Old 09-09-2006, 12:41 PM   #5941
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
think the new arm sweep block is really good idea ,
nice upgrade to have & also simple to do ,which is what it`s all about
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-09-2006, 12:56 PM   #5942
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
I wish I knew where I can get some of those new sweep front suspension mounts.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 09-09-2006, 01:01 PM   #5943
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
fpart: I got mine from rc-champ, I look forward to trying them. Most Asian based shops should have them now, I don't think they've travelled too far yet.
pops: possibly to get more oil under the piston= more traction? Maybe an additional idea to acheieve more than just cutting the triangle piece and inverting it Maybe also for more ride height without fiddling with shock lengths/innards.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 09-09-2006, 01:06 PM   #5944
fpart's Avatar
Ali, I sent and email to RC-Champ and he told me that he was out of stock on them and that they should be back in stock soon. This was 3 weeks ago. Still no response from him.
スクービーは私のヒーローです!
Old 09-09-2006, 01:39 PM   #5945
New shocks negate the need for the triangle piece. Basically makes them exactly the same as Tamiya shocks, they are longer because of this 63.5mm is the minimum size you can get them down to.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 09-09-2006, 02:13 PM   #5946
Check the Yokomo Japan site, they update when they get stock of items in. all but the part numbers are readyable but the rest is in japanese. I believe there was a production problem with the mounts as some were not straight. The ones i have seem fine and will be using them on the car tomorrow.
Dan Hughes is offline   Reply With Quote
Old 09-10-2006, 02:08 AM   #5947
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I use the Onboard Toe-Out blocks since half a month now.
I think they are really good.
They achieved exactly what I was expecting. More precise, more steering, especially during entering the corner, it also felt like having more steering through sweepers.
Which brought even more was the HB frontend. Steering everywhere I need it :-)
And maybee a tip to those people having problems with the diff.
Use a tamiya thrust bearing without the brass inner part, so it fits on the Yoki screw.
When racing my 8Ts I always had to reassamble my Diff after every pack. But now with the Tamiyaparts in it, I have driven it for 13 packs now and it spinns totally free, locks fully and is like freshly built.
Hope this helps some people here.
Martin.
Martin Hofer is offline   Reply With Quote
Old 09-10-2006, 04:36 AM   #5948
MR JOLLY's Avatar
Microtechracing have the new sweep block`s instore
re;;shocks
does this mean tamiya had the right design so long ago now HB & yoke,schu have copied them
properly why so many peeps put the tamiya shocks on
good enough for D spashett good enough for me
my tamiya shocks on the evo 5 are 62mm was thinking of changing over then thought ,hey not much wrong with the `lovely` yoko shocks any way`s
Old 09-10-2006, 02:12 PM   #5949
Default Masami BD chassis & standard chassis (Help please)
does anybody know what the difference between the masami chassis and the standard BD chassis also where’s the cheapest place to by a chassis in the uk.
cheers
yoko is offline   Reply With Quote
Old 09-10-2006, 02:33 PM   #5950
same thickness (no additional weight) but a different Cf which makes it much stiffer than the original BD plate.
Old 09-10-2006, 06:04 PM   #5951
fpart's Avatar
Mr. Jolly, Thanks i just ordered two of them!!
スクービーは私のヒーローです!
Old 09-13-2006, 06:17 PM   #5952
hi which is better grainger kit or misami and whats the difference?? i really wanted to buy a yokomo ... thanx hoping for your input guys
jinkasama is offline   Reply With Quote
Old 09-13-2006, 06:29 PM   #5953
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Masami kit is a standard BD with Ti screw set, bomber white belts, Graphite arms and C-hubs, ti-nitride shock shafts, precision yokomo bearings, hollow layshaft, new rear shock tower, 64pitch gears, yokomo progressive rate springs. Available worldwide.
Grainger kit is a standard BD with a front spool, black belts, green rayspeed springs F&R, SDW front arms and building tips from Grainger. Only available in the UK via CML.
The Masami kit is great, and probably the easiest to get outside the UK.
v0rtex is offline   Reply With Quote
Old 09-13-2006, 06:48 PM   #5954
i just checked the web for those two cars. and, your right all the search for the grainger edition is only based on uk and their price is so expensive to convert to dollar.. while masami is a bit cheaper... and is that the latest right?( the masami editioin) thanx i might try to look for one...
Old 09-13-2006, 06:58 PM   #5955
Jochim_18's Avatar
If I where you I will just get the regular YOKOMO BD kit. And you can upgrade it to MASAMI spec if you want to.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
