Old 04-04-2007, 05:07 PM   #7066
I have unopen yokomo bd Masami for sale
mrfastrc51 is offline   Reply With Quote
Old 04-09-2007, 09:49 AM   #7067
noline's Avatar
Hello there I have a couple of questions about the Yokomo BD. I race on a asphalt track 100X50 with rubber tires how would a gear these motors with a 112 spur?
Trinity based C027 stock motor
Trinity based Komodo 19t
Also what size bearings and what are the part numbers for the CGM steering
Any help would be greatly appreciated
noline is offline   Reply With Quote
Old 04-09-2007, 12:07 PM   #7068
Registered User
I have a few questions about running foam on carpet
1. need a setup
2. I don't want the center oneway, how do you make the front drive solid?
beltdriven is offline   Reply With Quote
Old 04-09-2007, 12:11 PM   #7069
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
not sure on the gearing but here is the part #s your looking for
bearing is 8mm x 4mm ( yokomo part # bb-84-4 )
cgm steering is sd-202g
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 04-09-2007, 05:16 PM   #7070
Registered User
how do you direct drive in the center?
Old 04-09-2007, 05:19 PM   #7071
coons88's Avatar
Send a message via MSN to coons88
You buy the locked center pulley...
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 04-09-2007, 05:23 PM   #7072
Registered User
part # please
Old 04-09-2007, 05:42 PM   #7073
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
BD-630
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-09-2007, 06:49 PM   #7074
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Foam setup
I'm always trying to get my foam setup better
so here my base point.
60/40 shock oil (front/rear)
33lb/24lb (front/rear) use Corally springs.
bomber belts
4.5/5 ride height (front/rear)
1mm/1.5 droop over ride height(front/rear)
FRONT:
.5 to 1 degree toe out
1mm shim kickup
ackerman outer front holes.
outer camber links on middle hole on Chub
Chub upper hinge pin
upper shock 3rd hole from outer
lower shock outmost hole possible (I use SDW arms)
belt tension med
REAR:
1 degree rear toe block (plastic)
upper shock tower 2nd hole from outer
lower shock outmost outer hole
camber link shortest position
belt tension med
rear bulkhead brace installed at outer bulkhead
Tires, Parma are Magenta and Indigo or stage 2 Jacos to suit your track.
Must install a thicker top deck, Team bomber or whatever you can get a hold of.
Hope that helps you out.
olhipster1 is offline   Reply With Quote
Old 04-09-2007, 06:59 PM   #7075
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Does anyone have a Edit pdf sheet for the Yokomo BD some guy here along while ago had one here to download I went to the Yokomo U.S.A site but did not see a editable one
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-09-2007, 10:31 PM   #7076
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default CVD
Ok , I know this is not a new question, and has been answered before. However, I'm hoping there has been a new development or two since last discussed.
What is the best axle (cvd) for the BDM? I have broken 6 stock M units and one steel unit. I actually own a full line hobby shop, but none of my distributors (including Yokomo) seem to have what I need.
Help?!?!?!
mrrcguy is offline   Reply With Quote
Old 04-10-2007, 12:28 AM   #7077
JasonC's Avatar
have you tried the TI racing CVD's
Old 04-10-2007, 01:46 AM   #7078
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
running a center locked pulley with a fron one way (low/med grip indoor asphalt). will a center one way help me get more corner speed?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-11-2007, 06:41 AM   #7079
Registered User
thanks for the info
Old 04-11-2007, 07:17 AM   #7080
Sleighty's Avatar
ive just got myself another BD after using an Xray for over a year, i cant for the life of me remember how to build the yokomo shocks properly. I used to be able to get them perfect with no air and equal reboud.
Can anybody give me there step by step and any tips as this may refresh my memory for the best way of doing things.
thanks very much
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
