Yokomo MR4TC-BD
Old 09-14-2006, 04:56 PM
  #5971
Originally Posted by jinkasama
is the masami has the two belt rollers? or its still comming.i saw the car of masami through a pic somewhere it has two bearing rollers. ..
No, that was just a custom addition for the Worlds.
v0rtex is offline
Old 09-18-2006, 04:14 AM
  #5972
fpart's Avatar
Trader Rating: 40 (100%+)
Talking WOW
I ran my BDM with the Pro4/HB front end this weekend at our final ORL2 race. It was awesome. I TQ'ed with almost a lap over the field. Screwed up in the main though and hit a plowdisk and broke my titaniumracing spool and some other parts.
The front end is a must if you want steering.
Has anyone had breakage problems with their spools as late and what front drive axles is everyone using?
fpart is offline
Old 09-18-2006, 08:11 AM
  #5973
Just got TiR HB axles and Yokomo bones. So i can run the HB bearings and dont need to shim the car excessively.
Dan Hughes is offline
Old 09-18-2006, 09:37 AM
  #5974
fpart's Avatar
Dan or anyone. Does anyone know where I can get a hold of a Ti/R front spool outdrive set delrin or aluminum(preferred)
fpart is offline
Old 09-18-2006, 09:42 AM
  #5975
asw7576's Avatar
Originally Posted by Martin Hofer
but i wouldn't use shorter than as it is recommended in the manual ...
would prefer adjusting the droop
I was using longer upper link ( 2nd hole count from outside ) and would like to go back to original setup printed in the manual ( 3rd hole count from outside ).
What about droop you are suggesting ?
asw7576 is offline
Old 09-18-2006, 09:44 AM
  #5976
If your in the states Schumacher distribute for you. I think you can order from their website too.
Old 09-18-2006, 09:48 AM
  #5977
Martin Hofer's Avatar
I usually run 6/5 but sometimes when grip is low 5/4 oder 6/4 is better.
but 6/5 is my starting point
Martin Hofer is offline
Old 09-18-2006, 09:59 AM
  #5978
Hi all,
I told you I'd report in when I had my TIR spool.
Well, drove it for a day yesterday and it is awesome. I drove it with the delrin outputs on a medium- high grip asphalt track and you cant even see any wear on it!!
The team Bomber spool I first had, I had to replace the blades on the axles every 2 batteries with some luck. Sometimes even 1/ battery -> 2.5!!!
You can order different/ replacement outputs from here: http://www.titaniumracing.com/sectio...=5_Spools.html
They shipped fast to me... (off course me being in Europe...)
Quante is offline
Old 09-18-2006, 06:17 PM
  #5979
JasonC's Avatar
Trader Rating: 120 (100%+)
just out of curiosity.... are you guys haveing problems running the plastic yokomo spool, i have used the yokomo spool, at both the reedy race and the ko-grand prix, and have hade no issues what so ever..
JasonC is offline
Old 09-18-2006, 08:54 PM
  #5980
Jochim_18's Avatar
I did have problem using yokomo plastic spool it keeps snapping on me in half during powering considering I only run 19T. I then switch to shooter spool works great. But now I just received my new delrin YOKOMO spool I haven't tried it yet, because as of now I went back running oneways works like a charm.
Jochim_18 is offline
Old 09-19-2006, 02:50 PM
  #5981
What actually do you mean with the term "front end", as english is not my mother tongue I do not understand such a word. Maybe you can explain it.
joamu is offline
Old 09-19-2006, 03:40 PM
  #5982
I found the Yok Plastic spool to be very fragile. If you are a very smooth driver who never makes a mistake, it will work for you. But it's not very forgiving for those of us who hit a few dots on occasion. I've snapped two in half. Both within the first minute of a race. I bought them both at the same time though. I suppose it is possible there was a bad batch
DOTMAN is offline
Old 09-19-2006, 11:36 PM
  #5983
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Bad Batch !!!! Na i reckon coz they are plastic meself
MR JOLLY is offline
Old 09-20-2006, 12:23 AM
  #5984
dont worry it's coming
G2B Anthony is offline
Old 09-20-2006, 03:41 AM
  #5985
fpart's Avatar
Front end is the PRO4 C hubs and knuckles(steering) along with hardware like ballstuds, bushings(steering), etc.
fpart is offline
