Old 05-25-2006, 01:40 AM   #5221
Sleighty's Avatar
does anyone have the part number for the little blue spacer that goes above the hub on the grainger edition car?
thnx
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 05-25-2006, 03:20 AM   #5222
Hi,
@Sleighty: SD-414C should be the number.
@caveman: No, that's the Genius 80. It is big but you should know that my chassis is 12mm narrower. So in standard BD it should fit just fine. If you look at the GM-Racing page you'll find the car of Markus Mobers.
http://www.gm-racing.de/webnews/bild...f/MobersBD.jpg
@Zacharopoulos: I made some chassis in different thicknesses. A 3mm chassis with a 3mm topdeck for carpet and a 2mm chassis witht the stock topdeck for asphalt.
On carpet you have the advantage, that the chassis is a lot stiffer and narrower. So the chassis rolls less and don't touches the surface as easy as with the stock one. The steering response is better and in high grip/high speed situations the car feels more stable.
With the 2mm chassis the only advantage is that you can change the stiffnes of the car by using different topdecks. Plus it is narrower.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 05-25-2006, 06:25 AM   #5223
Send a message via MSN to Zacharopoulos
If i ask you for one or two would it possible to make for me??? i was thinking for 2.5mm or 3mm without the top deck , but i will use it on asphalt!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-25-2006, 08:04 AM   #5224
Send a message via AIM to aoizip
Ralf:
Do you know the part number for the ride steering plate for the bd?
anybody know where to get it in the USA? I look every where and can't seem to find one.
thanks for the help
~Ming
aoizip is offline   Reply With Quote
Old 05-25-2006, 08:17 AM   #5225
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Anyone know a good setup site for BD setups. There aren't a lot in the Yokomo Site.
fpart is offline   Reply With Quote
Old 05-25-2006, 08:55 AM   #5226
housey's Avatar
http://www.cmldistribution.co.uk/tea...ter=0000000001
enjoy
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 05-25-2006, 01:33 PM   #5227
Originally Posted by aoizip
Ralf:
thanks for the help
~Ming
Here it is ;
RP 002B - Blue Alu steering plate for Yokomo BD
I know that it also exists in Black.
Ralf is offline   Reply With Quote
Old 05-26-2006, 11:35 AM   #5228
Default Setup - data
Originally Posted by housey
http://www.petitrc.com/view_news.php?id=4618 Slightly more complete!
Arn0 is offline   Reply With Quote
Old 05-27-2006, 01:26 PM   #5229
hello guys !!!
three things !!!!
first of all where i can find the Masami rear shock tower??? anyone tried the bomber towers????
Is it anything that i can change with the screws that keeps together the c hub and upright and the plastic washer that goes above or under the upright ??? i mean a different kind of screw and a colar or a washer!! That can also decrease the slop!!!
And last but not least at the back i race with the block that write on it +2 degrees!! What does this mean?? 2 deg. at each wheel ??, or 2 deg. at both wheels together???
thanks
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-27-2006, 05:31 PM   #5230
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
You can get Titanium kingpin sets from Yokomo that is simply a titanium screw with a titanium collar that replaces the old kingpin. That removes the need for the plastic collars. Cant find the part number right now.
2 degrees each wheel.
v0rtex is offline   Reply With Quote
Old 05-27-2006, 05:40 PM   #5231
Smile TITANIUM KINGPIN
Hi,
The PNo for the Titanium Kingpin Screw and spacer is SD-414TA. You get two spacers and two screws in a packet. Therefore you need two packets for one car.
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 05-27-2006, 07:38 PM   #5232
well guys, today i switched to the stiffer yok chassis, the white springs, and went from 2.5 rear toe to 2.0 with .05 hubs. amazing, differance in handling. i went from the occasional 10.3 and one time 10.1 to repeated 10.2's and a fast lap of 9.8. i am one happy yok customer/driver.
Turtlemaster is offline   Reply With Quote
Old 05-27-2006, 07:39 PM   #5233
What surface & tires were you running?
Old 05-27-2006, 08:14 PM   #5234
The firm chassis is really nice, car seems to be more consistant.
pops is offline   Reply With Quote
Old 05-27-2006, 09:50 PM   #5235
thanks!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
