Old 09-02-2006, 09:58 PM   #5911
Greg M's Avatar
I ran my Novak GTB and 4.5 in my BD for the first time today. Talk about power, it was awesome. One problem I'm having is ripping the inside of the diff pulley to bits. I did this in practice and the last race of the day. The pulley is disintergrating where the diff balls go which is the weakest point. Has anyone else had this sort of problem? Maybe an alloy diff pulley is needed?
Greg M is offline   Reply With Quote
Old 09-03-2006, 06:15 PM   #5912
MadBrushRacing's Avatar
Does anyone have a link where I can find the manual to download?
Tony
MadBrushRacing is offline   Reply With Quote
Old 09-04-2006, 12:06 AM   #5913
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Tony
http://www.petitrc.com/reglages/yoko...omoMR4TCBD.htm
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-04-2006, 12:24 AM   #5914
VooDooPH's Avatar
anyone know of replacement alternatives for the kingpin collar that goes under the knuckle arm in the c-hub? kinda lost one of mine in a crash. but since i'm using the team suzuki aluminum knuckle arms, i find it a waste of money to get new knuckle arms just for the collars.
thanks!
note: tried looking for the Yok aluminum aftermarket ones but they're not available here locally.
Old 09-04-2006, 12:35 AM   #5915
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Ti kingpin inserts will do the job, with a button head screw rather than a regular kingpin.
v0rtex is offline   Reply With Quote
Old 09-04-2006, 01:00 AM   #5916
VooDooPH's Avatar
sorry for being such a noob but what do those look like?
thanks!
Old 09-04-2006, 01:28 PM   #5917
You have something wrong with the way you built your diff. We run 7 singles and never have a problem. Maybe you have the diff too loose?
pops is offline   Reply With Quote
Old 09-04-2006, 01:42 PM   #5918
thanks!
Were these the ones?
The Lightweight ones are the best, don't have a picture, but it is a sleave with a Ti screw and it works the best. The spacer and sleave are one piece. Part number SD-414TA
Old 09-04-2006, 02:18 PM   #5919
Greg M's Avatar
The first pulley showed no sign of excess heat, but looking at the 2nd one last night I can see that there are signs of the plastic melting. It was set pretty tight, but not tight enough obviously. I'll crank it up abit more when I put the car back together tonight. Any tips on telling how tight to make the diff? I thought I had it pretty tight where I didn't think there would be much diff action. If I tighten it much more, I wonder if it would be worth running a solid axle.
Old 09-05-2006, 04:02 AM   #5920
VooDooPH's Avatar
yup. been looking for those... couldn't find them here locally.
Old 09-05-2006, 04:58 AM   #5921
pheyhoe's Avatar
R/C Tech Charter Subscriber
I assume its the front diff then. What surface you running on?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 09-05-2006, 07:36 AM   #5922
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
these are very good used these to replace the black shouldered kingpin varity
just a better fit into the steering knuckle
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-05-2006, 10:50 AM   #5923
Yep, too loose. If you look at the instruction manual when you assemble the diff you will see a tip on how to make sure the diff is tight. With a couple of allen wrenches you hold the outdrives and try an rotate the pulley. That is a good strart. After you install the diff in the rear, I hold the LR tire in my left hand and with my left thumb I press hard on the spur gear. With my right hand I try and turn the right tire. You should not be able to either turn it or at least be very difficult to turn. You can over tighten the rear diff and that will make the diff feel very gritty and eventually make the diff screw snap. For a front diff I put the rear tires between my knees and rotate the front tires it should make the belts click on the pulley if it is tight. But running a spool is faster on asphalt, but a front diff is better on carpet with foams.
Old 09-05-2006, 12:00 PM   #5924
Aha, I read something about a spool... time to ask something about it.
I'm driving a with 4.5r motor on asphalt. Griplevel is medium to high.
What is the best spool out there???
I have the Team Bomber one and I'm very displeased with it. I bought it cause it required blades and I thought, nice touch, replace the blades, keep the spool alive.
Well, I'm going through blades at a rate of 1 pair on 2 batteries (NOT KIDDING). I'm a person who goes pretty soft on the throttle so that definately isnt the problem. -> these are expensive batteries at this rate!!
I now ordered the one from Titanium racing cause its thye one that comes with the grainger kit. Also ordered both types of outdrives and I wanna see what works out best.
Are there other spools better for the BD??
Quante is offline   Reply With Quote
Old 09-05-2006, 12:13 PM   #5925
Send a message via AIM to aoizip
Quante:
if you don't mind the extra weight, then you can use the steel spool from speedtechrc...
~Ming
aoizip is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
