Old 11-23-2006, 07:30 AM   #6361
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
The Rayspeed 3*1,2mm who are in the BD Masami Spec kit.
I use the Yoki pistons stock. If I'm right they have 0,8mm, but I ordere those rayspeed pistons without holes in them, so I can drill some myself.
I'm not saying the rayspeedpistons aren't good, but the holes of those I have are definately to big.
Martin Hofer is offline   Reply With Quote
Old 11-23-2006, 08:05 AM   #6362
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
@ Martin
in the uk drilling out to 1.1mm or putting rayspeed blacks in is really normal for the UK tracks
even indoors rubber/carpet is well used
different tracks, different drivers,different driving styles
every one is right
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-23-2006, 08:10 AM   #6363
In germany everybody uses the stock pistons, either mit 450wt Yokioil and stock holes or holes drilled to 1mm mit 450wt Yokioil.
I testes pistons a while ago and tamiya pistons (3*1,0) mit 60wt oil are pretty similar to what I run now.
Old 11-23-2006, 05:16 PM   #6364
MadBrushRacing's Avatar
If you use the Rayspeed pistons does the side with the grove face up or down in the shock? Not that i think it can make much of a diff, but they must be like this for a reason.
MadBrushRacing is offline   Reply With Quote
Old 11-24-2006, 11:52 AM   #6365
Racingbod85's Avatar
Hi all.Scuse the ignorance but when masami refers to -0.5 degree skid mount angle - does this mean the hinge pin is tilted towards the front or back? and please remind me what each does!see attached. also in that photo a while back he appears to be using the what many believe to be inferior SD roll bars rather than the rayspeed versions. any ideas why?
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 11-24-2006, 11:53 AM   #6366
whoops
RC12L4
Novak 4.5R / 10.5R
Old 11-24-2006, 11:56 AM   #6367
- = antidive -> front front mount lower than front rear mount (0,5mm)
Old 11-26-2006, 10:40 AM   #6368
Default Probelsm with one way
I am new to the BD and have had the following problems:
After about a dozen batteries the central one way failed completely. I replaced this. I was told to put a little bit of silicone grease in the one way to avoid this.
After about another 6 batteries the shaft that the one way rides on snapped at the point in the middle where the pin goes through it. It also appears to have damaged the one way bearing as part of this process.
Each time I have replaced it with a solid piece until I was able to get the spare.
Staring to wonder if I should just use a solid piece and change the dront one way as well.
Are these parts normally this fragile? We are only using a 27T motor on rubber tires so i cant imagine we are overloading these components.
Also does anyone have a good setup sheet for 27t on Asphalt?
Peter
aussieotto is offline   Reply With Quote
Old 11-26-2006, 11:31 AM   #6369
try to replace the axle with the hardened hollow shaft. this one works
but I mostly use a solid oneway in the middle.
Old 11-26-2006, 01:37 PM   #6370
lignum vitae's Avatar
yes the hollow shaft is much better quality, have seen a few std ones go but none of the hollow ones, even under intence mod conditions.Inox grease found at a good fishing tackle store is great for oneway.
lignum vitae is offline   Reply With Quote
Old 11-26-2006, 02:18 PM   #6371
crabboy's Avatar
Trader Rating: 58 (98%+)
Stay with the fixed centre pulley, no more problems.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-26-2006, 03:12 PM   #6372
Hey all,
Quick question, will the wishbones, part number SD008HW fit on the BD or are they just for the SD?
Just got myself a BD and I'm all new to these things
uvxt is offline   Reply With Quote
Old 11-26-2006, 05:29 PM   #6373
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
yes they willl work on the BD as well
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-27-2006, 12:59 AM   #6374
anyone know where i can get masami BD rear driveshafts thanks
Old 11-27-2006, 01:16 AM   #6375
curious mind's Avatar
hi guys, i have been driving a yok BD for about 4months now and have this centre 1way pulley. If ever i change to the locked centre pulley what will be the effect? What are the advantage and dis advantage of the lock pulley? Hope you can shed light on this for me. thanks.
curious mind is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
