Old 07-29-2007, 06:57 PM   #7486
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
i mesure from the top of the axel to the setup board.
JasonC is offline   Reply With Quote
Old 07-30-2007, 11:42 AM   #7487
Midnight's Avatar
Trader Rating: 85 (100%+)
Default Set up
Does any one have a good setup for high bite asphalt? Thanks in advance.
Midnight is offline   Reply With Quote
Old 07-31-2007, 09:16 PM   #7488
Midnight's Avatar
Whats the weight of the yokomo blue?
Old 07-31-2007, 09:18 PM   #7489
Midnight's Avatar
Originally Posted by Martin Hofer View Post
yokomo blues all around
all possible hb suspension parts
damperposition:
front shocktower: middle between 2nd and 3rd hole
front wishbone: middle between middle and outmost hole
rear shocktower: 2nd outmost hole on old bd shocktower
rear wishbone: middle
frontmoste hole on prototype ackermannplate (equals stock steeringrack with sd-202)
1mm under inner camberlink ballstud all around
1mm under front suspensioblocks 0 under rear blocks
3 toe-in in the rear, SD-300F05 front
I'm not sure what dampers and droop they used so here's what i use atm:
Rayspeed 3*1.2 pistons
400 Muchmore front
350 Muchmore rear
80% rebound
frontdroop 6
reardroop 5
both on hudy blox
remember if u use the plastic gauge provided by yokomo u have to set the droop to 7 if u want a rear droop of 6
Don't ask me why that is but I tested it with hudy blox, an associated gauge and an alloy yokomo
them 3 are correct, the platic one always shows 1mm less so -> want 6? set 7!
What shock oil are you running? And whats the lb of your springs. Im running xray springs. Thanks in advance!
Old 07-31-2007, 11:20 PM   #7490
JasonC's Avatar
YS-1460L Black 14.50
YS-14575L Blue 14.80
YS-1455L Yellow 15.70
YS-1565L Pink 16.26
YS-15625L Green 17.00
YS-1560 Orange 18.50
Rayspeed
Spring Rating [lb/in]
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Old 08-03-2007, 06:22 PM   #7491
Island Losi's Avatar
the alu diff comes with a screw. is this the only screw that will work? if this breaks can i use the standard diff screw?
PS. 7 yokomos at the euros and 1 in 10th. good luck guys
Island Losi is offline   Reply With Quote
Old 08-06-2007, 08:06 AM   #7492
pics of Grainger's car from the Euros. notice the plastic ends on the CVD ends, are those yokomo outdrives?
where can i get these caps/rings that go over the outdrives?
Yokomo MR4TC-BD-img_6700.jpg   Yokomo MR4TC-BD-img_6701.jpg   Yokomo MR4TC-BD-img_6702.jpg
Old 08-06-2007, 08:25 AM   #7493
Send a message via AIM to canto54
yes this is some yokomo outdrives mod to fit Team Bombers blade. Personnaly I use Tamiya blades that fit pretty well.
As for the caps I don't know if they are available.
canto54 is offline   Reply With Quote
Old 08-06-2007, 09:28 AM   #7494
JJC
Originally Posted by Chris Grainger View Post
Hi Guys
Martin is right in what he says about more lock from the cgm parts, but they are best used with MR4 TC caster blocks. If you use std caster blocks then the CGM parts will make no real difference, I will explain why
with the std Caster blocks you don't get enough lock, that's why we tried using MR4 caster blocks, but even with these or filling the std ones, you still don't get enough lock because the alloy blue arms hit the rack.. Running the CGM parts fixes this, so with the CGM parts run MR4 TC blocks or file the std ones, I feel you want about 25 degrees on the inside front wheel
New roll bars are available from Yokomo and Yokomo USA but I don't think CML have had there delivery yet..
The Picture John posted is my car as it stands now, ready for the new Season, so as a picture tells a thousand words, you can pretty much see how I'm running it
Chris
Hi,
What is the part number for the MR4 TC castor blocks?
JJC is offline   Reply With Quote
Old 08-06-2007, 09:32 AM   #7495
parts is ZS-4134
Old 08-06-2007, 09:36 AM   #7496
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
He used Corally Blades
those rings havebeen used at the worlds 06 as the material of the worlds diff was softer. with the new blue alloy diff you will not need those rings as material is superstrong.
he just uses them for safety.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-06-2007, 10:56 AM   #7497
who the diff and spool that masami used? TiR?
was reading the earlier quote by Grainger and saw that for spool on ashalt u use up to 25 degrees of steering sweep? i have Tir CvDs on my car, what care/maintance i need to use for these CVDs?
Old 08-06-2007, 10:59 AM   #7498
The spool is TiR
the diff is the prototype of bd-500a
clean them and apply grease to make them run smooth
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-06-2007, 11:04 AM   #7499
i use grease in the outdrives, do u mean grease in the hinged area for the CVD?
Old 08-06-2007, 11:06 AM   #7500
not in the outdrive but in the point where dogbone and axle are connected
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
