Old 04-04-2005, 06:35 AM   #721
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Talking
Originally posted by Matt Howard
So I guess no one knows the old "wd40 belt softening" trick?
I do!! I have my bag and a fresh car of wd-40 waiting for my car too!
fpart is offline   Reply With Quote
Old 04-04-2005, 07:32 AM   #722
ghoppa's Avatar
Trader Rating: 54 (98%+)
Originally posted by pheyhoe
So did you re-shim the center diff?
what shim size are they?
Good to hear that it was running ok, did you copy a setup off of a FK05 or something similar as far as shock settings go or did you use the kit setup??
I came across the same problem, but you will have extra parts (i.e.-2 bearings, e-clips, as well as shims/washes) and there is a shim in the "leftovers" that will work just fine for the center layshaft....
I too had a great outing with the car (Hesperia), but I encountered too much (forward) weight transfer into the corners (off throttle) and I did not have any "shims" (other than what came in the kit) to "mess around" with my anti-squat/dive. Made the car very squirrly entering the corners....
Can't wait for Steve to come out with a spool, this will help entering the corners "harder" as well as adding a little more "break" (esc). This will help 'cause a front one-way ain't happenin' @ Scott's track....
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-04-2005, 08:38 AM   #723
chaini's Avatar
Any general differnces in drivng compared to the SD SSG?
chaini is offline   Reply With Quote
Old 04-04-2005, 08:48 AM   #724
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Well Yes the SD is a shaft driven car and the BD is a belt driven car.....The shaft driven car has mre off the line rip but the belt have a more of smooth power band. You really notice on and off power with shaft driven cars where as the BD has very smooth on/off power. Kinda hard to really give you what the real differences are unless you drive each...That is what I am currently doing to see which suits my driving style. So far the BD is my first Belt 10th scale and so far it is really nice. I have to still get use to the insainly quiteness of a belt drive. I think I am starting to see what all the talk is about a belt drive car. However I do miss the awsome pull away I use to have with the SD against belt drive cars.....
Guess it will take some getting use to.
Take Care & GOD Bless
Stephen <><
Hey Steve, got me a Ti Screw kit yet??????
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-04-2005, 09:32 AM   #725
I haven't gotten to drive my BD on the track yet, how does it steer?
kmorast is offline   Reply With Quote
Old 04-04-2005, 09:53 AM   #726
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Mine have been soaking in rubbing alcohol overnight after I broke them in
Old 04-04-2005, 11:48 AM   #727
pheyhoe's Avatar
Is it better to soak the belts before running them in or after running the car for a while.
How long do you soak them for? do you take the wheels off the car to run it in?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-04-2005, 03:07 PM   #728
I soaked them overnight. The car doesnt even have suspension mounted on it, just breaking in the center drivetrain.
Old 04-04-2005, 03:16 PM   #729
pheyhoe's Avatar
I am guessing you lay the car flat when running it in without suspension then..? otherwise the driveshatfs would take one hell of a hammering...
Old 04-04-2005, 03:25 PM   #730
I'm only breaking in the belts, not the driveshafts and hub bearings.
Old 04-04-2005, 04:21 PM   #731
pheyhoe's Avatar
Ahhhh. i thought you meant you were breaking in the whole drive train...
Misunderstood you
Is it worth running in the full drivetrain?
Old 04-04-2005, 07:23 PM   #732
Misunderstood you
Dont really need to in my opinion, the bearings dont need much breaking in if you clean out the bearings.
Old 04-04-2005, 07:34 PM   #733
my rear diff was fitting to tight and would not spin free, so i removed the two shims and its much better, and after i removed the two shims, there still very little side to side play on the diff. also the center pully gears,had to add a shim there, was to much play. Robert
mugenracer is offline   Reply With Quote
Old 04-04-2005, 08:49 PM   #734
turns out there was some plastic flashing on the rear diff. after it was removed i reinstalled the two shims and now its perfict.
Old 04-04-2005, 10:27 PM   #735
ghoppa's Avatar
for the guys whom have run the car, question:
have you all noticed that the belt "rubs" the "driver's side" aluminum steering bellcrank??????
it is for some reason on mine, and I wanted to see if you all encountered this as well....
it just barely rubs, but I really don't think it'll be an "issue"....
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
