Old 06-04-2007, 04:58 AM   #7336
highwayman's Avatar
Originally Posted by skypilot View Post
no the I.D. of the stock out drive is to small for the dogbone. one of the two would have to be modified.
alrighty... thanks... thought maybe i could use the x-ray bones with the alum spool.
highwayman is offline   Reply With Quote
Old 06-04-2007, 11:02 AM   #7337
tantalus007's Avatar
Trader Rating: 17 (100%+)
sir, are there any problems when using the alum spool with the yokomo ti or steel cvd's???
tantalus007 is offline   Reply With Quote
Old 06-04-2007, 11:21 AM   #7338
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Originally Posted by mike ivy View Post
Hey Michael Schumacher,Try Demon I picked up there Asphalt chassis I like it alot. It takes about a week to get to ya if your from the U.S there based in the UK click this link below. hope this helps
http://demonpowerproducts.co.uk/index.php?cPath=94_85
Mike Ivy,
That Demon 3mm chassis has the same cut out like original? I've seen some BD chassis without any hole on electronic side.
Mike Schumacher is offline   Reply With Quote
Old 06-04-2007, 01:13 PM   #7339
Send a message via AIM to canto54
hi all, here is a pic of the updated spools from patrick jasmin. Old ones were great but these looks just fabulous. I will try them next weekend. My old spool have 6 races on it and absolutely no wear on the outdrives!!
canto54 is offline   Reply With Quote
Old 06-04-2007, 08:15 PM   #7340
skypilot's Avatar
Trader Rating: 14 (100%+)
i want some, how much plus shipping to seattle washington.
skypilot is offline   Reply With Quote
Old 06-04-2007, 08:25 PM   #7341
highwayman's Avatar
no problem, with the spool... i just thought that the x-ray or TC4 bones were stronger than the yoke ones.
Old 06-04-2007, 10:09 PM   #7342
for a while i thought that the yoke alum spools were having durability issues... i'll be testing those setup tips you gave me in the tracks... car needs a little more tweaking especially when using those wwwweeeeennnnnnggggggg!!! wwwweeeeennnnnnggggggg!!! motors...
Old 06-04-2007, 11:19 PM   #7343
Jochim_18's Avatar
It's all in your throtle fingers guys I've been using the same plastic rear diff since winter season and up to now with no issues. I've been runnning both mod and 19T. I guess I just got so used to driving my car like this like I was driving my 12th scale.
Old 06-05-2007, 02:03 PM   #7344
yokemad's Avatar
hi Guys
What You guys think about Aluminum Diff Halves ??Are they better than standard plastic ones or Is that waste of money to go for that nice looking Blue Alloy ones....Also Same question for Steering arms and rear uprights does it worth to buy Team suzuki alloy ones or Graphites are strong enough???
Thanx in advance for kind replies....
yokemad is offline   Reply With Quote
Old 06-05-2007, 02:10 PM   #7345
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
alloy parts in your suspension is a full waste of money.
unsprung weight you know.
Plastic is good .
The alloy outdrives are pretty good, but i recommend to make blades fit the outdrives as they are usually not ment to be used
Martin Hofer is offline   Reply With Quote
Old 06-05-2007, 02:22 PM   #7346
yokemad's Avatar
Thanx Mate
U mean the diff Rings Not normally used with aLLoy diff halves but You think It is better to use diff rings with alloy halves like plastic ones Is that wright?
Old 06-05-2007, 02:27 PM   #7347
um no
you have to widen the slots a bit in order to use xray, hotbodies or tamiya blades.
if you don't you will notice heavy wear on the outdrives in no time
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-05-2007, 05:39 PM   #7348
yokemad's Avatar
I got it now but that looks to me a bit long story I think it's better to carry on with Plastic diff outputs...They may not as strong as alloy ones but much cheaper than alloy ones and they dont need any mod...
Martin thank u very much for your help...
Cheers mate
Old 06-06-2007, 06:19 AM   #7349
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Mike Schumacher View Post
Mike Ivy,
Mike is this what you have seen? This is a chassis that I produced right after the BD came out. There are probably 10 or so out there. It was actually CNC machined from 3.17mm or 0.125" Very stiff. I also did a top plate as well.
Chris
Mach10_shooter is offline   Reply With Quote
Old 06-06-2007, 12:22 PM   #7350
you should contact him directly at this adress: [email protected]
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
