Old 05-31-2007, 04:58 AM   #7306
re; coolcanfanman
start with this and then tune it to his liking.
rayspeed reds all round
shock oil F50 R45
pistons 3 hole yok std
ride hieght F5.5 R5.7-6
2 camber angle all round
droop 5-4
shock holes on towers
F 3rd out B 4th out
shock position on arms
mid on front furest out on bck
plus a liitle tip put adative on the back around 5-7mins before you put it on the front.
why u may ask- the answer is because the front tires are usally put under the most load around tracks there for they heat up quicker causing the car to oversteer and later on in the race a slight bit of understeer. u dont have to do this but if you dont you will never know the difference.
cheers
blazer2 is offline   Reply With Quote
Old 05-31-2007, 06:25 AM   #7307
TheCoolCanFanMan's Avatar
Cheers for that Blazer
Malc TCCFM
Originally Posted by blazer2
re; coolcanfanman
shock oil F50 R45
droop 5-4
F 3rd out B 4th out
cheers
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-31-2007, 08:06 AM   #7308
Blazer, What traction compound d you use on carpet?
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 05-31-2007, 08:36 AM   #7309
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Anyone using this delrin diff? If so, how's that?
Mike Schumacher is offline   Reply With Quote
Old 05-31-2007, 08:38 AM   #7310
LRP Carpet
Old 05-31-2007, 09:59 AM   #7311
re;bluey 74
i use std team corally Jack the gripper or there carpet version.
if you suffer with a little bit of understeer and want to fine tune use the carpet jack the gripper on the front and the standard on the back.
Old 05-31-2007, 10:51 AM   #7312
Yeah, Corally Jack the Gripper & Carpet Jack are real good.
B-day is offline   Reply With Quote
Old 05-31-2007, 11:08 AM   #7313
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
FX-2 if it's well ventilated *g*
LRP Carpet 2 -> very good alternative
also Corally Carpet Jack
sometimes X-Gear
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-31-2007, 11:29 AM   #7314
Oh, Is it allowed to use FXII indoor in Germany?
Old 05-31-2007, 11:49 AM   #7315
actually .....no
but usually nobody cares as long as the places is not full of fx-2 smell :- )
I always have a little fan standing on my pit table circulating the air
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-31-2007, 11:53 AM   #7316
Originally Posted by Martin Hofer
actually .....no
Old 05-31-2007, 12:00 PM   #7317
I did try LRP, CS, Orion, MM, Paragon traction action(no smell). But Corally Jack and Carpet Jack usually work really well if not better than the others. Now I'm lazy and just stick to these two.
Old 05-31-2007, 02:01 PM   #7318
skypilot's Avatar
Trader Rating: 14 (100%+)
yes, its pretty, don't know the weight difference, but didn't make me any faster then the stock plastic. and both last me about same time. 4-5 months on rebuild
skypilot is offline   Reply With Quote
Old 05-31-2007, 06:03 PM   #7319
Hello,
Can someone tell me the difference between the trailing(1), and non-trailing(0) steeringblocks?
The trailing blocks comes with the masami kit. I want to know what difference it makes on the track.
Thank you
Fred
kruit is offline   Reply With Quote
Old 05-31-2007, 07:24 PM   #7320
HOPENK's Avatar
excel delrin diff drive is much stronger than stock one, it has 2 hole position, if 1 is worn out, u can used the other one. but dont forget the excel only used the aluminium nut, no lock nut like original one. so u need to put the loctite to the setting diff screw and the aluminium nut. if not it will lose...
HOPENK is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
