Old 07-09-2006, 10:30 AM   #5641
Originally Posted by caveman
Pops, please don't refer the steering knuckle as "0"deg & "1"deg, you confuse many people. Those are "0"mm trailing(inline) & "1"mm trailing.
Really? He didn't ask for an explaination about the steering hubs, he was asking about the 0 deg C Hub and if you could use a 0 deg or 1 deg steering hub, and my answer was there were no 0 deg C hubs. There was a good enough explanation for the steering hubs by you prior to his post on the steering hubs.
pops is offline   Reply With Quote
Old 07-09-2006, 10:36 AM   #5642
Really.
caveman is offline   Reply With Quote
Old 07-09-2006, 10:54 AM   #5643
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
On another subject.........
I gave the HPI c-hubs (4 degree) a go on Saturday, on ashpahlt running rubber. Car was absolutely planted and was setting excellent times. Only modding needed is to drill the outer hingepin hole on your wishbones to 2.5mm, and use HPI outer hingepins. The HPI hubs gave more steering lock and better geometry, the car felt a lot smoother and more progressive to drive than std, yet it also had more steering!!! Now that's a beau of a combination!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 07-09-2006, 11:12 AM   #5644
I'm thinking about that as well, are you using HPI C-hub with Yokomo steering knuckle or with HPI'one? I may get some to try next week.
Old 07-09-2006, 11:22 AM   #5645
Ali Graham's Avatar
Nah I just used std 0 offset steering blocks. I might get some HPI blocks though when yok release the new ackerman plate which is further forward, which would make use of the front hole on the knuckle.
Old 07-09-2006, 08:21 PM   #5646
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Maybe this was discussed already, but what are people doing to make their BD's foam friendly? I already have the hard chassis and was wondering if a thicker upper deck was avalible. Other wise I know how to stiffen it, but it is a pain. I figured I would use associated Purple front and bronze rear springs with 60 wt front and 40 wt rear oil, but dont know what to do about pistons. I was thinking 3mm droop front and rear, but I am totally guessing on that also. And body G6, but thats simple. As far as the springs and oil, i am guessing too. Its all I could think of. To use a front diff do I just buy all of the rear diff parts and use it in the front? And lastly, does Yokomo sell a solid center pulley instead of the one way pulley?
College
Switch Blade is offline   Reply With Quote
Old 07-09-2006, 09:28 PM   #5647
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
cant really help ya with carpet, but yes yokomo does sell a direct / locked center pully, i can not remember the part # though, when i remember or find our ill re-post,
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 07-09-2006, 09:34 PM   #5648
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
With regards to the front ball diff, a rear diff fits in the front with no changes.
v0rtex is offline   Reply With Quote
Old 07-09-2006, 09:35 PM   #5649
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
hi just wanna know where can i buy those carbon fiber dical or tape ,so i can put it in my weights so it will blend on my chassis..
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 07-09-2006, 09:40 PM   #5650
JasonC's Avatar
www.yokomousa.com is your friend
carbon sticker is part # zc-cdw
Old 07-09-2006, 09:48 PM   #5651
thanks a lot guys. My original intention when I bought the BDM was to use it as a rubber car, but my racing buddies talked me into racing foam...
and as I look at the parts list myself I cant find the solid center pulley.
College
Old 07-09-2006, 09:58 PM   #5652
pinggoy's Avatar
thanx
TAMIYA TRF416X
Old 07-10-2006, 07:38 AM   #5653
stormperson's Avatar
Send a message via AIM to stormperson
Parma also sells cf decal sheets...
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 07-10-2006, 07:52 AM   #5654
johnbull's Avatar
I'm playing with a centre link steering system instead of the 2 links, at the moment.
Apart from making the car lighter to compensate a bit for the heavier brushless system, I also have plenty of ackerman now. However, does ackerman do much to help when you're running a spool? I don't think so.
johnbull is offline   Reply With Quote
Old 07-10-2006, 07:57 AM   #5655
Could you post a couple of pics Joe?
Dan Hughes is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
