Yokomo MR4TC-BD
#6406
I saw people using them with no success.
I meant i just bought some standard ones and rounded the grub screw.
Its a bitch when you have bought something that should in theory be better and its not
#6407
Originally Posted by pheyhoe
I just gave up and bought a full new diff. lol.
The rings were molded into the outdrives too. The new one i built is nice and tight so it should not happen again
#6408
Did you run your diff in? I didnt have time and when i went out it was like drifting for half the race, even though off the ground the diff spun freely and was not slipping. :S
#6409
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
the screeching sound was quite often heard down in the lower ranks of driving
maybe properly adjusted diffs are the way to go
never had a problem even with the Diff Bolt that some have said about
#6410
I think the reason mine went is becasue i built the diff when i got the car, ran 19 all the time and about a year later i ran a 3.5 and thats why it ended up being a goey mess. :P The new one runs perfect now
#6411
Nah! original had about 8mins practise and died with about minute left of 1st heat-due to thinking 'that slippings ok'! was sliding everywhere before hand. new one i did right up and was fine all day and much better to drive. having jumped from stock to 4.5 i'm finding the transition a little difficult!don't generally drive with a one way either - had major issues slowing down for corners effectively!took over a second off my best lap throughout the day though so thats encouraging!
#6412
Originally Posted by jarkko
We have a problem with newly installed Yokomo hardened universals.
The thinner pin in the joint (rear wheel) keeps coming out al the time.
I wonder if other people have had the same happen.
Can anyone suggest a fix to this? I would hate to just discard new, rather expensive and hard to get parts.
#6413
#6414
Yeah that works well, but if when u build um up u just ,rive, on the grub as hard as u can u shud have no problems ther after.
#6415
I have a pair of Yokomo threaded body shocks which have the black plastic cap.
These shocks seem to have a different o-ring set up and also the pistons I have in my SD kit fit very loosely in the body (kinda like parking a bicycle in an airplane hanger).
Does any one know if these shock bodies require a different piston setup?
Also, on the YokomoUSA website in the setup sheets section, shock length is listed as 64mm/66mm F/R. Is this length measurement taken from the top of the upper eyelet to the bottom of the lower eyelet, or is it middle of hole to middle of hole?
#6416
Originally Posted by MR JOLLY
Are the Bomber shock towers worth getting (the one with loads of muti holes on )
#6417
Total shock length is overall i.e. include plastic above and below eyelets.
HTH
#6418
Originally Posted by lignum vitae
more adjustment is never a bad thing.
#6419
it is i`ll be even more confused
