Old 08-22-2006, 02:28 AM   #5866
lignum vitae's Avatar
Originally Posted by VooDooPH
hi there. new to the thread. just got a 2nd hand unit off a friend.
anyway, was looking for set-up sheets, was wondering if anyone could point me to some (asphalt racing) that are in english? so far all i've seen is the Masamai set-up sheet but its for carpet. the ones at the yok jap site are in japanese and i can't understand anything.
thanks!
btw, are the belts from the MSX, Cyclone and BD interchangable? cars look like they have very similar layouts...
another question... will the yokomo LCG front dogbones fot the BD?
try cml distribution ltd for setup belts not interchangeable
lignum vitae is offline   Reply With Quote
Old 08-22-2006, 04:07 AM   #5867
coons88's Avatar
Send a message via MSN to coons88
Not sure about Cyclone belts, but MSX belts have about 8-10 teeth less than BD belts
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 08-22-2006, 05:21 AM   #5868
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Originally Posted by Dan Hughes
I havnt made the decision yet. Im working on some other parts that i will test asap but its finding the time to design the parts and finding someone who has a CNC machine.
IM interested, if you make them!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 08-22-2006, 03:14 PM   #5869
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Need more steering!!!
A couple of my friends have been running the Yokomo BD's for a about 3 weeks now. We run on outside asphalt track, mixed, hot weather, running CS-27 tires, and NOvak 4.5R. They seem to be having a lot of understerring pblms on corner entry and corner exit. They have tried all kinds of things and the car is still not working as they'd like. Anyone know of a good set-up for asphalt track, hot weather, rubber tires, low to mid traction? Also please give us some set up tips to give the car the most steering possible for LOW-MED traction outdoor asphalt track. He is currently using a one way and diff, and has tried lots of things, but none seems to help, to the point they're thinking of selling the cars and getting Cyclones or something else- I have assured them that the car will work, but they need to work on their set up- there must be something wrong they have not looked at. Please help me hlep them, as the cars are awesome and I'm sure it too can have lots of steering if set up correctly. So please...what set ups do you recommend to get the car more steering up front?
yyhayyim is offline   Reply With Quote
Old 08-22-2006, 03:22 PM   #5870
Post there current setups and then we can help better, theres a million different ways to get more steering.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 08-22-2006, 04:17 PM   #5871
yyhayyim's Avatar
Here is the current set-up they have running on asphalt track, low-med traction, rubber tires, mixed.
Drive train: one way, front, ball diff in rear.
Anti-Roll Bars: none
Steering block: 1 Deg offset in front,
Hub Carrier: 0 Deg in rear
Camber: F- 1.5 Deg, R- 2.0
Toe: F- toe out 1 deg, R- 2.0 toe in
Droop: F-4 , R- 4
Suspension Arm Position: Front:F-4mm, R-0mm; Rear: F-2mm, R-2mm
Shocks: F&R SSS body, short, 62mm
Oil: F&R 30wt
Springs: F-White, R-Stock blue
Pistons: F&R, 2 hole
Bump Stop: F-1, R-1
Shock Tower Position: F-2 hole, R-3 hole
Camber links: Front: 1mm under ball stud in inner link on bulk head; REAR: none under ballstud on inner camber link on bulkhead.
Upper Camber link: F-2nd hole, R- 2nd hole
A-Arm shock position: F- middle hole, R- inner most hole
Ride Height: F- 5.5mm, R-5.5mm
Old 08-22-2006, 05:15 PM   #5872
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Sounds like its close to kit setup to me with the exception of rear toe & wheelbase.
Try softer front springs, harder rear springs, kit rear sway bar and go in one hole on the front shock tower. Those are the obivious initial things you can try. After that you can try SDW front arms too. Obviously only change one thing at a time.
If the weather is hot and tires are open, you could go to a harder compound of tire all around - something like a CS32. How old are the tires they're using? CS27s tend to drop off after 6 or 8 runs in Mod..
Also, how experienced are they with high powered motors? It could be the fact that they're simply trying to drive them too fast and causing understeer.
v0rtex is offline   Reply With Quote
Old 08-22-2006, 06:09 PM   #5873
yyhayyim's Avatar
Vortex! Thanks for your input. Will give them a try and report back. The CS27's are worn but good enough to try out settings and get car dialed. And what are the SDW arms?
Old 08-22-2006, 06:11 PM   #5874
SDW arms are the front arms from the old(now) Shaft Drive Worlds car which are slightly narrower than the regular BD arms. They provide more steering than the regular arms because of the narrower track width at the front.
Old 08-22-2006, 07:52 PM   #5875
Send a message via AIM to aoizip
or you can try:
yellow spring in the front, blue or white in the rear.
3 hole piston with 40wt front, 35 rear.
0.5 ~ 0 front toe.
move front shock toward inside.
move rear shock all the way to the outside last hole.
silver sway bar front, none in rear
Suspension Arm Position: Front:F-4mm, R-0mm; Rear: F-4mm, R-0mm.
move the link to the 1st hole on the steering plate.
change your tire to semi use.. sometimes worn out tire has little grip left.
this is like my spool setup.. oneway.. I just suck at it!
~Ming
aoizip is offline   Reply With Quote
Old 08-23-2006, 01:07 AM   #5876
Remember
Tire, Insert, Bodies, Springs have the biggest effect on car steering.
Pls try Sorex36r, 039M insert, Protoform M6 body, F/R HPI silver spring. Other setting just fine tune to suitable your driving style. Hope this help.
G2B Anthony is offline   Reply With Quote
Old 08-23-2006, 11:15 AM   #5877
What is the steering position on the ackerman plate?
Dan Hughes is offline   Reply With Quote
Old 08-23-2006, 07:58 PM   #5878
The first hole in front
Old 08-23-2006, 10:26 PM   #5879
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
noticed a but of upward play on the steerng posts. is this normal?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-23-2006, 10:48 PM   #5880
yes, but you can shim it out. The manual specifies putting some spacers in there on top of the top bearing so it has less slop.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
