Old 01-09-2007, 09:48 AM   #6676
H.Nilsson's Avatar
Originally Posted by fpart
I tested the front inner toe blocks. I just did it one time and it was OK but didn't improve my lap times so I went back. I am running indoors carpet right now and think that the blocks are not good for carpet. What springs are you talking about the white ones or something newer. If the white ones are what you are referring to, I use them almost exclusively(except carpet) orange paint up front and green paint rear most of the time with a spool outdoors.
Hall÷!
I have the white ones "pro series spring" in front orange and rear pink sometimes i run rayspeed white front and blue in the rear . I improved my lap times widh toe-in blocks 0,5 and a one-way
aboute the PR i have hade no problem sins i puttit in the bumper but when i hade it on the side some crashes make it go lose
DHI CUP 3 days away!!!!!!!!!!
Have tested MUCH-MORE tires but i like LRP better
H.Nilsson is offline   Reply With Quote
Old 01-09-2007, 12:20 PM   #6677
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I use Yokomo New-Style greens up front and pinks in the rear almost exclusively. Outdoor and indoor.
Martin Hofer is offline   Reply With Quote
Old 01-10-2007, 08:46 AM   #6678
tantalus007's Avatar
Trader Rating: 17 (100%+)
Could anyone explain what the effects would be if i remove the 1mm alum shimms underneath the alum suspension mounts... also what if i remove the shimms on the rear susp mounts only and vice versa???
thanks in advance...
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 01-10-2007, 01:15 PM   #6679
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
put it simple without getting confusing & tricky
1)If removed it acts like a Citreon 2cv (low roll centre), this is good for old racers with slow reactions
good in low grip situ`s ,where you get car to generate more grip then whats on offer
2)If left in acts like a F1 car (high roll centre ) this is good for youg racers with fast reactions
Good for high grip conditions ,makes car react quicker to driver input & get round faster
HTH
(Hii John !! chris`s side kick
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-10-2007, 02:43 PM   #6680
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
You're backwards Jolly
Lower rollcentres will take away grip by generating less chassis roll (IE removing the spacer, chassis roll like an F1 car).
High rollcentres will generate grip by allowing the chassis to roll more (IE adding a spacer, chassis roll like a Shitroen 2CV).
Edit: im reffering to the spacer under the inner ballstud.
v0rtex is offline   Reply With Quote
Old 01-10-2007, 02:57 PM   #6681
Send a message via MSN to Zacharopoulos
Guys are you talking about removing all the four spacers or only the two of them??
i mean lowering both rear/front suspension mounts or only the one??
thanks
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 01-10-2007, 06:35 PM   #6682
Default STOCK?
Guys,
Ive been looking aroundfor some parts recently and noticinng that some places includin my LHS are very low.
Has anyone heard any more about the rumor of a REvised BD
Any one care to fill us in?
Cheers
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 01-11-2007, 01:23 AM   #6683
MR JOLLY's Avatar
Edit
Im talking about the wishbone blocks
Old 01-11-2007, 01:32 AM   #6684
MR JOLLY's Avatar
thanks
Vortex is doing the ballstud way
i am talking about your way (wishbone blocks)
all four in front & rear
Side note
chris grainger has pointed out
you should run 1mm spacer under front blocks only to make roll centre the same back & front of car (get me)
at the mo i`m running Russell williams setup for rubber/carpet and that has
2mm under front blocks ,1mm under rear blocks
Some guys it says it feels a little Vague in the corners
bit i`m getting used to it my self & it seems to suit my Shakes i have ,mainley the car stays behaved longer & it seems easier to drive for me & settled for my own troublsome shakes i have
Old 01-11-2007, 03:38 AM   #6685
Not to mention the 2mm under the front inner camberlinks, that would be too twitchy wouldnt it?
Old 01-11-2007, 07:02 AM   #6686
MR JOLLY's Avatar
Foor some reason it isn`t (to me anyway) & it works ,this is with std chassis
since i have the Demon 3mm one it works okay
Old 01-11-2007, 08:28 AM   #6687
Wayne1one's Avatar
Default front steering block plastic/graphite
Is anyone having problems with the front steering block breaking I have been running my car for a while, and if I dare hit, bump, touch something its guaranteed that the front steering block broke and the king pin is some where on the track. I have been through numerous SD-415 and king pins, other than not hitting anything any suggestions.
Wayne1one is offline   Reply With Quote
Old 01-11-2007, 08:36 AM   #6688
it sometimes happens to me that my car chrashes i n the wall at full speed but nothing ever broke
Old 01-11-2007, 09:40 AM   #6689
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
is the steering block actuall breaking for is the king pin striping out....
if the upper kingpini is pulling out, try part # sd-414kb ( king pin from the LCG) it has a more threads on it compard to part # sd-414k ( stander kingpin on the BD) you may have to grind off a few threads off
If the lower king pin is pulling out.. there is a newer king pin that used a spacer and a 3mm screw. part # sd-414TA ( i think but im not really postive, i have the part # at home)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 01-11-2007, 09:43 AM   #6690
This is the correct part number!! is the one with the titanium collar and screw!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
