Old 04-01-2007, 08:26 PM   #7051
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Chassis
I believe the standard chassis had a more cutout in the front section which resulted in a weaker front section.
The Masami had removed the cutouts in the front. It was mentioned on here that the Mchassis was a bit more rigid, but I have all three versions and find the standard and Mchassis are about the same in flex.
There are a few post about the chassis difference, do a quick search and you should find what you're looking with a few pics.
hope that helps ya
olhipster1 is offline   Reply With Quote
Old 04-01-2007, 08:34 PM   #7052
loopedeloop's Avatar
Thanks for the reply. Thats what I was hoping
loopedeloop is offline   Reply With Quote
Old 04-02-2007, 02:44 AM   #7053
Hi guys, I have a BD with standard kit steering knuckles and just noticed that one has a 0 and the other has a 1 marked on them. Is there a difference?
John
yoke2 is offline   Reply With Quote
Old 04-02-2007, 03:04 AM   #7054
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
yes, the 1mm trailing knuckles do have less steering than the 0mm knuckles. so you'd better replace the knuckle with a 1 on with a knuckle with a 0 on it.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-02-2007, 03:18 AM   #7055
Thanks Martin, Will change it before I race next
Old 04-03-2007, 10:25 AM   #7056
Sleighty's Avatar
hi everyone,
i have the gold front roll bar for the BD, do you have to cut it down to make it fit, its very long and im sure will catch on the steering assembly? Or have i been sold the wrong roll bars?
I have a gold and silver one..... any ideas?
cheers
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 04-03-2007, 11:35 AM   #7057
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by Sleighty
hi everyone,
cheers
sounds like you have the rear sway bar instead of a front
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 04-03-2007, 12:51 PM   #7058
Sleighty's Avatar
i suspected that was the situation thanks
A1-RC.com
Team Scream
Xray
Old 04-03-2007, 02:45 PM   #7059
Racingbod85's Avatar
Zach Try post number 6029 for pic of bulkhead mod. You grind away the most forward bottom point of the motor bulkhead and don't run the screw.
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 04-03-2007, 02:55 PM   #7060
Send a message via MSN to Zacharopoulos
thanks man , i was trying to find it but it is really an old mod ee?? i thought was something new!!
has anyone tried making larger the motor mounts holes so the motor mounts lower??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 04-03-2007, 03:16 PM   #7061
this was done at the worlds, they even removed some cf from the main chassi. not sure if the effect is that big ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-04-2007, 06:30 AM   #7062
yokemad's Avatar
Default Setup for no grip Woodenfloor...
Hi guys
We r Racing on a very low grip polished woodenfloor and just bought myself a Bd I not a well experienced driver so I need Your Setup ideas I know Car should be as soft as possible,We use 20mm minipin tyres,5mm ride height,6mm front,5mm rear droop,blue rear,white front springs but How should be the camber links? I put 2mm spacer to front,how should be the rear camber link long or short...Front 4 degree caster blocks,rear 3 degree toe in,fornt toe in 0,Camber front 1 rear 2...
What u reckon???
And any tips to built Shocks?? how do I understand too much or little the shock oil and Can I use schumacher 30W shock oil or do I have to use the one comes with kit If so what rate is that 45-30???
Any comments welcome
Thanx in advance
yokemad is offline   Reply With Quote
Old 04-04-2007, 06:41 AM   #7063
the kit oil is 450
put 1mm under the front inner ballstud and 1mm under the rear inner ballstud, droop maybe 5,5/5 or similar.
30wt oil sounds good
remove the rear side post and the rear brace for more flex.
use rayspeed blue springs up front, and rayspeed greens in the rear.
white/blue is rather hard
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-04-2007, 03:05 PM   #7064
yokemad's Avatar
Martin Thanx for good advices,White-Blue springs that comes with the kit so they shoud be Blue=soft,white=med. is that right?
Anyother comments welcome
Old 04-04-2007, 03:16 PM   #7065
white hard blue med green soft
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
