Old 06-29-2006, 02:05 PM   #5536
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note we receive a good shipment of Yokomo parts back in stock for both BD and SD kits
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-29-2006, 09:55 PM   #5537
Originally Posted by Dan Hughes
Pops quick Q, just got BX cups and studs do you use the studs in the rear hub carrier?
No, using the longer ball studs in the rear on the inside hole. Shortest link position.
pops is offline   Reply With Quote
Old 06-29-2006, 09:56 PM   #5538
Originally Posted by Jeff Werner
Pops- on your nats setup sheet- It lists rear droop at 4mm and front at 6mm what method did you use to measure this (guage, over rideheight, ect)? Putting the setup on the car to try it out and wanted to get that part right.
Jeff
Jeff, using a Yokomo droop guage, on lowest part of the arm.
Old 06-29-2006, 09:59 PM   #5539
Originally Posted by caveman
The Touring Worlds is just a week away, wait and see what new stuffs yokomo, tamiya, HB etc have, even not a completely new car, they may have some updates, BD"W", 415MSX"II", Cyclone"X"....
You might see a BD-BE Edition.
Old 06-29-2006, 10:02 PM   #5540
Also got the SD-300RF part to do the toe out....belt goes over the top of this? Grind 1mm off the bottom of the part correct? Do not want to mess up a new item...lol
Jeff
Right, you should grind 1mm off the bottom, so you can add up to a 1mm shim if needed.
Old 06-29-2006, 11:07 PM   #5541
SpeedTech's Avatar
Hi Pops,
Thanks for stopping in the other day, I feel bad I had to take off so quickly like that. Hope you liked the new shop
Steve Wang
Old 06-30-2006, 12:27 AM   #5542
BringItOn's Avatar
hi any BD setup sheets for Outdoor Asphalt, with one way?
I am getting my BD ready to race.
Here are a few things I have thought of and learnt from reading through this thread.
1. Get the Masami Rear Shock Tower - whats the difference? different shock mounting locations?
2. Centre Locked diff.
3. Yokomo SDW Front Arms - gives narrower track width - should get more steering
4. get a tamiya servo saver.
5. team bomber F&R belts (masami edition) - are these strong belts? or just lighter? I am running mod so i rather some stronger belts. - Anyone got a part number for these belts?
Are these the same as the Yokomo MR-4TCBD Rear Drive Belt (Low Friction) and Yokomo MR-4TCBD Front Drive Belt (Low Friction) belts?
Anything else i should look at getting? Any shims/flanges/bearings i may need?
thanks
BringItOn is offline   Reply With Quote
Old 06-30-2006, 07:58 AM   #5543
Originally Posted by SpeedTech
Hi Pops,
Steve Wang
No problem Steve. Have to tell you your shop keeps getting bigger and better everytime I drop by.
Old 06-30-2006, 08:20 AM   #5544
BringItOn,
Do not run the center locked pulley unless you are running the spool. The car will drive weird with just the locked pulley and a one-way.
The box set-up works very good to start.
The worlds arms will give you a little more steering, great when running a spool and locked center pulley.
Team Bomber belts are softer in the begining, but if you soak your new stock belts in WD-40 for a couple of days, they're just as good if not better. The Low Friction Belts for the BD are the right belts.
Extra parts needed are steering hubs, O degree, 1 degree, extra set of arms, and Wide Front Bumper. The Wide Front Bumper will reduce the cost of buying arms, steering hubs and C-hubs. I would get a set of extra 6x10 wheel bearings. For some reason, maybe small wheel bearings, the front end of the Yokomo are tough on wheel bearings. All around, the Yokomo precision wheel bearings are very good.
Old 06-30-2006, 08:32 AM   #5545
HarshGuy's Avatar
Hi Pops,
Steve Wang
Steve ...no need to apologize, everyone takes off quickly when pops stops by
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-30-2006, 08:35 AM   #5546
ha ha.
Old 06-30-2006, 12:10 PM   #5547
BringItOn,
I may have jumped the gun on the "car driving weird" with a locked pulley and a front one-way. I understand some people are doing that at So Cal and are having very good results. Could have been just the car at the time (wrong set-up) or the driver. I would give it a try and let us know how it is working for you. You have nothing to lose.
Old 06-30-2006, 09:21 PM   #5548
Jochim_18's Avatar
I've been running my BD with the locked center and front one-way for quite a while now and it works pretty good. And the car feels like it accelerates a lot faster than with a center one-way.
Old 07-01-2006, 06:02 AM   #5549
Tpg racer's Avatar
Hey guys just being curious, is the Yok.BD better than the Hpi Pro4???
Any input would be helpfull.
Tpg racer is offline   Reply With Quote
Old 07-01-2006, 06:39 AM   #5550
Matt Howard's Avatar
He visited me once and I had to "move" to Korea
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
