Old 03-27-2007, 07:31 AM   #7021
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
bx diff screw and the diff joints
Martin Hofer is offline   Reply With Quote
Old 03-27-2007, 10:02 AM   #7022
BJ
Hi
Is anyone using the new narrow wheelhex clamps, do you run them with any spacers? If not do they rub on the ball cups.
BJ is offline   Reply With Quote
Old 03-27-2007, 11:37 AM   #7023
hi, i run the narrow hexes, the spacer is to allow normal track wheel width, so dont use the spacer. this will give you a 2mm narrower track. but if your using the s.d narrow arms you may need the spacers beacause the turn in may be too agressive plus increased tyre wear. i got gave this information with my car.
and thanks for the information ALI gave me, i will try it out.
blazer2 is offline   Reply With Quote
Old 03-28-2007, 01:39 PM   #7024
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default 0 degree toe
hey fellow Yok racers
Just a quick question, is there a way to get 0 degree rear toe.
I'm pretty sure Yok doesn't make a 0 deg rear aluminum block.
Currently using the plastic 1 degree SD block.
any help is appreciated.
olhipster1 is offline   Reply With Quote
Old 03-28-2007, 01:48 PM   #7025
Send a message via MSN to Zacharopoulos
yeap by using the 2 degrees rear block and 1 degree rear hubs the left-right and vice versa!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 03-28-2007, 01:52 PM   #7026
olhipster1's Avatar
Default ok
OK...thanks...
but maybe a bit confused with the answer...
2 degree rear toe block
minus
1 degree rear uprights (reversed)
equals
1 degree
am I correct or is it
when the 1deg rear upright is reversed it equal 2deg total angle.
i'm trying to get a total of 0 degree rear toe.
Old 03-28-2007, 02:21 PM   #7027
use a 1 suspension mount and 1 hubs switched from left to right. then you'll have 0
Old 03-28-2007, 02:23 PM   #7028
Send a message via AIM to aoizip
Hey OL,
why do you want a zero toe? Your car ran pretty good, if you are pushing at entering switch back, try add a little bit more droop in the rear to have more weight transfer to the front, and maybe laydown the front end shock 1 more hole.
~Ming
aoizip is offline   Reply With Quote
Old 03-28-2007, 02:49 PM   #7029
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
wouldn't that give you .5 of top no 0 ?
i was think a 1 deg block and 2deg block reversed ( right on the left and left on the right...) buy i may be worng ....
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 03-28-2007, 02:51 PM   #7030
JasonC's Avatar
im not sure if this would work but you could see if the one pice Rear Front mount will fit on the Rear?
new thigs to play with when i get home from work ........... yahhhh
Old 03-28-2007, 03:58 PM   #7031
olhipster1's Avatar
Default front block
i just measured the
front rear block
=47.50 mm approx
rear outer block
= 51.mm approx
darn it, that won't work.
guess i'm going to have try a few things also...
Aozip..the car was running great on foams this past weekend...
but if I dived into a corner way to hot the back would want to slip out just slightly. So almost got it set up right.
plus i want max speed on the straight, the 0 deg should give me just a bit more.
Chasing that perfect setup now...
ohh..by the way for everyone trying to get the ride adjustment easier..try using Associated shock ends with the steel pivot balls
Part #: 7217
this works perfectly, I can now run 54mm to 59mm foams without having to worry about ride height adjustment. I'm getting 2 to 6 ride height.
Pro-Yokomo ....
Old 03-29-2007, 01:44 PM   #7032
Default Drive shafts
Hi i have a set of hardend drive shafts but no packet any idea how i tell if these are front or rear?
kev-h
Kevh
Cyclone WCE
LRP Sphere TC spec
Novak SS 13.5
Spektrum 2.4
kev-h is offline   Reply With Quote
Old 03-29-2007, 01:48 PM   #7033
The axle lengths are different between front and rear driveshafts. Longer for the rear.
Bryan D is offline   Reply With Quote
Old 03-29-2007, 01:50 PM   #7034
do you know what the lengths are?
kev
Kevh
Cyclone WCE
LRP Sphere TC spec
Novak SS 13.5
Spektrum 2.4
Old 03-29-2007, 02:10 PM   #7035
Guys anyone know if any eshop has dogbones for TIR cvds for BD??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
