Yokomo MR4TC-BD
Old 09-13-2006, 06:26 PM
  #5956
Originally Posted by Jochim_18
If I where you I will just get the regular YOKOMO BD kit. And you can upgrade it to MASAMI spec if you want to.
More expensive to do it that way, by far.
v0rtex is offline
Old 09-13-2006, 07:22 PM
  #5957
i searched masami and found that it only sells 399$ and its on sale, so i guess its cheaper.
jinkasama is offline
Old 09-13-2006, 09:17 PM
  #5958
Martin Hofer's Avatar
Originally Posted by v0rtex
Masami kit is a standard BD with Ti screw set, bomber white belts, Graphite arms and C-hubs, ti-nitride shock shafts, precision yokomo bearings, hollow layshaft, new rear shock tower, 64pitch gears, yokomo progressive rate springs. Available worldwide.
No it is not. The Masami Kit has a different Chassi plate which makes it way stiffer ... now its comparable to an msx or an T2 on hard setting. So it is much better for carpet racing than the old BD was.
You can order only the plate to: BD-002MG
I don't know which plate is in the Grainger Kit ... BD-002 G, MG or GH?
Martin Hofer is offline
Old 09-13-2006, 09:33 PM
  #5959
Oh yeah I knew there was one hop-up I missed
v0rtex is offline
Old 09-13-2006, 11:37 PM
  #5960
lignum vitae's Avatar
not to mention the light weight drive shafts
lignum vitae is offline
Old 09-13-2006, 11:39 PM
  #5961
Oh and I missed the rayspeed shock bladders and o-rings.
v0rtex is offline
Old 09-13-2006, 11:54 PM
  #5962
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default Grainger edition
forgot these bit`s
Ti-screws
rayspeed piston`s
gold Ni-Tride shock shaft`s
Ti, Hinge pins retaining screws
Black art setup book
revised steering/castor blocks for UK tracks (sounds real tech,but really left a spacer out & added a couple of he`s own
fixed centre
carbide diff & thrust balls
trialing steering arms (0)
hardened front UJ`s
SD worlds rear drive set (blue)
hinge pin spacers in blue ali
have a left anything out
MR JOLLY is offline
Old 09-13-2006, 11:59 PM
  #5963
Aww why cant the Masami get those too...
v0rtex is offline
Old 09-14-2006, 12:12 AM
  #5964
asw7576's Avatar
Which one is better for hairpins and S corners :
Longer rear upper link or shorter rear upper link ?
asw7576 is offline
Old 09-14-2006, 04:00 AM
  #5965
crabboy's Avatar
Trader Rating: 58 (98%+)
Never got those parts with mine
crabboy is offline
Old 09-14-2006, 04:48 AM
  #5966
depends an what you need. If you need a more stable rear end the long upper link is your way to go. If you need a bit more steering the shorter one should be better
Old 09-14-2006, 12:28 PM
  #5967
Ali G
YGPM
adyb is offline
Old 09-14-2006, 01:22 PM
  #5968
asw7576's Avatar
Shorter upper link turn quicker ?
hhhmmm..... I need that.
asw7576 is offline
Old 09-14-2006, 01:25 PM
  #5969
but i wouldn't use shorter than as it is recommended in the manual ...
would prefer adjusting the droop
Old 09-14-2006, 04:53 PM
  #5970
is the masami has the two belt rollers? or its still comming.i saw the car of masami through a pic somewhere it has two bearing rollers. .. the grainger edition is sweet. i wish i can get a hold of one.with out spending more since its GBP conversion
