Old 05-07-2007, 09:45 AM   #7156
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by |JayFlores|2
voodoo, this as a base setup works well in JPraceway but if you dont like it, firstly try to change droop settings and so on. hehe anyway, i was wondering who uses it in our place?.. hahaha! goodluck to that guy in our upcoming shootout.
me too praying for that guy and wishing him all the luck...
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 05-08-2007, 11:33 AM   #7157
harkonen's Avatar
Trader Rating: 19 (100%+)
Will xray T2 springs work on the Yokomo BDM shocks?
My RCtech feedback:
http://www.rctech.net/forum/showthread.php?t=93997&highlight=harkonen
Jesse R.
harkonen is offline   Reply With Quote
Old 05-08-2007, 11:55 AM   #7158
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
yes they should do, but hb works better. so I'd recommend to use those if you feel a need to use other springs
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-08-2007, 11:43 PM   #7159
Jochim_18's Avatar
HPI Springs all the way.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-09-2007, 04:51 AM   #7160
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guys I have a question about the Masami Rear Shock tower. I know when you use this shock tower you have to lenghten you shocks,I use 62mm for the rear what would be a good shock lenght for this tower.
Also what are the differences in Chassis
The original and the mg chassis I think that what its called Lol...
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-09-2007, 06:31 AM   #7161
the mg flexes the same as the old bd chassi, but with 4 cutouts less in the front, for more front impact stability
with the masami shocktower i used 65mm shocklength in the rear, but I went back to the old shock tower. simply better to have shorter shocks, and if you copy the design of the masami tower on the old shocktower you get an awesome look too
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-09-2007, 03:42 PM   #7162
mike ivy's Avatar
Cool, Thanks for the info
Old 05-09-2007, 03:49 PM   #7163
Default Thicker Carpet Chassis
This is a call to the guys who run on foams i do have a chassis in the works and at the moment its the same design as the original but will obviously be thicker material but with the parts milled out where suspension mounts and bulkheads go to keep the roll centres the same. Are there any changes that you would like to see and what material thickness 3mm or 3.5mm or maybe 4mm?
All your views will be welcome
Dan
Dan Hughes is offline   Reply With Quote
Old 05-10-2007, 09:35 AM   #7164
guys, has anybody tried using the Yok Aluminum Solid Front Spool, any comments??? does it work well on yok steel cvd's or do i have to upgrade to the ti cvd's???
Old 05-10-2007, 09:41 AM   #7165
it is pretty good
a friend of mine uses it since about 3 months now. no excessive wear even though it does not use blades.
he uses yok steel
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-10-2007, 11:41 AM   #7166
I used it and it notch after just a few runs. They should have made it to use blades.
DOTMAN is offline   Reply With Quote
Old 05-10-2007, 11:43 AM   #7167
Send a message via AIM to aoizip
Hi Martin,
for the foam chassis, a 3mm of top and bottom deck would be great.
if you can also add one extra post on each of the corner(4 corners), like a wing style from xray. that would stiffen up the chassis even more. that way you can either stiffen or loosen up the chassis depends on traction. Because I think 4mm is way to over kill and with extra weight you carry. Not to image the price tag is going to carry over.
just some thought.
~Ming
aoizip is offline   Reply With Quote
Old 05-10-2007, 03:07 PM   #7168
If you're looking for a spool, I'm driving the TIR one with delrin outputs, extremely happy about it, almost no wear, you keep the std axles and the outputs are pretty inexpensive.
Quante is offline   Reply With Quote
Old 05-10-2007, 03:13 PM   #7169
Send a message via MSN to Zacharopoulos
Hello if you are after a spool check my post and pictures here and
here
and don't ofrget that i race with 3.5T motor and TIR cvd
and contact me for any questions!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-10-2007, 03:20 PM   #7170
here
HOw do I get one of your spools? Also, do you offer replacement outdrives or are those the same ones that go on the Tamiya cars?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
