Old 11-20-2006, 12:37 PM   #6346
Originally Posted by MR JOLLY
that`s nothing i am old
full lock on my BD is like 26 degrees on the setup gauges , when i go racing in 27t or 19t rubber/carpet & the grip comes up i start to click back the rates on me tranny & i`ll end up around the 80% rate on me 3PK which works out around 15-19 dgree on gauges ,i can still get round hairpins really well aswell
they are after more lock not more grip , coz i believe that you can have the wheel at to much angle it will scrub speed off !! a straighter wheel is a faster car
And like all real life racing cars they don`t have much lock & surely this equates to more corner speed
me perssonaly think if you need more lock to get round corners then your masking a badly setup car by asking the steering to give you all the lock to get round the corners
But if you have proper grip upfront then you don`t need full lock to get round ,this also looks after your tyre`s more because they are not scubbing across the top of the surface thus making them hotter & roughening the tyre suface up
agree 100%
Turtlemaster is offline   Reply With Quote
Old 11-20-2006, 01:13 PM   #6347
Send a message via AIM to aoizip
Orlando,
thats why you need to get a 12th scale... hehee!
the spring i gave you is 33ib man.... That is supposed to be for the front..
and you put it in the rear???? I will bring my BD to the track this weekend if my butt is not at killington over the break... <Winter is my snowboarding season >
~Ming
aoizip is offline   Reply With Quote
Old 11-20-2006, 02:55 PM   #6348
ATLAS COPCO's Avatar
Hi
Can someone help please
What pistons come on the tree and can you give me the sizes
ATLAS COPCO is offline   Reply With Quote
Old 11-20-2006, 03:02 PM   #6349
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Ming
were you looking at the car backwards...again
i put the corally on the front shocks, next time you can wear my glasses...
think I need to change to 2 hole pistons.
We'll go over it on Sat..bring your BD and well race them up to the A's
olhipster1 is offline   Reply With Quote
Old 11-20-2006, 06:01 PM   #6350
coons88's Avatar
Send a message via MSN to coons88
Originally Posted by asw7576
I hate to say this : the axle pin on yokomo CVD is easy to come off ? The pin occasionally ruin the steering knuckle and rear upright.....
I never know it until it already happened
( even I already super glue it ........ the pin will move someday somehow )
Get a heat gun and some 10-12mm heat shrink and cut it to about 3 or 4mm in width, slip it over the axel so that it covers the pin, and shrink it with the heat gun, hold the heat gun there for a long time (about a minute) so that it sticks there really tight, otherwise it will just slip off. Pin will never come out again, works so well that you can run it without the grub screw - though I wouldn't suggest to try!
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 11-21-2006, 12:35 AM   #6351
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by ATLAS COPCO
Hi
if you get yoko pistons ,just the 3 hole & drill out to 1.2 mm ,this is where the rayspeed pistons come in (white one) allready done & a straight fit
same as tamiya piston thye are 1.2mm holes aswell
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-21-2006, 06:59 AM   #6352
Holmenkollen's Avatar
I think the Tamiya piston have 0.9 mm holes in them.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 11-21-2006, 07:03 AM   #6353
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I use the yoki 3-hole pistons as they are.
the rayspeeds are definately to soft. the car losses so much traktion because of these pistons.
Martin Hofer is offline   Reply With Quote
Old 11-21-2006, 07:43 AM   #6354
S_fender's Avatar
Tamiya 3 holes have 1.1 mm holes.
S_fender is offline   Reply With Quote
Old 11-21-2006, 07:46 AM   #6355
my tamiya pistons do have 1mm
Old 11-21-2006, 09:14 AM   #6356
I second S_fender, Tamiya 3holes pistons have 1.1mm holes.
B-day is offline   Reply With Quote
Old 11-21-2006, 09:28 AM   #6357
MR JOLLY's Avatar
Oh Goody lots of chat over the size on tamiya pistons hole`s
In the Uk drilling out the std pistons to 1.1mm or putting rayspeed white in is the norm for outside asphalt stuff
Old 11-22-2006, 01:22 PM   #6358
lignum vitae's Avatar
martin you should try going up 10-15 weight oil to compensate, as yoki are moulded rayspeed are machined= much smoother and more accurate to set even.
lignum vitae is offline   Reply With Quote
Old 11-22-2006, 10:20 PM   #6359
I don't care about how the piston is made, I only care about how it performs.
And for typical european tracks the rayspeeds are simply not good. Way to soft. I needed 60WT Oil to get some damping in there. For this reason the yokis are much better.
Old 11-23-2006, 12:56 AM   #6360
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
martin which Rayspeed Piston are you refering to as "to soft" Yokomo part # RS-12 RS-13 RS-14 OR RS-17, i have found that the Rayspeed pistion are more consisten because they are a slightly larger outside diamiter, allowing for less " blow by"
If you insist on using the Stock 3 hole piston, you may want to try drilling out each hole with a #60 drill bit with yokomo 450 wt oil
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
