Old 05-30-2006, 01:38 PM   #5266
pops ... speedy-932 thanks 4 the help...
mwoods is offline   Reply With Quote
Old 05-30-2006, 02:18 PM   #5267
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Ok answers to hopefully most questions!
1. The SDW arms make the front end 4mm narrower in TOTAL, 2mm each side. They make the car a lot better to drive and give it a lot more positive steering with a spool, and indoors with a 1-way on rubbers it is unstobbale That doesn't make the std arms obsolete, I used them the other day at Halifax (for non UK-ers this is a huge track where the last nitro euros were held) and they allowed me to run a soft, progressive setup without to much bite to scrub off corner speed. Std arms seem better on more flowing tracks, very low grip situations (the team ran std arms at the stafford national, where chris took ftd and won) or in very high grip outdoor situations, I believe this is what the Jap team run, and hence why they come on the Masami Edition.
2. The yokomo springs. As they are progressive, there is no accurate way to give them readings as the poundage varies throughout the compression. The HPI springs have ratings, but these aren't entirely accurate. A 16.9 rated HPI spring felt very similar to a 14lb rayspeed spring on the track. The best way to match the new yokomo springs is in comparison with the hpi and then rayspeed springs.
The progressive springs make the car easier to drive and smoother, but these are the comparisons and conclusions I have come to: (I also asked Chris Grainger for some clarification ) These won't be entirely spot on accurate due to the different charecterisitcs of these springs, but it is a rough guide:
yok black = hpi blue = rayspeed green
yok blue = hpi silver = rayspeed blue
yok yellow = hpi silver/pink (in between) = rayspeed yellow
yok pink = hpi pink = rayspeed white
yok green = hpi gold = rayspeed red
yok orange = hpi white = rayspeed red/grey
with a 1-way, roll bars and std arms I ran yok blues all round (halifax)
with a spool, front roll bar and SDW arms I ran yok pink fronts and yok blue rears (stafford)
These were both with 450/400 oil
As an extra note, here is something I just made (see attachment). I believed more could be done in low-grip conditions than just removing the centre top deck post, and also saw that the team did this for the last Euros (well at least Pulmper/plumper did, can't spell it!), hence I got the dremel out and set to work
old top deck is on the right hand side for comparison
**sorry attachment didn't work first time**
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 05-30-2006, 04:04 PM   #5268
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Thanks for the tip, could be handy to know in a low-grip situation
v0rtex is offline   Reply With Quote
Old 05-31-2006, 12:55 AM   #5269
Send a message via MSN to Zacharopoulos
Originally Posted by speedy-932
Hi,
@Zacharopoulos: Where do you see different pulleys?
@mwoods: I think they are the same spring rate as the old Yokomo ones. Just longer.
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Cheers
Chris
If you look here and notice the pulleys i think that you will understand what i mean , and especially the part ZS-630ASP
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-31-2006, 12:57 AM   #5270
They're not BD pulleys. They're for the old MR4-TC.
Old 05-31-2006, 01:01 AM   #5271
Yes i got it from the part number , but why they are at masami section , does masami edition uses these pulleys??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-31-2006, 01:03 AM   #5272
Thats not the Masami section. Im not sure exactly what MD stands for, but its not Masami
Just look in the BD/SD parts section for Masami parts. I dont know id Speedtech has any listed yet though.
Old 05-31-2006, 01:06 AM   #5273
Are you sure??? i thought that MD was from MBD so i looked there!! ok thanks!!
Anyone know differences between masami BD and BD?? except pulleys
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-31-2006, 01:09 AM   #5274
Ti Nitride shock shafts
White bomber belts
Ti screw set
new rear shock tower
new dogbones/cvds/unis whatever you call them
hollow centre shaft
precision bearing set
progressive rate springs
its all been discussed in the past, have a read back through the BD thread. Pulleys on the Masami are the same as the standard BD.
Old 05-31-2006, 01:13 AM   #5275
Sorry but i don't remember any discussion about MBD that's why i asked !!
So my car is better than MBD right??????
I have everything from masami car , + ceramic bearings , + SDW unis , hahahahahahah
thanks1!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-31-2006, 04:19 AM   #5276
Guys , as i noticed the part number for SDW arms is SD-008HW right???
Only the front are narrower or the rear are also narrower than the standard ??
Do you use only the front ???
thanks
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-31-2006, 04:31 AM   #5277
Smile SDW ARMS
You use the SDW front arms on the front of the BD. If you read earlier posts on this page from speedy 932 he dremeled a bit of the SDW arm. By having the front narrower it will give more steering.
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 05-31-2006, 05:10 AM   #5278
Ali Graham's Avatar
In the SDW arm set, you get a front and a rear. The front is 2mm narrower, the rear is just a std rear BD/SD arm with 2 holes. So you need two sets to do the car.
Old 05-31-2006, 12:41 PM   #5279
tcfree's Avatar
So dont crash it lol!!
tcfree is offline   Reply With Quote
Old 05-31-2006, 12:47 PM   #5280
Thanks i will try it !!!
Anyone tried bomber shock towers???
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
