Old 09-20-2006, 10:43 AM   #5986
Originally Posted by MR JOLLY
Bad Batch !!!! Na i reckon coz they are plastic meself
Yeah...I was reachin'
DOTMAN is offline   Reply With Quote
Old 09-20-2006, 11:31 AM   #5987
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Personally I have never had a problem with the plastic spool, its lasted me for the entire national/outdoor season since april without a single fault.
That spools gonna have quite a price tag, even in yen thats expensive, once shipped.........who knows!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 09-20-2006, 11:52 AM   #5988
hi all. does anyone no of a shop in the uk that sell the delrin diffs 4 the yokomo bd??
thanks mark w
mwoods is offline   Reply With Quote
Old 09-20-2006, 12:05 PM   #5989
Ali Graham's Avatar
I don't think there is a UK distributor for Excel products
Old 09-20-2006, 02:00 PM   #5990
TheCoolCanFanMan's Avatar
Hi Guy's
As the doctor ordered well you racers anyway
I have now designed a CCF + which is a separate carbon fibre bracket that can be attached to your existing CCF, The fan can sit above or below the carbon fibre bracket and can be cut to the desired length when the desired position has been adopted. It will hang over the speedo to help keep it from over heating, this item is especially useful for the brushless speedo’s because of there thermal cut out. There will be different length screws along with different length carbon fibre stand-off collars. all for £19.99 of your Britsh pounds and will fit onto ALL CCF's except JRX-S
Cheer Malc THE CAN MAN
The car in the photo is Chris Kerswells, and its the first of its type.
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-22-2006, 05:18 PM   #5991
lignum vitae's Avatar
Originally Posted by Martin Hofer
I usually run 6/5 but sometimes when grip is low 5/4 oder 6/4 is better.
but 6/5 is my starting point
hi martin wondering what method you use to get those numbers.
lignum vitae is offline   Reply With Quote
Old 09-23-2006, 01:21 AM   #5992
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I use a Droop Gauge as for example Losis or the Yokomo one.
here is an example of how it's done
http://www.teamlosi.com/xxxs_page/xxxs_droop.htm
Martin Hofer is offline   Reply With Quote
Old 09-23-2006, 04:23 AM   #5993
thanks that is very clear,have you tried the David Jun droop method
Old 09-23-2006, 11:55 AM   #5994
No I didn't because in Germany everyone messures like I do.
We only run Rubber Tires so meassuring "xxmm above rideheigh" is not necessary.
Old 09-23-2006, 12:56 PM   #5995
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
david Junnw ay is measuring from the top of stub axles !!
take all wheels off ,put car chassis flat on pitboard & measure with a set a calipers
26mm= 6 droop on yok gauge do it both ways just to cross reference
24mm=4 on yoke
droop gauge
another way hold wheel down then pull chassis up,push ride gauge under & measure uptravel (to much farting around that way) so i do it Junn`s way first & double check yoke way after
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-23-2006, 08:09 PM   #5996
high wondering what shock length you run to get those numbers.thanks for your info.
Old 09-23-2006, 08:26 PM   #5997
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
i am able to get my droop to be the same as stated a few post back, with a shock length of 63mm, but you need to build the shocks with the triangel peice upside down with 1/2 of the shoulder removed
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 09-23-2006, 10:29 PM   #5998
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default top deck
Does anyone know if any shops in the states have the shooter or team bombers stiff Top decks in stock?
Is one more stiffer than the other.
Thanks Rctechers
OL>
olhipster1 is offline   Reply With Quote
Old 09-24-2006, 01:10 AM   #5999
my dampers are 63m in the front and 65,5 in the rear, both with the short end (with 65,5 I'm able to geht 3mm of Droop with the Masami Spec parts) with the original bd parts 63 should be enough.
Old 09-24-2006, 01:51 AM   #6000
lem2's Avatar
Thanks Rctechers
OL>
I got mine from speedtech RC. And yes it is stiffer.
lem2 is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
