top link inner - 0 washers
Top link outer - , short silver ball + 2mm washer
Shock upper 2nd in
Shock lower - outer hole
Susp arm - graphite
W/B 2-2
Ride height 5.5
There are loads on pictures of his car particularly on John Doucakis website.
John Pape is offline
Old 08-19-2007, 06:23 PM
  #7565
thanks Jason and John. i saw the pics of the car on the blog.
Old 08-20-2007, 01:24 AM
  #7566
I have recently got a second hand BD to play with, what are the recommended mod's for asphalt racing.
I take it the CGM steering mod is a good one to do. Do you still put hpi suspension parts on them and what the reason for doing this?
Cheers
Smartypants is offline
Old 08-20-2007, 05:33 AM
  #7567
yokemad's Avatar
All steering mods to get more steering Lock...
yokemad is offline
Old 08-20-2007, 08:47 AM
  #7568
Default tir spool / yokomo spool
anyone no the weight difference between the tir spool and the yokomo one?
thanks..
mwoods is offline
Old 08-20-2007, 02:08 PM
  #7569
JasonC's Avatar
http://www.rctech.net/forum/showpost...postcount=5322
yokomo plastic spool = 11 grams
TIR ( fist generation spool/ with steel pins) 16 grams
i have the newer genertaion spool just not drive cups, as soon as i get some i will see how much the 2nd generation spool weights
JasonC is offline
Old 08-20-2007, 02:51 PM
  #7570
thanks wat about the new yokomo blue spool? ive been running the tir spool just wondering if the new one was lighter..
mwoods is offline
Old 08-20-2007, 03:04 PM
  #7571
JasonC's Avatar
give me a couple of hours and ill get it for you.... ( from personal experiance... i would not recomend using the alum spool)
JasonC is offline
Old 08-20-2007, 04:54 PM
  #7572
Front
Roll-bar - none
Camber - -2
Toe angle - 0
Body - new version
Oil 450
Piston Tamiya #3
Shock lower middle
Ride height - 5mm
Rear
Roll-bar - none
Camber - -2
Toe angle 3
Body - new version
Oil - 400
Piston Tamiya #3
Shock upper 2nd in
Susp arm - graphite
W/B 2-2
Ride height 5.5
how does he mount the yokomo steering knuckle on the HB hub? I try it but yokomo steering knuckle is too tall for the hub. Does he shorten the knuckle?
canto54 is offline
Old 08-21-2007, 06:09 AM
  #7573
JasonC's Avatar
13.1 grams for the yokomo alum spool
JasonC is offline
Old 08-21-2007, 09:27 AM
  #7574
does anyone know what type wheel nuts masami and other guys are running. they look like 1/10 nitro(mugen).
BWOOD is offline
Old 08-21-2007, 09:29 AM
  #7575
thanks
mwoods is offline
