Old 08-03-2006, 01:31 PM   #5821
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Evicerator
Ron,
Has anyone ever told you that your little South Park charicature guy makes you look like a total bad a$$?
He looks ready to tear up some 19T competition!!
humm better do something bout that then................... maybe i should move up to mod then
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 08-03-2006, 01:57 PM   #5822
Originally Posted by rocketron
the post your referring to is mis-leading in that question is not about the stock rear front brace BUT using the alternate piece that was intended for the front rear brace being used as the rear front brace. This induces some degree of toe... not having tried it i don't know how much either
I have switched over and did not measure the toe after the change. But as I remember it was pretty close to one degree. I had to re-adjust the front toe a little after. You got to try it Ron, it seems to help with the steering quite a bit, car is much more planted.
pops is offline   Reply With Quote
Old 08-03-2006, 02:21 PM   #5823
rocketron's Avatar
your right about trying it but actually have more steering than really needed at the moment. remember i have the ackerman plate, and also been using 2 degree C-hubs. the new pieces should be arriving soon now too. i have also used the F+1 plastic brace (i believe from the SD) cut down to give some toe.
been racing and doing alright..... can not wait until carpet season though
Old 08-03-2006, 02:29 PM   #5824
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
OK im confused but then agian that does not take much lol
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 08-03-2006, 02:39 PM   #5825
What are you using for 2 deg c hubs?
Word is that Stockton might be going to go to Rubber Tires. Too many complaints about foam tires. Expense, chunking blah, blah. I really liked it when we ran rubber, it was more fun then.
Old 08-03-2006, 02:50 PM   #5826
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
The BD is absolutely planted on carpet with rubbers
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 08-03-2006, 04:00 PM   #5827
yokomo BD's Avatar
hi, do yokomo have a two deg caster blocks for the BD? thanks..
yokomo BD is offline   Reply With Quote
Old 08-04-2006, 05:55 PM   #5828
lignum vitae's Avatar
Hi spotted some bdm setup sheets on yokomo japan web wondering if anyone has translated copys
lignum vitae is offline   Reply With Quote
Old 08-07-2006, 07:18 PM   #5829
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Looks like the new narrow clamping hexes for adjusting the front track width have been released: http://www.teamyokomo.com/japan/newp...s2006_7_en.htm
Part number: ZC-011N
v0rtex is offline   Reply With Quote
Old 08-08-2006, 08:46 AM   #5830
Francis M.'s Avatar
I think the kit comes with 4 deg caster block but you can buy and optional 2 deg block.
Francis M. is offline   Reply With Quote
Old 08-08-2006, 08:47 AM   #5831
Francis M.'s Avatar
Does anyone know What type of cvd masami was using at the worlds?
Old 08-08-2006, 10:36 AM   #5832
Ali Graham's Avatar
TiR (titanium racing) CVDs, although on the rear it appears he's used a std front driveshaft stub axle so that he can use the new rear hubs that are a lot thinner than the stds, meaning a shorter stub axle is needed.
Old 08-08-2006, 08:48 PM   #5833
so many changes, so many new parts, hows a guy to keep up,
i've been away from my bd for too long, took a month off from on road to get ready for off road nats with the yok bx, car was great,, i sucked, to much time away from off road, made the sdw arm change with the yok spool a month ago, and finally ran it it last weekend, i liked it alot, car was amazing. if you haven't tried it you should. but now all these new parts, and changes, i guess i better pay attention. lol
Turtlemaster is offline   Reply With Quote
Old 08-12-2006, 03:09 AM   #5834
Hi all, Bought a BD a few weeks ago and I'm very pleased with it, great car and handles better as my previous RDX.
I bought the car 2nd hand (in mint condition :-) ) but it came with 2 diffs, on the smaller tracks I'm just as fast as with a one-way, but I miss a lot on on power steering out of the corner.
Asked a shop what to buy best, spool or one way and they told me most drive spool... so the TB spool is on its way.
The question is, what kind of setup changes can I expect?? maybe (prolly) more drag brake I presume...
What kind of extra wear will the spool cause me?
Greetz
Dirk
Quante is offline   Reply With Quote
Old 08-12-2006, 03:55 AM   #5835
coons88's Avatar
Send a message via MSN to coons88
Hi, Hopefully someone can give me a quick reply here.
Does anyone know if the BD steering posts #BD-200P are the same as either the LCG #SD-202LPL or the SDW #SD-200LW posts?
They look the same as the SDW ones, but not too sure.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
