Old 11-18-2006, 03:08 AM   #6301
pheyhoe's Avatar
R/C Tech Charter Subscriber
I think masami has just used one servo post and servo taped the servo down. On my old SD i just use to use servo tape and nothing else.
Hes running rubber modified so the brace must be for more flex. Dont know about the purple ball studs :s they are different ball ends so i guess they fit better. Another thing. Look how much room he has because of the low profile servo. You could fit 3 reciever packs in that thing!
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 11-18-2006, 06:42 AM   #6302
Local racer's Avatar
Default Carpet Chassies
Thank you Darkside,alright guys that is a picture of the carpet chassies that we are working on,guys we are almost finished and I think this car will be a force on carpet.
http://www.tqracing.net
Local racer is offline   Reply With Quote
Old 11-18-2006, 07:49 AM   #6303
tcfree's Avatar
How much we looking at?
thanks.
tcfree is offline   Reply With Quote
Old 11-18-2006, 10:41 AM   #6304
pheyhoe's Avatar
Could somebody tell me the biggest spur gear that fits on the BD? i will remove the brace. i just want to know how far i can go without sticking out the bottom of the chassis..........
THANKS!
Old 11-18-2006, 11:04 AM   #6305
116 or 118. if I remember correctly I used the 116 WITH the brace. it sure was close, though.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 11-18-2006, 11:29 AM   #6306
hey guys im looking to get a new BD i run a LCG on carpet now! and its a rocket and hooks up well as i was reading a page back one guy said it was not good! i beg to differ i have a really stiff 3mm chassie and top deck on mine! if any of you would like i know a guy who makes them and it defanetly handles in the corners alot better! it transitions way smoother! and id stiffer then a T2 with bmi chassie! if you would like one feel free to pm he chargers $110 per chassie but if is high quality stuff.
But back to the main reason im on here! is im lloking to get another BD to run on carpet and was wondering if you think its worth it to go with the Masami ED or not? thanks for the input!
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 11-18-2006, 02:51 PM   #6307
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default My Very Good guess
The purple ball studs are to go with the BX ball joints ,these have holes in top so you put a 2mm hex driver in to change shims with out getting the pliers out to twist the ball cups off & then use the yokomo box wrench which seemed to be the only wrench that fits the yokomo ball studs
i have square racing ballstuds with a 2mm socket in top, so mine are allready done
learnt that from the tamiya evo 4 i had
i run 48dp & about 84 or 85 is the biggest on spur
HTH
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-18-2006, 02:53 PM   #6308
MR JOLLY's Avatar
is this aimed at the usa foam/carpet racing ??
Old 11-18-2006, 03:15 PM   #6309
BJ
HTH
The BX ball studs have the 2mm hex drive in them!! so why is using a purple one, looks like another HPI part
BJ is offline   Reply With Quote
Old 11-18-2006, 03:30 PM   #6310
MR JOLLY's Avatar
Default good question ,not sure
How long are the BX ball studs compared the std BD ??? (i don`t know)
if they are a little longer then they are no good r/centre changes , but if the HPI ones are the same length thye it`a straigth swap over with out r/centre change
down below is a rubber/carpet setup (russel williams use`s ,very fast UK driver in 27t/19t proberly mod aswell)
Dan Hughe`s posted this up on Team Japan (Wahooooo!! site)
This is the std BD car ,no fancy chassis or anything
PS;;russ won the DMS 2 Dayer & CAME SECOND @ c/wars 2 dayer all with in a week or two of each other using the preglued v-tech 24r as controlled tyre
Last edited by MR JOLLY; 11-19-2006 at 02:05 PM. Reason: Nathan wasen`t happy with info
Old 11-18-2006, 04:18 PM   #6311
pcar951's Avatar
Trader Rating: 19 (100%+)
Onroad Dude. You're right, I should clarify that my LCG carpet / foam tire experiment was with the stock chassis. It was just dumba$$ of me to think that I could make it work with that much flex.
On the other hand, my BD took the TQ and win last night at our club with only the Yokomo hard chassis and bomber top plate. I can imagine how good this car will be with Local Racer's 3mm chassis.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is online now   Reply With Quote
Old 11-18-2006, 06:03 PM   #6312
the bx hex drive ball stud and the std yok ball stud are the same height, i have a bx and the cups are a "loose" fit, i use rpm cups on the high impact stress points to keep them from popping off. those purple ones are probably hpi and have a snug fit.
Turtlemaster is offline   Reply With Quote
Old 11-19-2006, 10:50 AM   #6313
Midnight's Avatar
Trader Rating: 85 (100%+)
PS;;russ won the DMS 2 Dayer & c/wars 2 dayer all with in a week or two of each other using the preglued v-tech 24r as controlled tyre
Could you email that setup to me? I cant read it. Thanks
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 11-19-2006, 11:24 AM   #6314
Nathan Parker's Avatar
Nope Check your facts Colin
Nathan Parker is offline   Reply With Quote
Old 11-19-2006, 02:04 PM   #6315
MR JOLLY's Avatar
re adjusted Mr PERFECT
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
