Yokomo MR4TC-BD
#6091
I doubt that the little steering slop is what makes the car feel twitchy.
If anything the less slop on the steering system the more senstitive it will be.
I would play around with the ackerman or check the spacers in your c hub if you have it reversed it will make the car sensitive to steering input.
#6092
Originally Posted by Local racer
We are keeping evrything stock we are only playing with moving the batterys forward a small amount,this will give the car some needed turn in for the carpet.We are also considering a line of front sway bars desighned for carpet racing.
Since you are making parts, can you make steele or aluminum outdrives?
#6093
Originally Posted by BJ
Would it be posssible or has anyone fitting the TAM415MSX steering system to their BD's? I have done all the tricks to the BD system, CA around the flanged bearing and countersunk screw instead of buttonhead. But still have a lot of movement vertically which i think gives the car a twitchy feeling.
#6094
well i tried the cutting the motor mount and removing the blue support, not a good idea for me, i run on high bite asphalt and it was a hand full. didn't feel like chasing setup to fix it, (was also testing 13.5 brushless at same time). maybe i'll try to find the setup later this winter
#6096
Feel
Guys if you could shoot us some pms were trying to see how many chassies to run for our first order.
#6098
deleted
#6099
This is a 3mm BD chassis and top deck I purchased for my BD a couple of years ago. This set-up worked great on carpet.
#6100
i'm lucky in that i have a local carper track and indoor asphalt track so don't what to say yes make me one with out knowing the price first.
#6101
A picture of your work will help most of us to decide also.
~Ming
~Ming
#6103
Im interested too but would like to see pics first. I also would like to see the Batt position adjustable or a little more forward for carpet.
Also, Don't know if any of you chassis guys know it, if you move the batts a little forward, you should be able to move the batts in closer to centerline(Left to right)
