Yokomo MR4TC-BD
#6241
anyone interested in a couple of sets of excel diffs
#6243
They new or like new?
complete diff or just the outdrives?
#6244
Guys carpet chassies coming out good,we will have pictures up soon also working on alum diff halves
#6245
cool Im interested!
#6247
Does anyone know what the purpose of these are? They look like something to keep dirt out of the diff. But in the picture they are on a spool by the looks if it, and it doesn't even look like a Yokomo spool/pulley. How would they attach?
http://www.precisionrc.com/nv/car/pr...duct_id=37075#
#6249
Don't buy one they are garbage. they don't work trust me..........
#6252
#6253
Originally Posted by biker
Can anyone point me in the direction of a good carpet rubber setup for the BD? We're running stock, with TakeOff CS-27 tires..
thanks
thanks
#6254
Ok, ran my BD on high grip carpet last night.
I would like a carpet setup using a spool and foams for a tight track? anything appreciated
I think i have the general stuff sorted. ie. springs, camber, toe, shock positiongs. I need the other nitty gritty stuff like droop, and the rest of it. What spacers should i be running under the suspension mounts?
#6255
pheyhoe:
I use 2mm up-travel for front and rear on the droop setting.
try to use a diff up front if you are running foams.
Short parallel link up front, and angled link or parallel link in the rear
for the rubber, one way is the way to go. droop setting on 5 front, 4 rear on the droop block.
I use the 2 degree plastic on rear.
hope this help
~Ming
hope this help
~Ming
