Old 10-26-2006, 11:34 AM   #6166
tcfree's Avatar
Originally Posted by pcar951
Ran the BD for the first time this eve on carpet with foams. Car was down 2/10ths from my T2 lap times early on but by the third pack it was right on par and getting faster. I'm running a front diff, the hard chassis, graphite suspension and decided to go with my LCG rear shock tower, blue springs up front and greens in the rear. Shock oil is 40 front 30 rear 3 hole 1mm pistons. Anybody have anything to add or change to this setup? The car is close already but I feel like there's more potential. Overall, it's freakin awesome so far!!
Hi depending on track layout/grip i can surgest 2 try a stiffer grade springs and a 1 way, even on tight tracks the 1 way is faster than diff 'in my view' it takes some getting use 2 but u can prolly be half a sec faster per lap with the 1way after a good practise!!
Ste.
tcfree is offline   Reply With Quote
Old 10-26-2006, 11:52 AM   #6167
Send a message via AIM to aoizip
running foams i would stick with diff up front.
my setup is a lot stiffer then yours.
AE purple spring front and rear.
60w front / 40 rear (two hole piston with holes enlarged a bit)
double deck (team bomber + standard screw together)
updated rear shock tower.
2mm up travel on both front and rear.
short camber link on both front and rear.
~Ming
aoizip is offline   Reply With Quote
Old 10-26-2006, 04:35 PM   #6168
are the longer shocks better or just different???
Turtlemaster is offline   Reply With Quote
Old 10-26-2006, 08:13 PM   #6169
pcar951's Avatar
Trader Rating: 19 (100%+)
Thanks for the advice! I have the bomber top deck on the way, I will try the one way then a little stiffer spring and damping as you have suggested. Need to carry a little more corner speed and eliminate a slight push on power. May try a little antisquat in the rear for more on power steering.
On the long shock issue....I was tempted to pull the short shocks from my LCG and put them in this new BD. I found that it's impossible to stand the shocks up too much on the BD as the longer ones really limit up travel. Wonder why Yokomo elected to go with longer shocks on this car?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy
pcar951 is offline   Reply With Quote
Old 10-26-2006, 08:19 PM   #6170
pcar951's Avatar
Originally Posted by Local racer
We are testing chassies as we speak we want this done right so it is going to take a little time.
Patiently waiting......sort of.
Jim Chapman
Old 10-26-2006, 09:20 PM   #6171
so far all my yoks came with the sss shock, i think that is the short one, and now came across some ss shocks the longer shock body one, the long shock should have more up travel.??
Old 10-26-2006, 10:21 PM   #6172
Default new part No?
Guys,
I THOUGHT, i have seen a new part from Yoke, which allows you to adjust the front track width.
It looked like a new hex adaptor with spacers,
But i have since not seen a part number or heard of anyone carrying them.
Has anyone seen a part number? please.
Simon
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 10-26-2006, 10:35 PM   #6173
Francis M.'s Avatar
Yok is offering a new wheel hex that will narrow the car by .5mm I think.
It also comes with shims so you could run the standard width.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-26-2006, 10:36 PM   #6174
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default been doing that for a while
the Mugen Seiki 1mm wheel spacer fit perfectly to widen track..and help fit foam tires on the car. Just a bit of a pain when taking off wheels...i forget they are on the hexes...and tend to misplace them.
but narrow hexes in the back would be great...especially for foam racing.
someone find that part number...
olhipster1 is offline   Reply With Quote
Old 10-26-2006, 11:11 PM   #6175
pcar951's Avatar
The shock shafts are completely retracted into the shock body before the chassis bottoms out even with the o-rings removed. The only answer is to lay them down a little. Lots of down travel though.....you could probably run 15mm+ ride height!
Jim Chapman
Old 10-27-2006, 11:39 AM   #6176
Midnight's Avatar
Trader Rating: 85 (100%+)
Default Shock
Does anyone know the diff in the chrome and gold shock shafts? Are they all the same length form sss to ss? and from front to back?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-27-2006, 12:03 PM   #6177
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by Bluey_74
Guys,
Simon
partnumber is ZS-011N
the r narrowing the front and/or rear by 1mm on each side.
I currently use the narrow hexes front and rear but I'm using a 1mm spacer in the rear. With this combination the car is unbelievable precise to drive, always doing what i want it to.
Found out that this car really needs the wing mounted far back, and I mean far back :-) On my mazda 6, I'm currently running the most, I'm only able to screw the wing down with only 1 screw cause of lack of material for a second one :-)
Btw. I'm running rubbertires on carpet with 3,5T brushless. The car is awesome and better than my T2 ever was. If someone s interestet in my setup just pm me or send me an e-mail
Martin Hofer is offline   Reply With Quote
Old 10-27-2006, 10:15 PM   #6178
Jochim_18's Avatar
Yap on MAZDA 6 body you want the wing as far back as possible, the car is much stable on straight line and it corners better.
Old 10-27-2006, 11:25 PM   #6179
Francis M.'s Avatar
they are the same lenght. the gold is ti nitride coated. Check your pm.
Old 10-27-2006, 11:41 PM   #6180
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
what up francis,
When you going to come run some carpet. Track will be open this sunday.Hope you can make it...
King of B Main is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
