Old 05-14-2006, 06:51 PM   #5161
Oasis's Avatar
Trader Rating: 36 (100%+)
I also noticed in the photo the outdrives..who makes them? Kim I got an LCG..
Oasis is offline   Reply With Quote
Old 05-14-2006, 06:52 PM   #5162
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Pretty sure they're Excel Delrin outdrives.
v0rtex is offline   Reply With Quote
Old 05-14-2006, 08:11 PM   #5163
Jochim_18's Avatar
Mike,
Have you tried the car yet? We raced last night at best buy parking lot traction is awesome. My BD is hooked up just put the fastest lap ... Will be racing next saturday night you should check it out.
I have a new Xray T2 but BD is a killer on asphalt.
Old 05-14-2006, 08:13 PM   #5164
Jochim_18's Avatar
Mike,
Those outdrives are made by Excel you can get them overseas in hong kong. I wanted to get one but hate to wait for it, they cost about $15 I'm fine right now with stock ones.
Old 05-14-2006, 11:23 PM   #5165
Hi,
@v0rtex: The spur gear is made by Robitronic (www.robitronic.com)
Or here
The chassis and the top deck are custom cut. The chassis is 12mm narrower then the standard one and flex a bit more (2mm version). I have a 3mm version for carpet aswell and this is really stiff.
@xxxkat: Yes, Excel makes them.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 05-15-2006, 07:53 AM   #5166
Rowdy's Avatar
I'v been interested in trying the Masami rear shock tower for a while. Anybody know where I can buy them online?
Rowdy is offline   Reply With Quote
Old 05-15-2006, 07:57 AM   #5167
Hi,
you could try Champ RC.
I have my shock tower from a german dealer.
http://www.rc-car-world.de/
You could contact him and ask if he ships overseas.
Cheers
Chris
Old 05-15-2006, 09:34 AM   #5168
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
The rear shock tower is awesome It does make small bumps seem a lot bigger though!!!! Its not the thing for a really bumpy track but mild bumps it can cope with. Very good turn-in and response.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 05-16-2006, 03:17 PM   #5169
BJ
On the Ackerman plate what seems to be the common setting, instruction says position 4, but somewhere I have read to use the second hole back?
Also what markings do you set the diff cam's too, I have 1 in from back on the front and 1 in from front on the back, if that makes sense
the rear belt feels OK but the front feels to tight (using black belts) what is the advantage over Bomber belts?
BJ is offline   Reply With Quote
Old 05-16-2006, 03:32 PM   #5170
Francis M.'s Avatar
The bomber belts are suppose to free up the drive train more, but
i don't feel a difference. On the ackerman plate the further back you
set it the more responsive it will be and should carry better speed
on fast flowing turns but will not make tight turns as good as having
the rod end all the way forward on the ackerman plate.
As for the Diff cams just set it like the inst. and it should be fine.
You will be happy with the car for sure.
My suggestion would be to run the car box stock and see what adjustment
you need once you have tried it. The base set up is one of the best starting
point for asphalt.
Francis M. is offline   Reply With Quote
Old 05-16-2006, 03:33 PM   #5171
The further forward you have the ball stud on the ackerman plate the more inital steering you should get, but you will loose a little exit steering.
Start out with the the cam marks at the longest marks on the mount, per the assembly instructions. You can adjust them as needed.
Bomber belts are supposed to be softer.
pops is offline   Reply With Quote
Old 05-16-2006, 05:33 PM   #5172
Default BD Servo saver
The kit comes with 2x servo saver mounts part # BD-200P these seem to just post for the bell cranks, does anybody know how these are servo savers?
YOKO
yoko is offline   Reply With Quote
Old 05-16-2006, 05:36 PM   #5173
YOKO
Good question. I just run the servo-saver from my old CGM on the BD - It saved the Ackerman plate a number of times
Old 05-16-2006, 05:53 PM   #5174
Default bd servo saver
only ran Bd twice broken 2 servos, fitted a cgm servo saver and broke ackerman plate.
i have glued the outer edge of new plate. i hope this will help.
shame they dont make these out of something like ally.
YOKO
Old 05-16-2006, 05:59 PM   #5175
YOKO
Various people have tried Alloy plates, I have one on my car at the moment. Its a little too soft for my liking but it beats breaking them all the time.
One of the guys I race with is looking into having some ackerman plates CNC machined, like the LGC plate. Problem then will be that the energy of a hit still has to go somewhere, back into the servo or popping off ball-cups no doubt.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
