Old 05-31-2007, 07:55 PM   #7321
HOPENK's Avatar
excel delrin diff, as light as stock one. if u want stronger. i also used yokomo al diff sleve (like used on plastic solid axle) with a little ca glue.
specially when using modified like 4.5r, strong power, foam tires, hard driving. the original plastic wobbling so quick, not excel delrin. much stronger. and has extra hole, like u have 2 diff drive, will last long. BUT YOU HAVE TO USE LOCTITE ON THE ALUMINIUM NUT and SETTING DIFF SCREW. if not it become lose and burned the diff pulley. like we discussed last pages. i throw away 2 set of excel delrin because of that, same happen like Zach burned diff pulley pictures, sample pictures at top this pages...
HOPENK is offline   Reply With Quote
Old 05-31-2007, 09:18 PM   #7322
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Wow. 2 sets of delrin outdrive + 2 set of aluminum sleeve = $60 + shipping! Stock platic outdrives will last longer with aluminum sleeve, right? I mean... aluminum sleeve is better than the ring?
Mike Schumacher is offline   Reply With Quote
Old 05-31-2007, 09:33 PM   #7323
Originally Posted by kruit
Hello,
Can someone tell me the difference between the trailing(1), and non-trailing(0) steeringblocks?
The trailing blocks comes with the masami kit. I want to know what difference it makes on the track.
Thank you
Fred
The trailing(1) steering blocks has less steering but smoother steering feel. I used it with oneway on big track.( back in the days when 12T motor limit) When using spool, you need the extra steering from in-line(non trailing) blocks I use spool almost everywhere outdoor now when runnig mod.
OR even with oneway, you can use non trailing if you want an aggressive feel.
B-day is offline   Reply With Quote
Old 05-31-2007, 09:55 PM   #7324
HOPENK's Avatar
are you want to use diff front and rear? if only use rear, just 1 set delrin. diff sleeve not to necessary. i just if you need more secure.
for my opinion sleeve better than ring, i dont know about other people...
Old 05-31-2007, 11:27 PM   #7325
Talk about diff, anyone knows the tamiya TRF 415 or TA05 alloy diff will fit BD?
Old 06-01-2007, 07:35 AM   #7326
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
it will fit if you use the yok pulley and nįrrow it by several tenths
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-01-2007, 07:40 AM   #7327
Default THX
Blazer, B day thx
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 06-01-2007, 11:30 AM   #7328
Interesting... more detail info please.
Old 06-01-2007, 11:34 AM   #7329
IMO the stock diff halves work better than anything else I've tried. I've been using the same ones forever and they're hardly worn
DOTMAN is offline   Reply With Quote
Old 06-01-2007, 11:57 AM   #7330
i don't know exactly, but with a good lathe you can make it fit with no problems
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-02-2007, 09:16 PM   #7331
skypilot's Avatar
Trader Rating: 14 (100%+)
not sure if its been mentioned before but did you guys know that the x-ray front one way out drive fit the bd. and the 51mm dog bones fits also, its a tad lighter not much but a tad. also with the xray outdrives you can play with the locked one way/spool setup. i'm gonna try and figure a way to pin it to make a full spool also.
skypilot is offline   Reply With Quote
Old 06-02-2007, 09:48 PM   #7332
highwayman's Avatar
will the x-ray bones fit the stock 1-way?
highwayman is offline   Reply With Quote
Old 06-03-2007, 06:05 AM   #7333
skypilot's Avatar
no the I.D. of the stock out drive is to small for the dogbone. one of the two would have to be modified.
Old 06-03-2007, 09:43 PM   #7334
Looking for a carpet chassis for BD. I've seen some BD carpet chassis without any cut out (except battery slot and two diff area). Which company makes those chassis?
Old 06-04-2007, 03:48 AM   #7335
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Michael Schumacher,Try Demon I picked up there Asphalt chassis I like it alot. It takes about a week to get to ya if your from the U.S there based in the UK click this link below. hope this helps
http://demonpowerproducts.co.uk/index.php?cPath=94_85
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
