Old 06-02-2006, 10:22 PM   #5311
Originally Posted by xxxkat
I have a question on rims, I'm using some CS-27's and they rub on the A arms.. (3/4 turn to full lock) Am I doing something wrong, Or am I supposed to use just Yokomo Rims? I have yet to use this car and I have a bunch of CS 27's that I would like to use. Anyone else have this problem??
Sounds like you may be running the steering hub in the bottom hole on the arm, and the spacer is under the steering hub. Move the spacer to the top of the hub to lower the steering hub, this will stop the rubbing.
pops is offline   Reply With Quote
Old 06-02-2006, 10:52 PM   #5312
Oasis's Avatar
Trader Rating: 36 (100%+)
Thanks Pops, This is exactly what happened, I bought the car off a friend of mine and when I checked (just this second) that is what I found. Should I always run the hubs in the bottom (suspension pin) position. Well thanks again and I wish you and Alex the best of luck at the Nationals next week..
Oasis is offline   Reply With Quote
Old 06-02-2006, 10:58 PM   #5313
wagonman72's Avatar
Geez Mike whataya new?
wagonman72 is offline   Reply With Quote
Old 06-02-2006, 11:08 PM   #5314
No not always, some set ups you can run it in the top hole, you just have to adjust the spacer to the bottom of the steering hub.
Thanks we will need it, only running stock so there really isn't a lot of pressure, just going to try and kick back and enjoy the race.
Old 06-02-2006, 11:15 PM   #5315
Oasis's Avatar
To the current crop of Yokomos..Yes
Any new's on the Hellfire new parts..
Old 06-02-2006, 11:54 PM   #5316
EVS
What is the part # for the SDW arms? I tried to run my BD on carpet and it was fast, but at least 3-5 tenths slower than my X-ray. I just couldn't get is to be as agressive. Any other suggestions?
EVS is offline   Reply With Quote
Old 06-03-2006, 01:28 AM   #5317
Thumbs up SDW ARMS
PNO for the SDW Arms is SD-008HW. Need two sets for one car.
Later
Calvin.
caltech1 is offline   Reply With Quote
Old 06-03-2006, 02:11 AM   #5318
johnbull's Avatar
Originally Posted by Turtlemaster
welcome back johnbull, hope you didn't join the "zipper" club like i did last year
Did that 10 years ago, but had an enormous heart attack last December - at the track. Got it all fixed now - a few more stents in the system, and a load more pills to take daily, but other than that, it's OK. We're getting old.
We have our end of season One hour Endurance this coming Wednesday (a holiday here) and Josh and I will be sharing one of the BD's for that.
Should be fun.
johnbull is offline   Reply With Quote
Old 06-03-2006, 02:58 AM   #5319
Hi all,
I'm looking for some help. I'm racing at Barham, UK in a couple of weeks and I need some setup start up advice. I'm going to be running Corally SSB's and a Team Almighty 19t Atlas tuned motor.
Cheers
Paul
pwracing is offline   Reply With Quote
Old 06-03-2006, 02:59 AM   #5320
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
http://i19.photobucket.com/albums/b1...ups/barham.jpg
that should be of some help to you
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 06-03-2006, 03:04 AM   #5321
johnbull's Avatar
Originally Posted by pwracing
Hi all,
Cheers
Paul
Hava a look out for Chris Grainger, Olly Jefferies, John Pape etc set ups for that circuit. I'm sure you will find them in the CML wensite.
If not go into rcracechat.com. All of them write in there.
Good luck.
Old 06-03-2006, 10:38 AM   #5322
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
for those who may want to know
the yokomo plastic spool weight is 11 grams
and
the Tri alum/delrin spools is 16 grams
according to my Tripple Beam Balance
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-03-2006, 01:39 PM   #5323
Jochim_18's Avatar
HMMMMM.... I haven't have any problem rubbing any of the Take-off rims against the arms....
Old 06-03-2006, 06:49 PM   #5324
My answer to that was:
If you are running the spacer in the correct position on the steering hub, you would not have any rubbing problem.
Old 06-03-2006, 10:29 PM   #5325
Should be fun.
i'm giving up on the enduros, (i think) we had a 12 hour one a while ago, and now the track boss wants to do a 24 hour. not for me, no way
Turtlemaster is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
