Old 07-06-2007, 09:42 PM   #7426
Good day guys, i usually bash and race with my friends on concrete, and so i was trying to get as much ride height as i can from my bd, what i did was instead of placing the pin of the hub carriers on stock position, i placed on the slot closer to the dogbones,
i'm posting because i'd like to ask you guys what particular effects will this give me?
imel24 is offline   Reply With Quote
Old 07-08-2007, 06:01 PM   #7427
Island Losi's Avatar
wheres the best place to get a spool diif and pulley that would ship international. i need them ASAP
Island Losi is offline   Reply With Quote
Old 07-10-2007, 01:14 PM   #7428
do Yokomo USA ship overseas?
Old 07-10-2007, 01:31 PM   #7429
razzor's Avatar
What other brands, spools will fit a Yok BD ???
I know the Scythe can use a Yok spool.
Any other brands have same dimensions or slight modifications.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-10-2007, 02:12 PM   #7430
Well, erm, where are you from?? Maybe this helps finding a shop near you ;-)
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 07-10-2007, 02:45 PM   #7431
Barbados in the Caribbean which is very close to the US.
Old 07-10-2007, 03:07 PM   #7432
I for one can say I have absolutely no idea of where to find a RC shop in Barbados... But man how I'd love being there atm instead of working in Belgium
But prolly Speedtechrc would ship to you.
Old 07-10-2007, 03:22 PM   #7433
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
too bad Speedtech does not stock much of the Yokomo line anymore.
JasonC is offline   Reply With Quote
Old 07-10-2007, 04:05 PM   #7434
yeah its a nice place to live. our only rc shop closed two weeks ago (not that it stocked Yokomo parts anyway). everything has to be imported and duty paid which is around 40%. i always say u guys are the lucky ones with the built tracks and stuff.
exactly!
Old 07-12-2007, 06:19 PM   #7435
any one has the setup that Masami used at the 06 worlds?
Old 07-12-2007, 10:38 PM   #7436
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
yokomo blues all around
all possible hb suspension parts
damperposition:
front shocktower: middle between 2nd and 3rd hole
front wishbone: middle between middle and outmost hole
rear shocktower: 2nd outmost hole on old bd shocktower
rear wishbone: middle
frontmoste hole on prototype ackermannplate (equals stock steeringrack with sd-202)
1mm under inner camberlink ballstud all around
1mm under front suspensioblocks 0 under rear blocks
3 toe-in in the rear, SD-300F05 front
I'm not sure what dampers and droop they used so here's what i use atm:
Rayspeed 3*1.2 pistons
400 Muchmore front
350 Muchmore rear
80% rebound
frontdroop 6
reardroop 5
both on hudy blox
remember if u use the plastic gauge provided by yokomo u have to set the droop to 7 if u want a rear droop of 6
Don't ask me why that is but I tested it with hudy blox, an associated gauge and an alloy yokomo
them 3 are correct, the platic one always shows 1mm less so -> want 6? set 7!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 07-13-2007, 08:47 AM   #7437
thank u martin.
what are the spring rates of these springs and what are the rates of the new progressive springs?
Old 07-18-2007, 04:49 AM   #7438
mattwoodcraft's Avatar
Default rear diffs
gooday every one i own a yokomo bd but since i have gone too running brushless in it lrp tc spec with a 4.5 in it . it doesnt matter how i do the diffs the rear diff will blow up where the centre comes apart from the pulley i have put 6 new diffs in the back of the car i never had this problem when i was running a brushed mod all i can put it down too is the power of the new motor an batteries now days ..
if any one could help that would be great cheers
mattwoodcraft is offline   Reply With Quote
Old 07-18-2007, 05:01 AM   #7439
i too had that problem. i was told that the diff was too loose and the heat would melt/fuse the central parts together. this is with a plastic diff. i rebuilt it as per above post and i used tread lock on the nut. on the first run it was it slacken off but i was able to tighen it back. it seems to be holdin up. this is with a mamba max 6900
Old 07-18-2007, 05:07 AM   #7440
razzor's Avatar
with brushless i think diff rebuilds is a very important part of the prep work at a race meet.Instead of sorting out brushed motors you have to spend the time rebuilding diffs and instead of brushes and relevants spares you know have to stock up on diff hears and diff balls etc..
Casterracing ZX1.5R
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
