Old 10-28-2006, 12:34 AM   #6181
pcar951's Avatar
Trader Rating: 19 (100%+)
Default short arms??
Anybody know what the short arm conversion is for the BD. What's the purpose? Better for asphalt or carpet? Part numbers?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 10-28-2006, 11:34 AM   #6182
the short arms are for the extra wide show/drift rims. keeps the wheels under the body.
Turtlemaster is offline   Reply With Quote
Old 10-28-2006, 04:13 PM   #6183
tcfree's Avatar
Hi. The shorter SDW arms give the car more front end turn in. The best choice in all conditions asphalt or carpet 'in my view' Thay are the same as standard kit arm's but thay have been modified, thay are drilled in a way so when u mount the arm thay are shorter. Also u need 2 remove some of the plastic off them so that thay dont rub on the bulk heads, sounds funny but u will understand when u get some!
Try this link http://www.speedtechrc.com/store/ebp...id=419&id=4667 Thay are 1 front and 1 rear so u will need 2 get 2 packs! if u look close at that pic u will c that thay are drilled diffrent 2 make them shorter.
Hope this helps.
ste.
tcfree is offline   Reply With Quote
Old 10-28-2006, 11:40 PM   #6184
pcar951's Avatar
Thanks for the info again guys!
I'm kind of new to Yokomo and although my LCG carpet experiment was an abject failure (I was warned), I'm finding the BD to be a great and probably under-rated car. I ran our weekly club race (carpet-foam) last night with my new BD and finished 4th in the A, the rest of the field were all Xrays. Not bad at all for it's first time out!
Although I love my Xrays, I get a little tired of just being one of the flock. It seems to me that every car has a "sweet spot" set up that only needs to be deviated from slightly, from track to track to be competitive. I'm looking forward to finding out what the BD needs to be top of the heep!
Once again...thanks for the help.
Jim Chapman
Old 10-29-2006, 12:15 AM   #6185
oops my bad, thought you meant the rear arms, my bad.
Old 10-30-2006, 10:20 AM   #6186
hey guys! i have a LCG that i race but i keep haveing the small problem of snapping the diff bolt! i was wondering if any one knows where i can get a harder bolt one that might not snap so easy! thanks
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 10-30-2006, 04:20 PM   #6187
i used to snap diff screws also, just back it off about another 1/4 turn it should stop breaking.
anyone try the .5 - 1 degree rear uprights. i put a couple of .5's on and with the 2.0 block gives 3 degrees on each side, is there a different feel with the toe on the outside of the arm vs the inside.???
Old 10-30-2006, 06:16 PM   #6188
pheyhoe's Avatar
R/C Tech Charter Subscriber
I suppose it will be slightly different because when the the arm pivots it will be pivoting in a slightly different direction... But i could not tell you what change it would make
Also when you change the toe in through the inner block it shortens the wheel base... so i would take a guess at saying if you use toe in on the inner block it would make the car more "nimble" but less stable. but if you use the outer blocks it will be easier to drive.
This can be change by the spacers on the hinge pin anyway so i guess it just gives you a finer adjustment maybe?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 10-30-2006, 09:14 PM   #6189
Francis M.'s Avatar
i wonder if changing to a 1degree toe hubs with 2 degree block would make a narrower rear compared to 0 degree hub with 3 degree block?
ive been told it does feel different by a friend.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-30-2006, 09:40 PM   #6190
i never thought about it narrowing the car, gotta get me one of those setup board sheets and find out, like i said before with the 2.0 block and .5 hubs it has 3 degrees on each side. with the 1 degree hubs it must be 3.5 for 4 degrees. i may try it later, this weekend is our regional and don't want to change the car yet.
Old 10-31-2006, 01:37 AM   #6191
Racingbod85's Avatar
How about adding 2' and 0.5'. I think you'll find it makes 2.5' each side not 3'. very simple maths I know this cos grainger edition runs 2.5' block with .5' hubs = 3'
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 10-31-2006, 01:49 AM   #6192
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
front toe in SD-300F05 won`t fit on front end
F-0 std has the pin holes all the way through block
05 block can`t slide allway in to line up with the chassis holes as the pin holes are not all the way through
have i got to drill block to make fit
if yes ,then that is Bol*&cks
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-31-2006, 02:35 AM   #6193
Jolly
That's cos it goes at the back and replaces the split mounts.
No wonder you run stock.
Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 10-31-2006, 02:37 AM   #6194
Pillock - as Stu says goes behind bulkhead
RC12L4
Novak 4.5R / 10.5R
Old 10-31-2006, 03:30 AM   #6195
MR JOLLY's Avatar
Originally Posted by StuartC
Jolly
Stu
i` am old
stock
nope i`m moving up to 19t now ,kind of like it really
cheers Big Ears
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
