Old 12-28-2006, 04:50 PM   #6616
Question for Chris, Do you have a picture of the CGM steering bellcranks on your car that you could post???
Thanks Bryan
Bryan D is offline   Reply With Quote
Old 12-29-2006, 01:57 AM   #6617
can anyone please tell me what difference the 1.5 1.0 and 0.5 front toe blocks do
i know it is prob a silly question but hey got to learn somewhere
judge10tpt is offline   Reply With Quote
Old 12-29-2006, 03:10 AM   #6618
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
gives you more steering mid to exit
i have 0.5 on mine (that`s fine;;; i think the 1-1.5 will be to much for rubber but for Foams !!!
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 12-29-2006, 03:29 AM   #6619
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
indoors I use 0,5 with spool and 0 with oneway, but outdoors I use 1,5 :-)
Martin Hofer is offline   Reply With Quote
Old 12-29-2006, 03:40 AM   #6620
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
with the front toe blocks do you still set the wheels to O toe with the set-up gauges?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-29-2006, 03:45 AM   #6621
MR JOLLY's Avatar
yes
you only angling the wishbone , also this does reflect in the wheelbase aswell if you put 1.0 dgree block on more then likley that could be .5-1mm difference ,making it shorter wheelbase ,(wheel end)
Old 12-29-2006, 06:31 AM   #6622
VooDooPH's Avatar
great! thanks!
btw, this is only for running mod or will stock benefit from it as well?
Old 12-29-2006, 07:03 AM   #6623
on stock 0 are best indoors, as the more toe-out u run, the less your car will carry cornerspeed -> 0 carries most cornerspeed
Old 12-29-2006, 07:21 AM   #6624
MR JOLLY's Avatar
i`m a 27t lover & use 0.5 on my BD with one-way
19T Bit too fast
Mod for sure too bloody fast for my reactions
Old 12-29-2006, 08:51 AM   #6625
tantalus007's Avatar
Trader Rating: 17 (100%+)
hi guys... i just want to clear what ive read regarding the front toe blocks...
if i put a 1 deg front toe block... i still have to adjust my front tires toe to 0 deg... because in using the front toe blocks the angle of the wishbones is what were changing to achieve more mid to exit steering and not the angle of the tires... have i got the whole concept correctly???
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 12-29-2006, 09:25 AM   #6626
jup, completely correct
Old 12-29-2006, 10:20 AM   #6627
3rd-dan's Avatar
at my home racetrack, it´s a carpet track, i installed the 1.5 deg toe out block with one way and rubber tires and this worked pretty good.
and it s true the more toe out the less you have corner speed.
but it´s still fast enough for me...........
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 12-29-2006, 10:24 AM   #6628
in germany we have pretty large carpet tracks, so corner speed is the key thing.
on more technical tracks more toe-out may be better because you are able to hug the corners more.
Old 12-29-2006, 10:29 AM   #6629
thanks... i just hope that our lhs will have the alum teo-out blocks on stock soon
Old 12-30-2006, 12:07 PM   #6630
i tried the chris setup of rear toe hubs, went with 2.5 on the block and 1 on the hub. car was really easy to drive and very consistant. great turn in and the spool kept it planted on exit. (indoor asphalt/high bite)
Turtlemaster is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
