Old 06-06-2006, 08:23 AM   #5356
Originally Posted by BJ
I thought this was the other way round.
Shimming up the inner camber link will lower the roll center, which will result in more chassis roll
Shiming up the inner pivot point for the upper link will result in more chassis roll. On low traction tracks you want more roll.
Higher inner pivot points lower the roll center, while lower inner pivot points raise the roll center. Higher traction conditions you want less roll.
pops is offline   Reply With Quote
Old 06-06-2006, 10:05 PM   #5357
btw, pops good luck this week at nats wish i could have made it down.
Turtlemaster is offline   Reply With Quote
Old 06-06-2006, 10:46 PM   #5358
Thanks, we will need all the luck we can get.
Old 06-07-2006, 02:10 AM   #5359
Rowdy's Avatar
Sorry guys for the mistake, I have edited the post to read correctly now. I was thinking the correct thing but typed the opposite.
Would have made this post a little hard to understand.
Originally Posted by Rowdy
Moving the hinge pin from the high hole on the hub to the low hole would also raise the roll center. However, if you were to do this and then move the outer camber link backward to the non standard hole on the hub, which in turn would lower the roll center back close to its original position, you would be moving the point of contact with the road slightly aft much the same as castor does. Although not exactly the same as castor.
Rowdy is offline   Reply With Quote
Old 06-07-2006, 03:32 AM   #5360
Send a message via MSN to Zacharopoulos
Thanks my friend !!! You really helped me!!!! that changes is almost 0,5 sec per lap!!!
thanks now i can understand the philosophy of my car!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 06-07-2006, 08:50 PM   #5361
I need some help, what kind of steel spools are you guys using in the Yokomo BD? I shear off the plastic one and I have been looking for a steel replacement. I dont really want to buy a bunch of plastic ones.
performance26 is offline   Reply With Quote
Old 06-07-2006, 08:56 PM   #5362
Speedtech has them. We are using one right now, works very well.
Old 06-07-2006, 09:18 PM   #5363
Jochim_18's Avatar
Speedtech Spool are to heavy I tried one before. I aslo have the problem with the yokomo spool I snap it in half.
Old 06-07-2006, 09:37 PM   #5364
Yes they are heavy, but seem to work very well in stock, I believe they even help in stock and help carry more speed thru the corners. Not having any steering problems with it at all in stock.
Old 06-08-2006, 01:45 AM   #5365
Rowdy's Avatar
Titanium Racing has titanium spools which should be strong and light. Not sure if your interested in these but you can order direct from their site.
Old 06-08-2006, 02:01 AM   #5366
Our spools are indeed very light and strong. You can have a choice of either Aluminium oudrives or Delrin outdrives. The Derin outdrives also comes with a pair of titanium sleeves to strengthen the outdrives. If you do ever break them the outdrives are replaceable at a small price.
Regards
Paul Webster
Titanium Racing Ltd
pwracing is offline   Reply With Quote
Old 06-08-2006, 04:41 AM   #5367
can you tell me what are diff balls diameter? Is the same as on HPI pro4 (2mm and 2,4mm) or perhaps slightly diferent size?
tomislav is offline   Reply With Quote
Old 06-08-2006, 04:41 AM   #5368
Thanks guys for the help I really appreciate it
Old 06-08-2006, 04:43 AM   #5369
i think that the balls must be 3/32!!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 06-08-2006, 04:48 AM   #5370
tnx, and perhaps you know thrust balls size?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
