Old 05-28-2006, 12:41 AM   #5236
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Turtlemaster
well guys, today i switched to the stiffer yok chassis, the white springs, and went from 2.5 rear toe to 2.0 with .05 hubs. amazing, differance in handling. i went from the occasional 10.3 and one time 10.1 to repeated 10.2's and a fast lap of 9.8. i am one happy yok customer/driver.
I'm totally in agreement with you; your car felt uber-dialed today Now I just have to order a new stiff chassis-n-bits...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-28-2006, 09:05 AM   #5237
Originally Posted by v0rtex
What surface & tires were you running?
pops is correct, chassis is very consistant, tires are, speedmind premounted sorex 36's on all four corners. surface was/is indoor asphalt, a couple small bumps here and there but nothing major, high bite, can be seen here http://www.seattleindoorraceway.com/...rack_info.html
pics show track being built, but scroll down for more pics.
Turtlemaster is offline   Reply With Quote
Old 05-28-2006, 10:11 AM   #5238
Hi,
did you race on rubber tires? Would you mind to share you setup?
I was this weekend at Türkheim for the Euros WarmUp. My car was really dialed after a few packs. I drove my fastest laptime after the rain (14.899). The really fast Xray guys (Groskamp, Wilck, Myrberg,...) drove around 2-4 tenths faster... so... that's ok for me...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 05-28-2006, 11:11 AM   #5239
yes rubber tires, sorex 36's premounted by speedmind.
setup
stiff yok chassis, standard top plate. front one way camber link in middle hole on c hub, no spacers under inner camber link, steering link ball studs on bottom of 0 degree steering arms and center plate, ball stud on plate 2nd hole from front. front shocks, 40wt losi oil with 3 hole yok piston mounted middle hole on front arm, 2nd hole from inside on front tower, with yok white springs with pink dot.
direct drive on spur gear. 110 64t spur. rear diff set tight, white springs with yellow dot, R0+2 rear camber block, .05 rear hubs. 50 losi shock oil with 2 hole piston. mounted outer hole on arm and 2nd hole from outside on tower. outter camber link in standard position, no spacer on inner camber link ball stud. using the long ball studs on rear and short in front. gold sway bars front and rear. installed the one piece hinge pin mounts not sure if it was a performance gain or not. no spacers under hinge pin mounts. droop is set with car sitting on board with tires on. ride height of 5.5 mm in rear and 5mm in front and holding the tires down chassis will raise 4 mm in front and rear. i.e. ride height gauge will slip in to the 9mm position when chassis is raised with tires touching board. hope that helps. i know our aphalt and your tarmac is different, so not sure if it will work, but you won't know if you don't try drive with a smile. ritchie
one more note, this is setup i built the car with when changing over to the stiff chassis and white springs i just recieved from yok, i have yet to try and fine tune it.
Old 05-28-2006, 04:25 PM   #5240
I just moved to Japan and am looking forward to some great racing with my BD. The other day I found a hobby shop and couldn't believe the wall of parts they had for the Yokomo. I then walked over to the shelf and found a Masami edition BD. I can't wait until my car is here and I can go racing. By chance do any of you know some good tracks in Japan? Also, what's the brush of choice and a ball park roll-out for a 23t motor?
kmorast is offline   Reply With Quote
Old 05-28-2006, 05:12 PM   #5241
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Yatabe Arena: www.yatabearena.com (if you can read japanese). Its Yokomo's test track(s) in Japan.
Edit: http://www.yatabearena.com/information/index.html is a better link, still in Japanese though
v0rtex is offline   Reply With Quote
Old 05-28-2006, 06:49 PM   #5242
I'm aware of Yatabe Arena and also NRC stadium which is about 20 km south of Yatabe Arena. I wil definately be checking them out next weekend. Any other tracks?
Old 05-28-2006, 06:53 PM   #5243
RC Champ : http://www.rc-champ.co.jp/2005/champ.htm
Quite a few others i'd imagine, http://www.jmrca.com/ might have a listing - I cant read japanese..
Old 05-28-2006, 09:25 PM   #5244
where in the U.S. are you getting thick yok chassis. I would like one for my lcg that I run strickly on carpet
magnum is offline   Reply With Quote
Old 05-29-2006, 02:46 AM   #5245
Send a message via MSN to Zacharopoulos
Someone that knows where we can find yok stiff chassis and masami rear shock tower??
come on guys , i really need a stiff chassis!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-29-2006, 03:02 AM   #5246
If you're in the USA, YokomoUSA should be able to help you out.
Hard chassis for BD: BD-002GH
Masami Shock Tower: BD-018MG
Edit: Sorry, I see you're not in the USA. Im not sure of any stores in Europe you could buy from.
Old 05-29-2006, 03:10 AM   #5247
No i don't live in usa so i need a shop !!! thanks anyway
I don't need a shop only in europe , if you know any shop in us that has any of these please let me know!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-29-2006, 05:47 AM   #5248
Hi,
click in my signature on "RC CAR World" and send him an email. He will get back to you fast. He doesn't have the parts in the shop at the moment but he can order them for you.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 05-29-2006, 06:03 AM   #5249
I will try it thank you!!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-29-2006, 07:03 AM   #5250
In my opinion RC-Car-World is the best Online-Store for Yokomo in Europe. Good service, great prices and super fast shipping. I can also recommend this store.
theracer is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
