Old 01-22-2007, 12:38 PM   #6751
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
no need for doing it this way. just plug the wire in and push the batterie in the slot. There will be enough space. :-) looks much cleaner this way. maybe I'll make a pic tomorrow and show you what I mean.
Martin Hofer is offline   Reply With Quote
Old 01-22-2007, 01:04 PM   #6752
Send a message via MSN to Zacharopoulos
That's actually not the way i do it when racing with 5 cells but i will post pictures later , after installing my new magnesium screws!!!
anyone know where i can find TIR cvd??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 01-22-2007, 03:03 PM   #6753
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by pcar951
On a less positive note. I ran my new BD500A aluminum diff halfs this weekend. They were notched an basically unuseable after 4 runs in 19 turn. Anyone else had a problem?
ditto
going back to plastic ltr`s
got grease on there aswell ,
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-22-2007, 04:25 PM   #6754
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MR JOLLY
ditto
What about the delrin diffs? Saw them on ebay, don't know the manufacturer, wonder if they're crap too?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-22-2007, 05:55 PM   #6755
lignum vitae's Avatar
made by excel they are well worth trying.
lignum vitae is offline   Reply With Quote
Old 01-22-2007, 09:03 PM   #6756
was that on the rear??
as far as the excel delrin diff halves, they last a very long time and once set no diff adjustments needed. however i find the same with the stock ones. not sure what the advantage is.
Turtlemaster is offline   Reply With Quote
Old 01-22-2007, 11:15 PM   #6757
Maybe the weight!!! Lighter rear diff , maybe more stability at the rear???
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 01-23-2007, 12:17 AM   #6758
MR JOLLY's Avatar
or maybe cos it looks white it looks fast
Old 01-23-2007, 01:17 AM   #6759
for 1 they are not just a cheap moulding like std wich means truer running 2 they have 4 slots so theoretically last twice as long
Old 01-23-2007, 06:16 AM   #6760
maybe, my lap times didn't change and thats the bottom line.
Old 01-23-2007, 08:12 AM   #6761
pcar951's Avatar
I'm running foam on carpet, had the aluminum diffs front and rear. The front notched first. Maybe I'll try to widen the slots and use blades.
Jim Chapman
Old 01-23-2007, 09:40 PM   #6762
thanks, maybe on pavement it won't be so bad, i have the spool and diffs and thier so pretty i'd hate to ruin them, ( i didn't buy them to go faster just for the coolness factor)
on another note, sheldons hobby is having a 60% off sale and they have a couple of sets of the alum rear hubs. problem is they are not doing phone or internet sales but if you know someone in the bay area that can hook you up....
note #2 tried the front toe blocks, wow. way to touchy, took off the 0 degree front steering knuckles and installed the 1's, changed the white yok spings for the old school orange ones, car is money right now, if your running med to high bite asphalt you are welcome to pm me i will send you my set up. this set up is with a spool.
Old 01-23-2007, 10:04 PM   #6763
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
there's a 1deg front-front toe block? kinda got confused... bot a 0.5deg front toe block and thought i'd get a front-front piece. but when i arrived i was a front rear block.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-23-2007, 11:17 PM   #6764
pcar951's Avatar
Yes, I ordered the same piece and had to call Yokomo USA to verify it's position. Sucks that you have to remove material from the arms to make them clear but should give more turn in.
Jim Chapman
Old 01-24-2007, 04:55 AM   #6765
VooDooPH's Avatar
do you run with 1deg front-front toe mount only with the 0deg front-rear mount? or can you pair it with a 0.5deg front-rear?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
