Old 07-18-2006, 06:29 AM   #5716
Hi,
the new suspension mounts are designed to give in-board toe-out.
They will be available in 0.5, 1 and 1.5 degree.
According to the only person I know that is able to read japanese the new wheel hexes are 1mm narrower per side and come with 0.5 and 1mm shims.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 07-18-2006, 09:25 AM   #5717
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Wanted to check that I am doing things correct....lol I got the One Piece RF "R" mount and took off 1mm from the bottom. When I put it on the car the belt will run on top or over the face of the mount correct? There was no room for the belt to travel under the mount.
Is the new release mount shown on Yokomo's home site the one to do this very thing?
Jeff
Jeff Werner is offline   Reply With Quote
Old 07-18-2006, 09:39 AM   #5718
Originally Posted by Ralf
Hi,
In despite of this impressive armada, at the beginning of the first qualification leg Masami's motor was soldered with reverse polarity and Yokomo team have urgently turned the endbell to let Masami run but it results with a shorter wire that came unsoldered during the leg and Masami did not finish..
therre is a wise saying .... "too many cooks...."
Berkky is offline   Reply With Quote
Old 07-18-2006, 10:01 AM   #5719
Francis M.'s Avatar
Jeff
yes.
Francis M. is offline   Reply With Quote
Old 07-18-2006, 10:12 AM   #5720
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
whats the part number for the new part?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 07-18-2006, 11:04 AM   #5721
Originally Posted by coons88
Here are some really good pictures of Masami's BDM from the worlds. You can see all the new parts. Click the pictures to enlarge them.
http://www.rcinfos.com/2006/2006_07_...omo_masami.php
Can anyone translate that
I notice the front has differnt wheel hex things to the normal ones on the rear The wheel nuts are also weird.
You can translate that if you have google. Just Right click the page and a box will apear. Just click on translate this page into english.
pops is offline   Reply With Quote
Old 07-18-2006, 11:17 AM   #5722
Francis M.'s Avatar
The reason I want to get the toe out block is so that i can get more
steering travel. I'm sure it does something else but more than any thing
i just want a little bit more wheel lock.
Old 07-18-2006, 11:23 AM   #5723
Hi,
then wait for the new suspension parts... Like all of us...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 07-18-2006, 02:59 PM   #5724
Francis M.'s Avatar
Originally Posted by speedy-932
Hi,
Cheers
Chris
That's the hardest part. Its better than grinding the rear /f mounts
Old 07-18-2006, 04:36 PM   #5725
I think I did it in about 15 to 20 minutes watching TV.
Old 07-18-2006, 06:11 PM   #5726
Jochim_18's Avatar
You can tell to one of those pix that the chassis is pocketed down right where the motor sits. hmmmm..... does this mean MASAMI also uses a different chassis?
Old 07-18-2006, 09:47 PM   #5727
What will the new in-board toe-out mount do? Is it design for the front or the rear? Or it just like using the "R" block instead of the "F" block infront but with adjustable angle?
If using the 1deg block in the rear, does it mean the total toe-out will be 4deg if using together with the standard 3 deg rear block?
MARKANO is offline   Reply With Quote
Old 07-18-2006, 10:26 PM   #5728
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
is that chub thats on the pic. already released? and what is the part no.?
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 07-19-2006, 03:37 AM   #5729
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Jochim_18- I think that chassis work is the result of a dremel or some other device, I believe it is a std chassis but with that area removed, he also used this chassis at the JMRCA Mod National. The chassis gets very, very thin where the motor sits, I believed it to be less than a mm when I saw one of the ones used!!!!!
pingboy- no they are not released yet, they are on their way though. If you are desperate to get your hands on them, just buy some hpi ones, they are pretty much identical
MARKANO: I would have thought they would be in use at the FR, where many drivers are using R blocks already to give outboard toe out. The varying degrees of outboard toe is a very good idea, but I can see it being expensive though with all these different suspension mounts....
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 07-19-2006, 04:38 AM   #5730
Teddy's Avatar
The one that Team Yokomo used are from HPI/HB.
They need different outer suspension arm pin, so you need to drill the arm to 2.5mm to use it on BD.
Also you need to change the driveshaft...
I think that is better to wait for Yokomo one (if they will release it)
Teddy is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
