Old 01-08-2007, 10:10 AM   #6661
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by Devon Racer
Im running 27t stock indoors with rubber cs 22/27 tyres using a one way front diff. I also have the Demon 3mm indoor chassis. At the moment my car is fitted with a front toe block with f0 printed on it, I would like to know what inboard toe out this is giving me ? Mr Jolly you might be able to answer that one as I now you run a demon chassis on yours. Can you tell me what block i should run with a one way and why ?
Also when i race away at the carpet thashnals the car is great, when I race at my local club (on carpet) with the same setup my car is pants. Every one at my club says its because our carpet has much more grip so I stiffened the car up, still not right, so I tried cs 27 tyres and again the car was not good. Any thoughts would be helpfull.
Well i`m not gary
But
F0 mean you have 0 kickup , the SD used to come with the F1 block (,eans 1 degree Kickup
So No outboard toe out for you ,you have parallell
i have f0.5 with a one-way fitted
you get more steering mid to exit with front inboard toe in ;
I can tell you now the Demon 3mm chassis doesn`t like low grip carpet ,if it`s dirty or having Foams races on it on the same night ,this doesn`t help either (Foam dust/powder left on track)
I have been using Russel williams setup from DMS 2 dayer to the `T` & so far so good (except low grip tracks) & demon chassis
front wheelbase by the way is 1+3 ,this is the same as the std chassis with the 1 mm shaved of front wishbones @back to shorten wheelbase (this works out 5+0
we still have .5mm thickers chassis & cells further forward ,so i don`t get to use full lock atall (80% rates i`m down too) about 18 degrees lock as opposed to 25 ish full lock
HTH
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-08-2007, 11:01 AM   #6662
Devon Racer's Avatar
[QUOTE=MR JOLLY]Well i`m not gary
But
Thanks for the help, when I look down on the front of my car it looks like it has a lot of inboard toe out as the wish bone hinge pins are not parallel. what would running inboard tow out do to the handling of my car with a one way. Also what difference would inboard toe in and parallel make to the handling so I can set the car for different tracks.
Thanks for any help you can give
Devon Racer is offline   Reply With Quote
Old 01-08-2007, 11:32 AM   #6663
H.Nilsson's Avatar
Originally Posted by conrod51
Can anyone advise where is the best place to mount an AMB personal transponder on the Yok BD. The instructions say not to have any carbon fibre or metal between the transponder and the track. How important is this as I know some people who mount their's on the steering servo.
In the bumber!
H.Nilsson is offline   Reply With Quote
Old 01-08-2007, 12:24 PM   #6664
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
do it like the Master (make a shelf out of lexan that extends past the servo)
if you want you can put a carbon-fiber sticker or just use black double side tape
http://www.overrc.com/courses/course...omomasami8.jpg
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 01-08-2007, 01:21 PM   #6665
Wayne1one's Avatar
Try on top of servo.
Wayne1one is offline   Reply With Quote
Old 01-08-2007, 01:44 PM   #6666
Wayne1one's Avatar
Originally Posted by JasonC
Rumor has it yokmo has releaed an alum spool, when confirmed i will post a pica and part #
I think you were referring to this one.
Old 01-08-2007, 01:54 PM   #6667
H.Nilsson's Avatar
Is that an LCG ore SDW car
I have an SDW butt i have only test it one day (10 acc)
Old 01-08-2007, 02:10 PM   #6668
Wayne1one's Avatar
Its the LCG.
Old 01-08-2007, 02:14 PM   #6669
Er, thats a diff.
Mounting the AMB PT on the servo is fine, but if you run a KO servo it is not advised. Best to mount it to a piece of lexan and hang it off the side of the servo.
Picture of Masamis car from worlds, he was running a diff in the back. It was a prototype of the BD500A aluminium diff halves available now. Standard kit chassis was used by the whole team at the worlds.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 01-08-2007, 02:16 PM   #6670
Inboard front toe in on the front gives more steering exiting the turn.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 01-08-2007, 03:02 PM   #6671
JasonC's Avatar
nope that is the diff, i forgot to pick up a alum spool when i went to Yokomo USA
Old 01-08-2007, 05:40 PM   #6672
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Originally Posted by H.Nilsson
Hallö I have also run SDW arms butt i like org. best
have you tested SD-300F05 and the new springs
i think they are more easy to drive with
I tested the front inner toe blocks. I just did it one time and it was OK but didn't improve my lap times so I went back. I am running indoors carpet right now and think that the blocks are not good for carpet. What springs are you talking about the white ones or something newer. If the white ones are what you are referring to, I use them almost exclusively(except carpet) orange paint up front and green paint rear most of the time with a spool outdoors.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 01-08-2007, 06:56 PM   #6673
Wayne1one's Avatar
my bad
Old 01-09-2007, 01:54 AM   #6674
Re mounting Personal Transponders; thanks for the replies and the suggestions. I think I'll probably hang it off the side of the servo which is what I had originally considered. My only concern with this is getting hit in that area by another car and risking damage to the Transponder. These things aren't cheap.
conrod51 is offline   Reply With Quote
Old 01-09-2007, 03:23 AM   #6675
Default Mounting PT
We have made a hole in the bumper for the PT. It is under the body mount brace (like in pic by H.Nilsson a few comments back). The wire is just long enough to reach the receiver.
We have not missed a lap in about 1,5 years when having this setup (about 20 races) and the PT is safe from being hit and also as far in the front as possible in case of finishing side by side with another car.
jarkko is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
