Old 02-23-2007, 07:49 AM   #6901
Send a message via AIM to aoizip
fiber-lyte doesn't want to ship outside the UK..
~Ming
aoizip is offline   Reply With Quote
Old 02-25-2007, 03:38 AM   #6902
Trader Rating: 69 (100%+)
when rebuilding the rear diff, is it okay if i just replace the diff balls and thrust balls, then flip the rings? will it feel the same as a diff with all brand new diff rings and balls?
marvi is offline   Reply With Quote
Old 02-25-2007, 10:31 AM   #6903
I just re-sand the other side of the d-ring to make it a bit smooth, or sand it till the groove is gone. then use it as it is... Been running the same diff ring for almost a year now.
Ming
Old 02-25-2007, 08:01 PM   #6904
Hi guys,
I have a in nice and good condition suzuki alum. knockle for sale.
only used for one race day at last summer club race(lent to a friend so he can finish the race day). there is a very slight grove on the pin area.
looking for $25 shipped in the lower 48 state, please pm me if you are interested.
thanks,
Ming
Yokomo MR4TC-BD-dsc04171.jpe   Yokomo MR4TC-BD-dsc04172.jpe
Old 02-26-2007, 01:56 PM   #6905
if you still having problem with CVD pin popping out to one side.
Here is another solution other then tightening that b!tching grub screw down.
~ heat shrink wrap ~
Old 02-26-2007, 09:21 PM   #6906
Jochim_18's Avatar
Tried those before it will hold up for a little while but they will come loose. Your best bet it's just get a hardened CVD that yokomo makes... I've been running it on mod class and it will take some punishement it will not bend like the standard steel dogbone.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-27-2007, 08:08 AM   #6907
mine holds up pretty well.. but again, I only run stock and 19t in outdoor with a spool. I found out that you can't over shrink it, it would be the best if you can find the tube that only shrink about 20% ~ 30% of its size. that way the shrink tube is not over stretching during the heating process.
My harden CVD is my back up...
~Ming
Old 02-28-2007, 07:08 AM   #6908
Racingbod85's Avatar
Ooooh yes they do! especially with a spool
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 02-28-2007, 09:01 AM   #6909
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I just got my bd and I am looking for the hinge pin balls that go in the alu. housing. My hobbyshop can't get them and its $8.00 to ship from yokomo.
roadrashracing is offline   Reply With Quote
Old 02-28-2007, 10:07 AM   #6910
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
looking for alternatives to the short ball connector (SD-401HC). any suggestions? also, the captured ball connectors in the T2 interest me (have a problem with popping turnbuckles)... is there a way to fit them in the BD?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-01-2007, 03:05 AM   #6911
Originally Posted by VooDooPH
... (have a problem with popping turnbuckles)... is there a way to fit them in the BD?
hey voodoo, are you using the stock yoke ball cups? ive also popped them on several occasions but i switched to RPM ball cups, havent popped one ever since you'll have to shorten the ones for the steering turnbuckles.
Old 03-01-2007, 11:06 PM   #6912
fullout's Avatar
Send a message via MSN to fullout
is anyone running a ball diff and the direct drive main gear adapter for carpet racing on foams. the guys at the track are telling me its the way to go. but none of them are driving bd's. helpppppp
fullout is offline   Reply With Quote
Old 03-01-2007, 11:13 PM   #6913
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default diff works
The direct center drive and diff is a must combo for running foams on carpet.
The car will push a lot without the above combo but if you're going to run rubber tires..you can easily switch back to the one way setups.
good thing about the Yok setup it's cheap to build a diff compared to other brand cars on the market.
other suggestion for foam racing:
1 degree rear toe - get the Yok SD plastic pivot blocks
shave the foams down 1mm so they don't rub on the steering knuckles or use wheel spacers.
getting correct ride height may be a tricky at first..so play around with different shock ends. I try get the shock length to around 62.5
allow me to run 57.5 mm foams at a ride height of 4.5 in the front and 5 in the rear.
olhipster1 is offline   Reply With Quote
Old 03-02-2007, 11:53 AM   #6914
fullout's Avatar
i appreciate the help thanks. now the next question is where is the best place to get yoko parts in north america? i was wondering if you can get offset premounted foams, it would save me from having to narrow the rims on a truer to get them to clear the rear shocks and the front hubs.
Old 03-02-2007, 11:58 AM   #6915
olhipster1's Avatar
Default parts
there are a few places you can order parts from.
yokomousa.com
horizonhobby.com
speedtech.com
stormerhobbies.com
or try and see if your local LHS can them for you.
I use Parmas believe they come in at 26mm width and just shave the down the steering knuckles or the tires just a tad bit on the front only...they fit well on the rear.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
