Old 07-28-2006, 09:18 PM   #5776
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
pinggoy... when you assembly go to assemby the off road kingpin on the BD caster blocks you will see that the alum sleef that comes with the off road king pin will stick up out of the caster block, just use a dreml with a sanding drum, ( i just left the sleeve in the caster block and grinded away un-till it is flush with the casterblock)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 07-28-2006, 11:10 PM   #5777
Originally Posted by speedy-932
Hi,
the ackermann effect is one of the most interesting and most complicated things (right behind camber changes in the corner during damper action).
To keep it simple:
The inside tire should always be more angled then the outside tire. This is because the inside tire has to turn a much smaller turning diameter around the corner, while the outside tire doesn't need that much steering lock as the diameter of its turning circle is quite bigger.
I hope it's understandable... If not, please ask and I'll try to explain it in a different way.
@BJ: As the new C-Hubs and steering knuckle allow more steering throw the mounting holes on the steering knuckles are further forward to prevent wobbling at maximum steering throw. To keep the ackermann effect the same the holes have to be further forward aswell.
Cheers
Chris
thanks that is what i was trying to say. but what this about new c-hubs and steering knuckles????
Turtlemaster is offline   Reply With Quote
Old 07-29-2006, 12:46 AM   #5778
Hi,
the new suspension parts (rear hubs aswell) were tested by Team Yokomo before and during the Worlds. I don't know the reason for the rear hubs but the C-Hubs and steering knuckles are designed to achieve more steering throw.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 07-29-2006, 12:31 PM   #5779
kawada's Avatar
New stuff from Team Bomber front spool
kawada is offline   Reply With Quote
Old 07-29-2006, 01:31 PM   #5780
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
thanx for the reply jason
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 07-29-2006, 04:24 PM   #5781
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
What are the small black things to the right? Are they plastic blades like the ones on Xray cars?
v0rtex is offline   Reply With Quote
Old 07-30-2006, 02:05 AM   #5782
JasonC's Avatar
yes vortex i belive so
Old 07-30-2006, 04:06 AM   #5783
coons88's Avatar
Send a message via MSN to coons88
Yay, blades I have to get me one of them, no more wearing in the outdrives!
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 07-30-2006, 01:28 PM   #5784
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Camber Location on front C-Hub: Got the car 2nd Hand and the car uses the King-Pin ballstud as the outside location for the camber link. Does anyone run the locations on the rear of the C-Hub? If so what handling characteristics are you looking to get from doing so?
Thanks.
Jeff
Jeff Werner is offline   Reply With Quote
Old 07-30-2006, 02:45 PM   #5785
Can anyone tell me what colour Rayspeed springs come as standard with the Masami BD edition, as i'm currently looking at buying one? Also what springs are most people using outside on asphalt, bearing in mind im using the HPI silver springs at the minute.
Thanks in advance
rosey is offline   Reply With Quote
Old 07-30-2006, 03:01 PM   #5786
JasonC's Avatar
the BD-M comes with the new white spings ( they have just a touch of color at the end of the coil for id)
part # YS-1565L Pink in the rear
part #YS-1560 Orange in the front
Old 07-30-2006, 03:29 PM   #5787
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
I'd say the orange springs are the equivelent to HPI whites and the pinks are the same as HPI pinks
We have been testing the Rayspeed springs in equivelent to the new white progressive ones. Basically, the progressives gave more grip. Great outdoors, but I reckon indoors HPI springs are a lot better for indoor racing as they are slightly less progressive and will help to prveent grip roll.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 07-30-2006, 03:38 PM   #5788
The new white springs are all progressive rate springs.
Why do people compare the Yokomo springs to the HPI springs? What are the differences? If you dont know the rates of the HPI springs, its a pretty useless comparison...
Old 07-30-2006, 03:55 PM   #5789
With my testing so far I have found they have a soft initial feel on corner entry but as they stiffen up at mid corner they really give the feeling of the car 'freeing' itself up - seemed to me to keep the corner speeds up. I cant wait to do more testing with these springs.
Old 07-30-2006, 07:33 PM   #5790
BringItOn's Avatar
Thanks.
Jeff
hi
i lost the king pin ball stud on the steering block. and hard to get a hold of...
so i tried a ball stud on the castor block (middle hole), and i found it had no steering at all. (but i didnt have the shims to raise the camber link)
i am going to try raise it to the position as it would be if it was on the steering knukle and see what happens again....
BringItOn is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
