Old 06-24-2007, 07:32 PM   #7396
Island Losi's Avatar
Originally Posted by Martin Hofer View Post
new swaybarkits sd-412FS and RS i think
thanks, will check it out
Island Losi is offline   Reply With Quote
Old 06-24-2007, 11:09 PM   #7397
HOPENK's Avatar
Originally Posted by Quante View Post
Yep, a little bit too much epa.
Since I started driving a spool, I also had a problem with the pins not locking enough with the setscrew (and it was fastened hard). solved the problem with putting a ring of shrink wrap over the axle ;-)
thanks, i will try again using spool with less epa...
if pin keep loose, also is good to use locktite on a set screw every time you take it apart, clean it up before apply a locktite again, and a bit sand paper sthe center of the pin.
HOPENK is offline   Reply With Quote
Old 06-25-2007, 01:41 AM   #7398
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anybody know is these parts will fit in the BD?
- Front Steel Diff Joint (ZS-501S)
- Rear Steel Diff Joint (ZS-502S)
also, could anybody refer me to an HK online shopping site that has the front dogbones available? or would the T2 51mm dogbones fit the Yokomo axle and outdrive (assuming i don't install the blades)?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-25-2007, 11:49 AM   #7399
Well, the pin was all locktite'd up
So I'm gonna try sanding the pin if it happens again, hope it works! Good idea anyway.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 06-25-2007, 09:39 PM   #7400
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Voodoo: i dont know it the t2 outdrives will fit the BD but if you want to, you can try the one's on my t2 just to check. just have to remind me to bring it next race day.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 06-25-2007, 10:10 PM   #7401
skypilot's Avatar
Trader Rating: 14 (100%+)
this was two pages back. brought it forward to answer the above question
Originally Posted by skypilot View Post
not sure if its been mentioned before but did you guys know that the x-ray front one way out drive fit the bd. and the 51mm dog bones fits also, its a tad lighter not much but a tad. also with the xray outdrives you can play with the locked one way/spool setup. i'm gonna try and figure a way to pin it to make a full spool also.
skypilot is offline   Reply With Quote
Old 06-25-2007, 10:51 PM   #7402
highwayman's Avatar
with or without the blades?
highwayman is offline   Reply With Quote
Old 06-26-2007, 01:09 AM   #7403
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Xray outdrives + Xray dogbones = Xray blades required :-)
Pinning is is easy, you just have to drill a hole through the narrow part of the oneway. A team colleg uses it that way but the whole unit is pretty heavy
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-26-2007, 09:31 AM   #7404
VooDooPH's Avatar
yok outdrives + Xray dogbones = no need for blades?
Old 06-26-2007, 01:56 PM   #7405
Just got myself a BDM and wanted to know what is the base setup for the BD cars. Or a good starting setup for asphalt med but abbrasive grip. Track is fast/large with hairpins and i compare it to used in the 06 worlds in italy. it also came with duel oneways.
thanks
Old 06-26-2007, 09:28 PM   #7406
HOPENK's Avatar
i bought xray T2-07 dogbone, blade and outdrive with cross pin connecting the two outdrive, make it still oneway but solid between left and right.
so far i knew:
-X-outdrive fit into Y-oneway housing with no modification.
-Y-dogbone compare to X-dogbone:
--Y-dogbone has bigger pin on the ball end side, so if use the X-blade, too tight no play at all (dremel the Y-ball end pin smaller, so X-blade can have enough play).
--Y-dogbone has smaller BALL end side part, so if you used X-outdrive with y-dogbone w/ X-blade, it will wobble, too much play. X-dogbone cannot fit Y-outdrive, because has bigger BALL end part.
--Y-pin and Y-steel tube smaller (connect to the axle), X-pin=2mm, Y-pin=1.5mm. so X-pin cannot fit into Y-axle.
ALL ABOVE BASED ON MY EXPIRIENCE, MAY BE SOMEONE HAS DIFFERENT IDEA...
-for me the most important, if want to use any kind of blade, dont forget, you have to dremel the aluminium part above the the blade, which hold the inner ball for turnbuckle (bottom side). blade only last 1 battery, because the blade hit that parts...
Old 06-26-2007, 09:49 PM   #7407
HOPENK's Avatar
now iam using:
for oneway: yokomo one with blade. make outdrive SLOT wider so x-blade can fit in, and yokomo dogbone Ball end PIN smaller, so x-blade can fit in also.
for spool: yokomo oneway, glued it up the one way bearing with outdrive together, or use hpi pro4 aluminium spool (purple). also make slot wider...
i still cannot get yokomo aluminium spool...
Old 06-28-2007, 10:30 AM   #7408
would the diff with the thin blue ring around the ends be good enough for low turn brushless racing?
Hows the speedtech and team bomber spools?
Old 06-28-2007, 10:34 AM   #7409
tested it with a motor that is even harder than a 3,5T (won't say what it was). No problems at all
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-28-2007, 11:22 AM   #7410
Sleighty's Avatar
hi everyone
If i swap the rear 0.5 toe in hubs left to right, would that give me 0.5 toe out? So if i use that along with the 2.5 rear toe in block, that would give me 2.0toe in overall?
Would this be a good idea? or am i being stupid? I want less rear toe in for a high speed track in stock.
thanks
Sleighty is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
