Old 06-20-2007, 02:54 PM   #7381
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hello There you can Try Yokomo U.S.A. http://www.yokomousa.com/ I believe they have a manual you can down load also you can purchase parts from there Web site hope this helps
Mike
Originally Posted by Island Losi View Post
where can i get these from? part no.?
where can i find a english manuel for the BD?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-21-2007, 01:14 PM   #7382
Island Losi's Avatar
How good is the Yokomo spool for brushless racing?
Island Losi is offline   Reply With Quote
Old 06-21-2007, 02:13 PM   #7383
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
you can take the full plastic spool and throw it as far as you can :-)
but the alloy spool BD-501SAA is pretty good
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-21-2007, 02:37 PM   #7384
Send a message via AIM to aoizip
So far.. my plastic spool... last about 2 practice on the drive way.
if you like to air hop.. land the car while in full power... I would get the steel or alum spool!
~Ming
aoizip is offline   Reply With Quote
Old 06-21-2007, 04:44 PM   #7385
The outdrive portion of my plastic spool twisted right off and I didn't launch...I just had a wheel go up up on a curb. Broke two plastic spools. Neither of them lasted for one battery pack
DOTMAN is offline   Reply With Quote
Old 06-21-2007, 05:36 PM   #7386
thanks
Old 06-21-2007, 08:56 PM   #7387
HOPENK's Avatar
question please, iam using brushless 4.5r use spool with blade . but the problem i keep braking pin from original one and also mip cvd pin. so i swithed to one way again. what kind universal did you used? thanks...
HOPENK is offline   Reply With Quote
Old 06-22-2007, 12:25 AM   #7388
Which pin?? I'm also driving a spool and a 4.5r, I've broken 1 pin that connects the axle with the dogbone.
I was told here that I was prolly using to much steering lock, changed it and the problem was gone...
Btw, a spool and blades??? most guys I see using that combo run Xray and they need to change blades every 2 batteries!!
There's better spools available, look a few pages back, there were a few posts of it!
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 06-22-2007, 11:04 PM   #7389
HOPENK's Avatar
okay man, thanks. i broke pin between axle and the dogbone. steering lock? mean less EPA?
iam using original aluminium oneway, glued it together and cut it wide so the xray blade fit in...
Old 06-23-2007, 04:40 AM   #7390
hi all, ive been out of touring cars for a while now as ive been racing offroad... im now looking for a knew touring car and ive looked at the BD...is it a good car to startwith. ill be racing 27turn and 11turn mod on allternate weeks on a resonably tight twisty track 15 second laps. In the UK outside on asphalt.
if i got the BD:
whats spares are needed
what hopups are recomended
what tuning option will i need
and anything else
thanx jordan
jordys jrxs is offline   Reply With Quote
Old 06-23-2007, 06:02 AM   #7391
Yep, a little bit too much epa.
Since I started driving a spool, I also had a problem with the pins not locking enough with the setscrew (and it was fastened hard). solved the problem with putting a ring of shrink wrap over the axle ;-)
Old 06-23-2007, 06:08 AM   #7392
if i got the BD:
and anything else
thanx jordan
I've been running mod with the BD for 2 years now and I'm extremely happy with it. Runs easy, not too much problems, quality material and its been here for a few years without too much changes and still its very competitive.
Spares, the usual, some whishbones, steering blocks, C- hubs, diff outputs (->they say).
Hopups, some springs
Tuning options??? erm??? I run a TIR spool.
I did made a small carbon plate that connects the top of the bumper with the front bulkhead in case of a serious crash, prevents the chassis from breaking in the front.
Maybe someone else has some more ideas??
Old 06-23-2007, 01:26 PM   #7393
anyone running a mamba max (6900) on there car? i would like to see pics of the setup. i notice masami's car at the worlds used sway bars with one less bend in them , are these the new rayspeed bars or just use the bars from SD?
Old 06-24-2007, 12:01 PM   #7394
yokemad's Avatar
hi guys
I'm just wondering if any of you guys removed the plastic battery holders from the chasis if so what kind of effect you notice also I've got blue yokomo aluminum front drive shafts in a retail pack and I'm usually using front ball diff. does it give me any advantage to use aluminum drive shafts instead of standard steel ones???
Many thanx in advance
yokemad is offline   Reply With Quote
Old 06-24-2007, 02:00 PM   #7395
new swaybarkits sd-412FS and RS i think
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
