Old 07-08-2006, 05:23 AM   #5626
The "1" knuckle sold with 0 deg rear hub, SD-415(normal), SD-415G(graphite).
Why don't you get the aluminium knuckle, much less problem with stripping. Speed model make some cheap one. I think US$16 a pair for either "1" or "0"knuckle. Although I don't know who have them in stock.
caveman is offline   Reply With Quote
Old 07-08-2006, 06:58 AM   #5627
What springs and oil is recomended for stock rubber racing?
7 celler is offline   Reply With Quote
Old 07-08-2006, 04:29 PM   #5628
Could someone send me the Grainger Setup for West London? I'm down there next weekend an I need to know what to get so my setup is the same or similar.
Paul
pwracing is offline   Reply With Quote
Old 07-08-2006, 04:57 PM   #5629
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
what combination you guys have in your sterring parts... "0" c huds and "1" steering knuckles?? or you can do it "0" on both?
and also anyone uses tamiya shocks??
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 07-08-2006, 05:12 PM   #5630
There is only one stock 4 deg c hub, and either 0 deg offset or 1 deg offset steering hubs.
pops is offline   Reply With Quote
Old 07-08-2006, 05:49 PM   #5631
pinggoy's Avatar
oh sori..so the stock is 4 degrees? for the c hubs? so which is better to put in the 1 deg. or 0 deg. knuckles??
TAMIYA TRF416X
Old 07-08-2006, 05:53 PM   #5632
Pops, please don't refer the steering knuckle as "0"deg & "1"deg, you confuse many people. Those are "0"mm trailing(inline) & "1"mm trailing.
Old 07-08-2006, 06:47 PM   #5633
pinggoy's Avatar
so what do you mean by trailing?(inline)
TAMIYA TRF416X
Old 07-08-2006, 06:59 PM   #5634
Talking
Trailing(i hope this is the right word), center of drive axle is behind center of king-pin. e.g. if you also run 1/12, look at the steering block, the axle is 1/8"(3.2mm) behind the kingpin(side view). in case of BD, it's 1mm, I think only yokomo use trailing steering knuckle. All the companies like X-ray, HPI, Asso etc, only has inline steering knuckle.
Old 07-08-2006, 07:07 PM   #5635
pinggoy's Avatar
so the whats the contribution if you use 1 mm inline ??
TAMIYA TRF416X
Old 07-08-2006, 07:16 PM   #5636
inline means "0"mm trailing, the"1"mm we should not call it inline.
"0"mm has more steering and more responsive, use it when I run spool outdoor or indoor with one-way. Use "1"mm only on big oudoor track with one-way, make the car easy to drive in fast corners. Other people may have different ideas
Old 07-08-2006, 07:17 PM   #5637
coons88's Avatar
Send a message via MSN to coons88
The 1mm trailing give less entry steering and makes the car less aggressive.
The other night I snapped a pin in the universal, so I decided to do what some of you guys doand go and buy a drill blank and make my own pins. But I am having some problems.
1. None of the hardware stores I call sell drill blanks
2. When I say #53 they just look at me like this all the drill bits are measured in mm, not numbers. So I will have to measure diameter of the pin, but thats no big deal.
But where did you guys find drill blanks???
Edit: Can someone please tell me the diameter of the pin because my calipers are useless
And I remember someone said you can use a 1.5mm allen key cut to size to use as a pin, but it doesn't fit...
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 07-08-2006, 07:55 PM   #5638
`Those pins are 1.5mm dia.
1.5mm allen key is 1.7mm from corner to the opposite corner, flat side to the opposite flat side is 1.5mm. It's too big to fit into the hole.
Old 07-08-2006, 08:30 PM   #5639
hi. i try putting on the "1" steering knuckle. it doesnt fit. do you need longer axles or something? thanks
qwerty is offline   Reply With Quote
Old 07-08-2006, 09:27 PM   #5640
loopedeloop's Avatar
Coons,
I couldnt get drill blanks either so just ordered #53 drill bits and cut the shank off them. I got 2 pins for every bit I cut. I havent broken a pin since.
Get them from donovans trade supplys or similar.
PM me if you cant find them and I'll get you some from whangarei.
cheers
geoff
loopedeloop is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
