Old 06-08-2006, 04:52 AM   #5371
Send a message via MSN to Zacharopoulos
No sorry not me , but i think you can find it out if you take a look at the manual!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 06-08-2006, 09:03 AM   #5372
thrust balls are 1.6mm, diff balls are 2.4mm(3/32).
caveman is offline   Reply With Quote
Old 06-08-2006, 04:04 PM   #5373
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
sup guys...im interested on this yokomo bd car..i just wanna know or could you guy talk me out on this cause im currently running xray t2 and it tweaks once in a while..so is this ccar tweaks? as much as the t2? tell me how good is this than the t2....thanx
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 06-08-2006, 04:25 PM   #5374
I guess everyone has their likes and dislikes about a car but I have both cars and can tell you that I like the BD better. For me it's an easier car to drive and to dial in. I turn faster and more consistent laps then with the T2. I haven't really had problems with tweaking. I put a little threadlock on the upper deck screws and tightened them down a little snugly and I've been good to go. I like the T2 also but I don't have as much confidence in it. I feel my car has performed inconsistently at times. The car will be good then get loose all of a sudden then be good again. It was like that with my 05 car too. That was just my experience. I'm actually looking to sell my T2
DOTMAN is offline   Reply With Quote
Old 06-08-2006, 04:52 PM   #5375
I have a speedtech spool and it make the car viberate to all get out in the front of the car. Everytime I steer the car left or right it viberates the car till I think its going to fall apart. Is this what the aluminum or these titanium spools going to do. That is why I was asking what everyone is running. Im unhappy with the speedtech spool and rather have the titanium spool, I just dont want it to do the same thing as the speedtech spool.
performance26 is offline   Reply With Quote
Old 06-08-2006, 04:55 PM   #5376
That vibration is caused by your universals, not the spool. That's where your problem is. You're gonna feel that with whatever spool you use until you fix that.
Old 06-08-2006, 05:04 PM   #5377
how do i fix that and it did the same thing when I put in CVDs as well
Old 06-08-2006, 05:16 PM   #5378
Are you using the stock BD universals up front? If so, the first thing you want to do is replace the pin that connects the the bone to the axle. The stock pin is too short and will come loose and break during a run. The pins used by the Barricuda work great. I haven't had a problem since buying those. Speedtechrc.com carrys them. Some people use piano wire too. I just don't remember the size. When that pin starts to come loose it can cause vibration too. Sometimes it's hard to get a universal not to bind. I've had universals be very smooth until the grub screw was tightened. I really struggled with it. I wish I had a fix for you. Mine worked okay from the start but I just bought the TiR universals which work even better.
Old 06-08-2006, 05:24 PM   #5379
rocketron's Avatar
Trader Rating: 16 (100%+)
on the front cvd's the pin can and has caused me problems. you can use #53 drill blank and make your own. drill blank stock is approx $3 ea or less and you can get several out of each piece. if you can not get drill blanks a #53 drill works by cut the pieces out of the solid portion you only get two pieces per drill though.
also use a good high temp grease when assembling these - go to pepboy or a car parts shop to get a high temp wheel bearing grease.
put some of the grease in the spool and dogbone when installing in the car this will help eliminate some chatter and binding as well.
hope that helps you out
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 06-08-2006, 05:28 PM   #5380
Listen to Ron. He's the EF Hutton of RC
Old 06-08-2006, 06:17 PM   #5381
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
that he is
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-09-2006, 09:56 PM   #5382
pinggoy's Avatar
anybody trying to sell their yokomo bd??? lmk
TAMIYA TRF416X
Old 06-10-2006, 10:29 AM   #5383
JasonC's Avatar
smojoe is selling on in the forsale form for a very good price
Old 06-10-2006, 09:34 PM   #5384
pinggoy's Avatar
is the yokomo bd has an optional front diff??.
TAMIYA TRF416X
Old 06-10-2006, 09:53 PM   #5385
Yes a diff and a spool.
pops is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
