Old 01-29-2007, 06:28 PM   #6796
one thing i forgot to mention, i use straping tape to hold the batteries to the chassis instead of the battery brace, it allows the chassis to move equally on both sides.
Turtlemaster is offline   Reply With Quote
Old 01-30-2007, 09:34 AM   #6797
Send a message via MSN to Zacharopoulos
and you gain a lot of grams!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 01-30-2007, 02:13 PM   #6798
Wayne1one's Avatar
How much tape do you use?
Wayne1one is offline   Reply With Quote
Old 01-30-2007, 02:32 PM   #6799
what do you mean??? with the word 'gain" i meant save a lot of grams!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 01-31-2007, 03:20 AM   #6800
coons88's Avatar
Send a message via MSN to coons88
Originally Posted by coons88
I run my BDM on foams, and I really sturggle to get ride height with it. I have to run about 60mm tires to get an optimal ride height of around 4mm. I would like to be able to run my tires right down to 56mm, but I just can't get ride height. Righ 56-58mm tires I get 1-2mm ride height. On the rear shocks I have to wind the pre-load basically all the way down as far as it will go to get about 4mm ride height. I run 4f 3r droop, and my shocks are 64mm rear 63mm front. Does anyone else have this problem? Or anyone know how to solve it? It is really really annoying.
I can't make my shocks any longer without the shock ends falling off, so I was thinking of trying the long shock ends but everyone says it makes the car handle funny, and to never use them, but I don't understand how making the shocks 65mm with long shock ends is any different to making hte shocks 65mm with short shock ends apart from the fact that they wont fall off in a impact.
Any input? Because im clueless
In regaurds to this. With alot of help and thinking from one of the Yokomo gurus here he figured it out. I was using the aluminum speed racing rear hubs to gain 0.5 out board toe. But it turns out the axel sits about 1mm (maybe more) higher then in the standard hubs. I havn't actually tested it at the moment because my car is in bits as I am rebuilding it. But comparing the two hubs side by side you can deffinetly see the difference.
So if anyone else is having this problem, and is running those hubs, take a look.
Moral of the story, stick with genuine Yokomo parts
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 02-03-2007, 04:39 PM   #6801
crabboy's Avatar
Trader Rating: 58 (98%+)
I heard Yokomo anouncing a new touring car on the 28th of this month, has anyone got any info on it already, maybe Chris Grainger can shed some light on it, he has been very quite on here of late, time for another post Chris and spill the beans.
I wonder if it will be a new car or a revision of the BD.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 02-03-2007, 04:53 PM   #6802
Jochim_18's Avatar
whohooo... I'm hoping for yokomo to come up with a new touring car I've been running my BD for 2 years now still very competitive with it.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-03-2007, 05:34 PM   #6803
H.Nilsson's Avatar
WHY!!!!!!
H.Nilsson is offline   Reply With Quote
Old 02-03-2007, 06:16 PM   #6804
m3ndo5a's Avatar
I pray to God its another Drift car I just order a Second BDM... But it wouldn't hurt to have another Yokomo BD super car
m3ndo5a is offline   Reply With Quote
Old 02-03-2007, 07:59 PM   #6805
loopedeloop's Avatar
Well I'm hoping they dont lol.
Leave touring car flavour of the month to Xray
loopedeloop is offline   Reply With Quote
Old 02-03-2007, 10:09 PM   #6806
Jochim_18's Avatar
Originally Posted by H.Nilsson
WHY!!!!!!
Why not? Don't you want to see yokomo to come up with a new car?
Old 02-03-2007, 11:02 PM   #6807
crabboy's Avatar
Im thinking it will be just a revised BD maybe with a new steering set up like the team has been running. The BD has been around for a couple of years now, so maybe its time for some new BD parts.
Still would be good to hear from Chris what the changes are.
Rhys Marshall.
Old 02-03-2007, 11:10 PM   #6808
Hey everyone, I just picked up a new BD (not the Masami) and have been searching the form for the latest modifications to the car. Can someone share which parts and part numbers (arms, c-hubs, steering mods, etc.) I should consider buying/doing to help me compete in 19t carpet/rubber class. Is the stock chassis good or has there been a stiffer chassis released yet? Thank!
Electro-MAX RC is offline   Reply With Quote
Old 02-04-2007, 02:35 AM   #6809
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
ok here are the must have parts for rubber racing on carpet:
RS-25 (swaybars front)
ZC-412 (maybe ZS, not sure, swaybars rear)
Rayspeed Green Spríngs (for the Rear, Blue/Green works nearly always)
SD-202G +
ZS-4134 (this is the steering setup Masami ran at JMRCA, but...)
HB Frontend (.. feels better when driving. can'T describe why but the car feels better with them)
SD-415S steering arms (if u use ZS-4134)
tha bd-001gh is also a very good option part but I would try the stock chassi.
Martin Hofer is offline   Reply With Quote
Old 02-04-2007, 06:16 AM   #6810
Wayne1one's Avatar
I think its time for something new too, all of these xrays and corallys running around here unchecked. Time to put a new yokomo in the hobby shops. a US spec (stiff) chassis that would work great on high traction surface with foams.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
