Old 07-14-2006, 02:46 PM   #5701
Originally Posted by VooDooPH
will the front BD shock tower fit the LCG? kinda broke mine (repaired with CA glue and some cotton) and the only available parts are from the BD.
they will fit but not aswel, the holes for mounting the shock tower to the bulkheads are closer together on the bd than the lcg. so you can fit it but only with two screws....
agower is offline   Reply With Quote
Old 07-14-2006, 03:09 PM   #5702
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Thanks for that G*speed
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 07-14-2006, 06:00 PM   #5703
Simon K's Avatar
I've just bought some SDW arms for my BD(haven't fitted them yet). Do I need to buy anything else or will they go straight on?
Simon K is offline   Reply With Quote
Old 07-14-2006, 07:22 PM   #5704
You will need to shave about a mm off the inside of the arms in order for the arms to clear the front bulkheades. I used a hinge pin and put both the standard arm and the Worlds arm on the same pin to figure out how much to remove with a dremel.
pops is offline   Reply With Quote
Old 07-17-2006, 09:12 PM   #5705
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Looking for a good rubber tire carpet starting setup. The car will be ran on CS 27s. Any info would be killer!
Jeff
Jeff Werner is online now   Reply With Quote
Old 07-18-2006, 12:34 AM   #5706
Simon K's Avatar
Thanks, after a closer look at the arms that should work well.
Old 07-18-2006, 01:26 AM   #5707
coons88's Avatar
Send a message via MSN to coons88
Here are some really good pictures of Masami's BDM from the worlds. You can see all the new parts. Click the pictures to enlarge them.
http://www.rcinfos.com/2006/2006_07_...omo_masami.php
Can anyone translate that
I notice the front has differnt wheel hex things to the normal ones on the rear The wheel nuts are also weird.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 07-18-2006, 01:53 AM   #5708
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
the wheel nuts in the pic's are for use with Setup Wheels or setup station's,
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 07-18-2006, 02:36 AM   #5709
Hi,
The article is about the 1/10 TC Worlds in Collegno, The author has discussed with M. Yokobori - Yokomo's boss.
Masami wanted really hard this TC title and prepared himself a lot.
It is a personal challenge for him as he would like to be the first pilot to be World Champ in any RC category.
He came with a full team to support him in this quest,
2 mecanics, one dedicated to the chassis, suspension and the other one to the transmission part only diff, motors.
Another Yokomo pilot dedicated to the batteries charge and discharge.
1 team manager.
Masami work is tires sanding and treatment, fingers + arms + full body stretching and meditation
Masami even came with a full box of glasses, all adapted to different luminosity
Mike Reedy was absent during this Worlds and no motor assistance was proposed to Masami, he asked then Team Orion for support who could not refuse.
In despite of this impressive armada, at the beginning of the first qualification leg Masami's motor was soldered with reverse polarity and Yokomo team have urgently turned the endbell to let Masami run but it results with a shorter wire that came unsoldered during the leg and Masami did not finish.
Text near pictures are about the new parts seen on Masami car, new steering arms,...
Last text block is about Masami race, Andy Moore and Masami finished the qualification with the same points but Andy was faster with 0.05 sec at one leg and had the TQ.
First final leg, Masami chased Andy tried to pass him inside but Andy slammed the door and Masami spinned, Marc who was around passed Masami and finsihed second in front of Masami.
Second leg, Masami forced and tried the impossible to pass Andy and was given a Stop&Go penalty, he then finished at the third place.
Third and last final, Masami at the middle of the race was 5-6 meters behind Andy showed his talents and came back on Andy who with wisdom let Masami passed him.
Masami finished Second at this Worlds event and has not filled this little gap in his prestigious palmares.
Ralf is offline   Reply With Quote
Old 07-18-2006, 02:43 AM   #5710
Guys,
you can find more pictures of Masamis BD at last Worlds event
www.petitrc.com
Go to album 4 of the Worlds coverage (09/7)
cheers,
Old 07-18-2006, 02:44 AM   #5711
coons88's Avatar
Yea that is what I thought.
Old 07-18-2006, 05:20 AM   #5712
Ali Graham's Avatar
The wheel hexes used on the front are new prototype items, they are wider than std I believe and they are designed to reduce wheel wobble. I'm guessing that Masami ran them on the front only to widen the front track width and kill some steering and increase stability.
Old 07-18-2006, 05:24 AM   #5713
Hi,
no, it's exactly the opposite. They are narrower and you can adjust the track width with the spacers included.
And the new front suspension blocks are also available now.
Now we've only to wait for the new suspension parts...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 07-18-2006, 05:58 AM   #5714
Ali Graham's Avatar
Thanks for clearing that up chris
Masami's do look fair wide in the pic so maybe his mechanic got carried away with the spacers?
Old 07-18-2006, 06:12 AM   #5715
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Any news on weather they will be the same width (or thinner) specification as the SDW arms? Hopefully they will be more readily available than the SDW arms too
v0rtex is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
