Old 05-10-2007, 03:32 PM   #7171
Send a message via MSN to Zacharopoulos
Originally Posted by DOTMAN
HOw do I get one of your spools? Also, do you offer replacement outdrives or are those the same ones that go on the Tamiya cars?
Actually i don't make them , i just use them and i am very sattisfied so i share it with you guys.
But you can contact patrick , who makes them and tell him that you found out his spool by my post and he will understand exactly what you need!!
also he does offer delrin replacements with aluminum rings as you can see at the pictures and if you want he can make for you a full delrin lightweight spool but without replacements
here is his site
and contact him with email here
thanks
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-10-2007, 04:08 PM   #7172
Thanks for the info
DOTMAN is offline   Reply With Quote
Old 05-10-2007, 04:16 PM   #7173
Thanks for the info
do not even mention it!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-11-2007, 01:56 AM   #7174
zacabrandy's Avatar
Is Yokomo going to release a new touring car in the near future? Does anyone know?
zacabrandy is offline   Reply With Quote
Old 05-11-2007, 05:24 AM   #7175
Send a message via AIM to canto54
I'm using these spool too.
I was using them on my T2 and now with my BD. As it was said, these spools are just awesome. Adjustement are just perfect and wear is very limited even with brushless power.
You can buy with confidence!!!
Robitronic Avid V2
Robitronic - Graupner - GM racing
JP Products
www.mrclongwy.fr
www.petitrc.com
canto54 is offline   Reply With Quote
Old 05-11-2007, 05:28 AM   #7176
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Talking
Originally Posted by aoizip
Hi Martin,
for the foam chassis, a 3mm of top and bottom deck would be great.
if you can also add one extra post on each of the corner(4 corners), like a wing style from xray. that would stiffen up the chassis even more. that way you can either stiffen or loosen up the chassis depends on traction. Because I think 4mm is way to over kill and with extra weight you carry. Not to image the price tag is going to carry over.
just some thought.
~Ming
Is someone making a 3mm foam chassis kit for the bd. If so i agree with Ming. I would like to see a 3mm chassis with the bulkhead cutouts and a top plate with wings(ala XRAY or BMI(cyclone)). Then I would run my BD indoors too!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 05-11-2007, 07:30 PM   #7177
send a pm to Jari if you want a stiff foam/carpet chassis. he makes an awesome carpet chassis for the bd and the lcg
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 05-11-2007, 08:37 PM   #7178
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey does this Guy Jari make a Thinner Yokomo BD Chassis for Asphalt? maybe a 2.25mm or a 2mm chassis I run on alot of low bite asphalt tracks Lol....
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-12-2007, 06:27 AM   #7179
Yep, I'd be interested in a more flexible chassis as well.
But lke said earlier, would it be interesting to make a soft chassis plate and make that stiffer by use of different top plates, like the xray chassis.
Any idea of the price range of the chassis??
Quante is offline   Reply With Quote
Old 05-12-2007, 10:38 PM   #7180
at this time Jari make a thick carpet chassis for the bd, lcg, hot bodies cyclone and his own 12th scale the FF07 (ff rc concepts)
TcORC president
Roche rapide p12
Old 05-12-2007, 10:56 PM   #7181
Switch Blade's Avatar
Send a message via AIM to Switch Blade
any price on the jari's lcg chassis? Is he on rc tech where I could send him a pm to discuss such matters?
College
Switch Blade is offline   Reply With Quote
Old 05-13-2007, 04:28 AM   #7182
highwayman's Avatar
i recently got the alum yoke spool, ran 4packs modified and raced 23T with it... spo far so good... although i did notice that the steel universals had a bit of wobble... too bad i cant use my TC4 bones with the yoke spool.
anybody tried widening the rear track width of the BDM to match the front? 190mm? it seems that i gained a bit of stability and steering when i made the rear wider... just wanted to see if anybody else had the same results...
highwayman is offline   Reply With Quote
Old 05-13-2007, 06:09 PM   #7183
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Yes, look for it early 2008. It'll be an updated version of the Masami kit, since its TC Worlds year...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-14-2007, 02:24 AM   #7184
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default 3.5 mm chassis
Just a note from past Yok BD experience.
anyone looking to release or make a 3mm or thicker chassis...
milled out pockets are a must for the BD...
the car does not like to sit high on a straight 3mm lower deck, the roll centers just don't get right.
I've used two different 3mm chassis and the car just didn't feel right at all, but once I put the car back down to the intended Yok (hard chassis) chassis it got all the grip back.
a 3mm or 3.5mm top deck would be great but the belt path needs to have a pocket also, belt will rub and where down very quickly without it. I always wanted to see someone release a 3.5 top deck with the pockets milled on the underside to keep the center of gravity as low as possible and assist the flex with a key-in effect.
just a few thoughts....anyone listening
olhipster1 is offline   Reply With Quote
Old 05-14-2007, 07:55 AM   #7185
Send a message via AIM to aoizip
Im listening Olando... that is why my corally is for carpet.. my bd is for outdoor!!
~Ming
aoizip is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
