Old 05-25-2007, 11:08 AM   #7276
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I have never melt a diff pulley even though running 3,5T GM with 6 cells on high bite carpet.
but i also use rubber tires.
I have never glued diffplates to the outdrives as i replace them every 10 - 20 packs or so. worked fine.
one thing that can cause your diff to melt are the carbid diffballs. Give ceramic a try as the carbid wear pretty fast and then the diffplates are rubbing on the plastic. except this i can really not imagine any reason for the pulleys to melt.
Maybe you really push your car hard as you are running foams and due to this stress your diff much more than we rubber tire drivers do.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-25-2007, 12:00 PM   #7277
Send a message via MSN to Zacharopoulos
i have melted 2 times my rear diff cause of slipping!! i didn't tight it after the lube that wasn't needed went out!! so i burned it , and one time i didn't melt it but i broke the pulley , i'll try to post a pic!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-25-2007, 12:39 PM   #7278
Send a message via MSN to sidcup_chaz
i have never been threw a diff and i never glue my diff the only other thing i can suggest is to see if the yokomo mr4 tc pulley fit as they can put up with more heat
sidcup_chaz is offline   Reply With Quote
Old 05-25-2007, 04:50 PM   #7279
Smart Racing's Avatar
I have seen the diff pully melting problem before, it was solved by changing the thrust spring for a new one, this was done after new pulley's, diff balls , plates and lock nut were fitted and the pulley still melted but after the spring was swapped out the problem did not reoccur.
Its a cheap part give it a try.
Smart Racing is offline   Reply With Quote
Old 05-26-2007, 02:11 AM   #7280
HOPENK's Avatar
thanks zach, u really right. the problem with the lock nut. excel delrin outer drive only used aluminium piece. no locking at all. when i used the original outer drive, i use all new except the lock nut. i try it alredy and no more problem with the diff at all. thanks alot man...
HOPENK is offline   Reply With Quote
Old 05-26-2007, 02:21 AM   #7281
you are welcome man !!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-26-2007, 02:32 AM   #7282
HOPENK's Avatar
sorry i cant post the pictures, the damaged was the solid piece between holes for diff ball was melted, and smaller part which hold the bearing apart from the belt pulley. so the diff pulley has a big hole in the middle. and the diff ball stick together in cirle position. also damage 2 of my excel delrin. but i dont have problem at all before using the excel delrin in smaller track...
Old 05-26-2007, 04:08 AM   #7283
Good to know ;-)
Quante is offline   Reply With Quote
Old 05-26-2007, 11:07 AM   #7284
Racingbod85's Avatar
those driveshafts could be the original tir's before they brought out the worlds edition. I've got a set, look very similar. I melted two diffs running a 4.5 on carpet - much more cautious now with it. can start slipping no matter how tight i do it after 4 runs. will try ceramic and glue the plates.
chaz - if you are the ginger one - don't be giving advice to this lot!
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 05-26-2007, 03:08 PM   #7285
im sorry so i cant even try and offer some advise for god sake
Old 05-27-2007, 11:10 PM   #7286
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
will be my 1st time running mod in an upcomming club race... any set-up suggestions? I'll be using a GTB/4.5 on low-bite indoor asphalt. will some front anti-dive help?
also, how do i set-up the car with a spool? hoping to get more off-power turn-in
current set-up (used for 23/27/19T)
Front:
Shock mount: 3rd hole from outermost
Shocks: 30WT oil, almost zero rebound
Tamiya Blue springs
Ackerman: 2nd hole from front
Roll center: 1mm spacer under both arm mounts
1mm spacer on inner camber link
no spacer on the outer camber link (using middle hole)
0.5deg FR arm mount
lower hole on Chub, spacer on top kingpin screw
stock swaybar
2deg camber
0deg toe
1mm uptravel (droop)
center fixed pulley
front one-way or spool?
Rear:
Shock mount: 2nd hole from outermost
Tamiya Yellow springs
Roll center: no spacers under both arm mounts
2deg RR arm mount, 0.5deg rear uprights (total 2.5deg toe-in)
lower hole on rear uprights
2 deg camber
2mm uptravel (droop)
Tires: Sorex 36R
Inserts: Sorex TypeC Medium
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-28-2007, 01:23 AM   #7287
setups looks pretty good
i would try to mount the front camber link not on the middle hole on the c-hub, but on the ball-kingpin.
Have you tried a spool yet?
Spool gives you a more direct feel when turning in, but then pushes slightly. If you brake just a little bit you get more steering corner entry. But you really have to be careful not to get to slow.
What body are you running?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-28-2007, 03:57 AM   #7288
VooDooPH's Avatar
running an Excel Accord now. Tried the ball-kingpin on the chub but it tended to rub the ball cup on the inside of the wheel.
here's the BD with the GTB/4.5... as neat as i can put it together...
Old 05-28-2007, 06:02 AM   #7289
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
vooodoo, trim the upper part of the ballcup with an exacto knife. thats what i do. and it works for me.
see you 3rd round dude.
sorry if i wasnt able to reply a while ago, anyway.. by using anti-dive it will lessen your front caster, so i guess it will turn in more. i tried it last round and it gave my car lots of steering.
|JayFlores|2 is offline   Reply With Quote
Old 05-28-2007, 06:09 AM   #7290
VooDooPH's Avatar
thanks jay!
anti-dive means raising the front or rear suspension pin mount?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
