Old 03-29-2007, 02:30 PM   #7036
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
http://www.titaniumracing.com/produc...asp?menuid=228
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 03-29-2007, 02:43 PM   #7037
Send a message via MSN to Zacharopoulos
thanks but i am looking something that isn't directly from TIR site!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 03-30-2007, 02:18 AM   #7038
Default Big problem with CVD
What CVD are u using with spool up front?
Just brake mine SD-010FW, only 5 packs with 17t motor?
Is there some steel CVD or perhaps can i use something from another car/manufacturer that is strong and durable!
tomislav is offline   Reply With Quote
Old 03-30-2007, 03:24 AM   #7039
loopedeloop's Avatar
If you dont want to get tir spool and driveshaft (expensive) try the following:
Speedtech lightened steel Spool $29usd (get two for price of one at the moment)
http://www.speedtechrc.com/store/ebp...id=322&id=5124
For the driveshaft get some #53 drill blanks or bits and cut them down to replace the pins in your CVD's. They wont break near as much as the kit parts.
The std yok spool is made from brittle rubbish and wont handle careful use let alone the hiding it will get racing
loopedeloop is offline   Reply With Quote
Old 03-31-2007, 09:45 AM   #7040
Registered User
COULD I GET ALL THE PART #S NEEDED FOR MAKING A DIFF.
beltdriven is offline   Reply With Quote
Old 03-31-2007, 03:07 PM   #7041
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
don'T you have a manual? there are all part numbers in there
Martin Hofer is offline   Reply With Quote
Old 03-31-2007, 05:43 PM   #7042
Registered User
no
Old 04-01-2007, 05:33 AM   #7043
then download it!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-01-2007, 05:56 AM   #7044
Do you notice much difference removing the 2mm off the bottom of the motor bulkhead to induce more flex in the chassis???
Bryan D is offline   Reply With Quote
Old 04-01-2007, 11:59 AM   #7045
i tested it but had tweak after tightening the motor. don't know why but since then i don't use this bulkhead anymore
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-01-2007, 12:02 PM   #7046
about which bulkhead do you talk guys?? i think i missed something!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-01-2007, 12:24 PM   #7047
i have tested this and had tweak probs.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-01-2007, 01:11 PM   #7048
Well today I also tested the 1 or 2mm removed from the motor mount with the opposite C brace removed and the car came back with no tweek at all....I did check it after every run and still no tweek.
The main reason for doing this, is so it has equal flex left to right.
adyb is offline   Reply With Quote
Old 04-01-2007, 01:19 PM   #7049
if anyone coul pos any pics of this modification i would appreciate it!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-01-2007, 07:37 PM   #7050
Can anybody tell me what is the difference between the Std bottom plate BD-002 and the masami version BD-002MG.
I broke my std one this weekend and the only replacement available is the Masami version.
Thanks in advance.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
